    6.4.5添加激光雷达失败
    gazebo 仿真 激光雷达
    1.9k
      鱼哥帮我看看这是什么原因呀,在gazebo添加激光雷达插件后运行gazebo会概率性报错崩溃,激光雷达不生效,以下是完整日志:
      chen@chen-virtual-machine:~/Program/test_car/test_car_ws$ ros2 launch car_description gazebo_sim.launch.py
      [INFO] [launch]: All log files can be found below /home/chen/.ros/log/2025-03-03-16-07-16-874166-chen-virtual-machine-7374
      [INFO] [robot_state_publisher-1]: process started with pid [7376]
      [INFO] [gzserver-2]: process started with pid [7378]
      [INFO] [gzclient-3]: process started with pid [7380]
      [INFO] [spawn_entity.py-4]: process started with pid [7382]
      [INFO] [joint_state_publisher-5]: process started with pid [7384]
      [robot_state_publisher-1] [INFO] [1740989237.394305769] [robot_state_publisher]: got segment base_footprint_link
      [robot_state_publisher-1] [INFO] [1740989237.394658450] [robot_state_publisher]: got segment base_link
      [robot_state_publisher-1] [INFO] [1740989237.394672166] [robot_state_publisher]: got segment base_up_link
      [robot_state_publisher-1] [INFO] [1740989237.394681183] [robot_state_publisher]: got segment camera_link
      [robot_state_publisher-1] [INFO] [1740989237.394688216] [robot_state_publisher]: got segment camera_optical_link
      [robot_state_publisher-1] [INFO] [1740989237.394694828] [robot_state_publisher]: got segment holderfirst_link
      [robot_state_publisher-1] [INFO] [1740989237.394701200] [robot_state_publisher]: got segment holderfourth_link
      [robot_state_publisher-1] [INFO] [1740989237.394708244] [robot_state_publisher]: got segment holdersecond_link
      [robot_state_publisher-1] [INFO] [1740989237.394715647] [robot_state_publisher]: got segment holderthird_link
      [robot_state_publisher-1] [INFO] [1740989237.394722711] [robot_state_publisher]: got segment imu_link
      [robot_state_publisher-1] [INFO] [1740989237.394729944] [robot_state_publisher]: got segment laser_link
      [robot_state_publisher-1] [INFO] [1740989237.394736637] [robot_state_publisher]: got segment left_passivewheel_link
      [robot_state_publisher-1] [INFO] [1740989237.394743760] [robot_state_publisher]: got segment left_wheel_link
      [robot_state_publisher-1] [INFO] [1740989237.394751414] [robot_state_publisher]: got segment right_passivewheel_link
      [robot_state_publisher-1] [INFO] [1740989237.394759199] [robot_state_publisher]: got segment right_wheel_link
      [robot_state_publisher-1] [INFO] [1740989237.394766322] [robot_state_publisher]: got segment trackleft_link
      [robot_state_publisher-1] [INFO] [1740989237.394773235] [robot_state_publisher]: got segment trackright_link
      [joint_state_publisher-5] [INFO] [1740989237.619566241] [joint_state_publisher]: Waiting for robot_description to be published on the robot_description topic...
      [gzclient-3]
      [gzserver-2]
      [spawn_entity.py-4] [INFO] [1740989237.756249140] [spawn_entity]: Spawn Entity started
      [spawn_entity.py-4] [INFO] [1740989237.757216273] [spawn_entity]: Loading entity published on topic /robot_description
      [spawn_entity.py-4] /opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/qos.py:307: UserWarning: DurabilityPolicy.RMW_QOS_POLICY_DURABILITY_TRANSIENT_LOCAL is deprecated. Use DurabilityPolicy.TRANSIENT_LOCAL instead.
