    9.