      [spawn_entity.py-4]   warnings.warn(
      [spawn_entity.py-4] [INFO] [1740989237.760391988] [spawn_entity]: Waiting for entity xml on /robot_description
      [spawn_entity.py-4] [INFO] [1740989237.776414899] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30
      [spawn_entity.py-4] [INFO] [1740989237.777898892] [spawn_entity]: Waiting for service /spawn_entity
      [spawn_entity.py-4] [INFO] [1740989238.950572748] [spawn_entity]: Calling service /spawn_entity
      [gzclient-3] [Msg] Publicized address: 192.168.142.134
      [gzclient-3] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/chen/Program/test_car/test_car_ws/install/car_description/share/ament_index"
      [gzclient-3] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/chen/Program/test_car/test_car_ws/install/car_description/share/car_description"
      [gzclient-3] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/chen/Program/test_car/test_car_ws/install/car_description/share/colcon-core"
      [gzclient-3] [Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
      [gzserver-2] [INFO] [1740989239.759986464] [depth_camera]: Publishing camera info to [/camera_sensor/camera_info]
      [gzserver-2] [INFO] [1740989239.761402219] [depth_camera]: Publishing depth camera info to [/camera_sensor/depth/camera_info]
      [gzserver-2] [INFO] [1740989239.762138249] [depth_camera]: Publishing pointcloud to [/camera_sensor/points]
      [spawn_entity.py-4] [INFO] [1740989239.960007971] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [track_car]
      [INFO] [spawn_entity.py-4]: process has finished cleanly [pid 7382]
      [ERROR] [gzserver-2]: process has died [pid 7378, exit code -11, cmd 'gzserver /home/chen/Program/test_car/test_car_ws/install/car_description/share/car_description/world/custom_room.world --verbose -slibgazebo_ros_init.so -slibgazebo_ros_factory.so -slibgazebo_ros_force_system.so'].![c71b22a7-9992-42ee-af85-9d8884b31d04-image.png](/forum/assets/uploads/files/1740989965076-c71b22a7-9992-42ee-af85-9d8884b31d04-image-resized.png)
      应该和Missing model.config没有关系,如果不添加激光雷达插件gazebo就不会崩溃,但是有时候又有激光雷达插件又能够成功运行,激光插件也生效,不会有这一条报错
      [ERROR] [gzserver-2]: process has died [pid 7378, exit code -11, cmd 'gzserver /home/chen/Program/test_car/test_car_ws/install/car_description/share/car_description/world/custom_room.world --verbose -slibgazebo_ros_init.so -slibgazebo_ros_factory.so -slibgazebo_ros_force_system.so'].![68844488-1db3-4e60-946e-95ba3d91dcc8-image.png](/forum/assets/uploads/files/1740990171863-68844488-1db3-4e60-946e-95ba3d91dcc8-image-resized.png)
      以下是添加及激光雷达传感器的详细代码
      <gazebo reference="laser_link"> -->
               <sensor name="laserscan" type="ray"> -->
                       <ros>
                           <namespace>laser</namespace>
                       </ros>
                       <topic_name>scan</topic_name>
                   </plugin>
                   <always_on>true</always_on>
                   <visualize>true</visualize>
                   <update_rate>30</update_rate>
                   <pose>0 0 0 0 0 0</pose>
                   <ray>
                       <scan>
                           <horizontal>
                               <samples>360</samples>
                               <resolution>1.000000</resolution>
                           </horizontal>
                       </scan>
                       <range>
                           <min>0.120000</min>
                           <max>8.0</max>
                           <resolution>0.1000</resolution>
                       </range>
                       <noise>
                           <type>gaussian</type>
                           <mean>0.0</mean>
                           <stddev>0.01</stddev>
                       </noise>
                   </ray>
               </sensor>
           </gazebo>
        从你提供的日志和配置信息来看,有几个可能的原因导致添加激光雷达插件后Gazebo崩溃:
        1. 插件版本不兼容:
          • 你使用的Gazebo版本是11.10.2,而ROS 2 Humble通常与Gazebo 11的更新版本或者Gazebo 12更兼容。请确认libgazebo_ros_ray_sensor.so插件是否是为你的Gazebo版本编译的。如果插件是为不同版本的Gazebo编译的,它可能会导致崩溃。
        2. 内存或资源限制:
          • 激光雷达传感器配置为高分辨率(360个样本),这在某些系统上可能会消耗大量资源。尝试减少样本数量或降低更新频率,看看是否能稳定运行。
        3. 错误的XML配置:
          • 你的XML配置看起来是格式正确的,但有时候细微的错误或者缺失的标签也可能导致问题。确保所有的标签都正确闭合,并且没有多余的字符或格式错误。
        4. 其他插件或软件冲突:
          • 检查是否有其他插件或软件包与激光雷达插件冲突。例如,其他传感器插件或物理引擎插件可能与激光雷达插件不兼容。
        5. 日志中的警告和错误:
          • 日志中提到的关于model.config的错误通常与模型文件无关,但它们可能是由于环境设置不当或路径问题导致的。确保所有相关的路径和环境变量都设置正确。
          • Deleting a connection right after creation警告可能指示某个组件在初始化后立即被销毁,这可能是由插件或Gazebo内部的bug引起的。
        6. 调试步骤:
          • 增加日志级别:尝试在启动Gazebo时增加日志级别,以获取更详细的错误信息。可以通过在启动命令中添加--verbose标志来实现。
          • 使用GDB调试:如果可能,使用GDB或其他调试工具来运行gzserver,以便在崩溃时获取堆栈跟踪。这可以帮助确定是哪一行代码导致了崩溃。
          • 简化配置:尝试移除或简化其他非必要的传感器或组件,以确定是否其他组件干扰了激光雷达插件。
        7. 更新或回退软件:
          • 考虑更新Gazebo到一个与ROS 2 Humble更兼容的版本,或者如果当前版本是最新的,尝试回退到之前的稳定版本。
        通过这些步骤,你应该能够更接近确定导致问题的根本原因,并找到解决方案。如果问题依旧存在,可能需要更深入地查看具体的插件代码或寻求来自Gazebo或ROS社区的帮助。
          2118561423 @小伊
          @小伊 gazebo11.10.2库里有libgazebo_ros_ray_sensor.so这个动态链接库,我尝试过把采样频率降低,但是还是经常崩溃
            针对您提到的Gazebo 11.10.2中libgazebo_ros_ray_sensor.so动态链接库导致的崩溃问题,尽管降低采样频率可能有助于减轻系统负载,但显然这并不是一个根本的解决方案。以下是一些建议,希望能帮助您解决这个问题:
            1. 检查依赖关系:
              • 确保所有必要的依赖库都已正确安装,并且与Gazebo 11.10.2版本兼容。
              • 使用包管理器(如apt-get)检查并安装任何缺失的依赖项。
            2. 更新和修补:
              • 检查是否有可用的Gazebo更新或补丁,这些更新可能修复了与libgazebo_ros_ray_sensor.so相关的已知问题。
              • 访问Gazebo的官方GitHub仓库或相关论坛,了解是否有其他用户报告了类似问题以及可能的解决方案。
            3. 资源限制:
              • 监控Gazebo运行时的CPU和内存使用情况,确保系统资源不是导致崩溃的原因。
              • 如果资源使用接近极限,考虑增加硬件资源或优化仿真设置。
            4. 日志和调试:
              • 查看Gazebo的日志文件,了解崩溃前后的系统状态和错误信息。
              • 使用调试工具(如gdb)对Gazebo进行调试,以获取更详细的崩溃信息。
            5. 配置和环境:
              • 检查Gazebo的配置文件,确保所有设置都是正确的,特别是与传感器和仿真环境相关的设置。
              • 确保Gazebo运行在一个稳定且配置正确的ROS环境中。
            6. 社区和论坛:
              • 访问ROS和Gazebo的社区论坛,寻求其他用户的帮助和建议。
              • 分享您的崩溃日志和配置文件,以便其他用户能更好地理解问题并提供帮助。
            7. 考虑替代方案:
              • 如果问题持续存在,考虑使用其他版本的Gazebo或不同的传感器插件。
              • 评估其他仿真平台或工具是否更适合您的需求。
            请注意,由于Gazebo是一个复杂的仿真环境,崩溃问题可能由多种因素引起。因此,解决这类问题可能需要一些时间和耐心。在尝试上述建议时,请确保您有足够的系统备份和恢复计划,以防万一出现不可预见的问题。
              尝试了几次后,现在直接gazebo直接卡在启动界面了,日志也和之前有一些不一样
              chen@chen-virtual-machine:~/Program/test_car/test_car_ws$ colcon build
              Starting >>> car_description
              Finished <<< car_description [0.14s]
              Summary: 1 package finished [0.41s]
              chen@chen-virtual-machine:~/Program/test_car/test_car_ws$ sourec install/setup.bash
              sourec:未找到命令
              chen@chen-virtual-machine:~/Program/test_car/test_car_ws$ source install/setup.bash
              [INFO] [launch]: All log files can be found below /home/chen/.ros/log/2025-03-03-17-59-07-717052-chen-virtual-machine-3873
              [INFO] [robot_state_publisher-1]: process started with pid [3875]
              [INFO] [gzserver-2]: process started with pid [3877]
              [INFO] [gzclient-3]: process started with pid [3879]
              [INFO] [spawn_entity.py-4]: process started with pid [3881]
              [INFO] [joint_state_publisher-5]: process started with pid [3883]
              [robot_state_publisher-1] [INFO] [1740995948.251949005] [robot_state_publisher]: got segment base_footprint_link
              [robot_state_publisher-1] [INFO] [1740995948.252182270] [robot_state_publisher]: got segment base_link
              [robot_state_publisher-1] [INFO] [1740995948.252193030] [robot_state_publisher]: got segment base_up_link
              [robot_state_publisher-1] [INFO] [1740995948.252199152] [robot_state_publisher]: got segment camera_link
              [robot_state_publisher-1] [INFO] [1740995948.252204201] [robot_state_publisher]: got segment camera_optical_link
              [robot_state_publisher-1] [INFO] [1740995948.252208950] [robot_state_publisher]: got segment holderfirst_link
              [robot_state_publisher-1] [INFO] [1740995948.252213339] [robot_state_publisher]: got segment holderfourth_link
              [robot_state_publisher-1] [INFO] [1740995948.252217807] [robot_state_publisher]: got segment holdersecond_link
              [robot_state_publisher-1] [INFO] [1740995948.252222276] [robot_state_publisher]: got segment holderthird_link
              [robot_state_publisher-1] [INFO] [1740995948.252226634] [robot_state_publisher]: got segment imu_link
              [robot_state_publisher-1] [INFO] [1740995948.252231133] [robot_state_publisher]: got segment laser_link
              [robot_state_publisher-1] [INFO] [1740995948.252235581] [robot_state_publisher]: got segment left_passivewheel_link
              [robot_state_publisher-1] [INFO] [1740995948.252240491] [robot_state_publisher]: got segment left_wheel_link
              [robot_state_publisher-1] [INFO] [1740995948.252245310] [robot_state_publisher]: got segment right_passivewheel_link
              [robot_state_publisher-1] [INFO] [1740995948.252249748] [robot_state_publisher]: got segment right_wheel_link
              [robot_state_publisher-1] [INFO] [1740995948.252254016] [robot_state_publisher]: got segment trackleft_link
              [robot_state_publisher-1] [INFO] [1740995948.252258305] [robot_state_publisher]: got segment trackright_link
              [gzclient-3]
              [joint_state_publisher-5] [INFO] [1740995948.506909023] [joint_state_publisher]: Waiting for robot_description to be published on the robot_description topic...
              [gzserver-2]
              [spawn_entity.py-4] [INFO] [1740995948.620220423] [spawn_entity]: Spawn Entity started
              [spawn_entity.py-4] [INFO] [1740995948.622548963] [spawn_entity]: Loading entity published on topic /robot_description
              [spawn_entity.py-4] [INFO] [1740995948.627491577] [spawn_entity]: Waiting for entity xml on /robot_description
              [spawn_entity.py-4] [INFO] [1740995948.644838611] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30
              [spawn_entity.py-4] [INFO] [1740995948.645381787] [spawn_entity]: Waiting for service /spawn_entity
              [spawn_entity.py-4] [INFO] [1740995949.403105183] [spawn_entity]: Calling service /spawn_entity
              [gzserver-2] [INFO] [1740995950.186192323] [depth_camera]: Publishing camera info to [/camera_sensor/camera_info]
              [gzserver-2] [INFO] [1740995950.187911694] [depth_camera]: Publishing depth camera info to [/camera_sensor/depth/camera_info]
              [gzserver-2] [INFO] [1740995950.189006163] [depth_camera]: Publishing pointcloud to [/camera_sensor/points]
              [spawn_entity.py-4] [INFO] [1740995950.305917939] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [track_car]
              [INFO] [spawn_entity.py-4]: process has finished cleanly [pid 3881]
              [gzclient-3] [Err] [Connection.cc:547] Connection[17] Closed during Read
              [gzclient-3] [Err] [TransportIface.cc:385] Unable to read from master
              [ERROR] [gzserver-2]: process has died [pid 3877, exit code -11, cmd 'gzserver /home/chen/Program/test_car/test_car_ws/install/car_description/share/car_description/world/custom_room.world --verbose -slibgazebo_ros_init.so -slibgazebo_ros_factory.so -slibgazebo_ros_force_system.so'].
              [gzclient-3] [Err] [GLWidget.cc:900] Unable to connect to a running Gazebo master.
              [gzclient-3] [Wrn] [Publisher.cc:135] Queue limit reached for topic /gazebo/default/user_camera/pose, deleting message. This warning is printed only once.
              [robot_state_publisher-1] [INFO] [1740996081.753914506] [rclcpp]: signal_handler(signum=2)
              [INFO] [robot_state_publisher-1]: process has finished cleanly [pid 3875]
              [INFO] [joint_state_publisher-5]: process has finished cleanly [pid 3883]
              [INFO] [gzclient-3]: process has finished cleanly [pid 3879]
              [gzclient-3]
              [gzclient-3]
              但是一移除激光雷达插件又能正常启动
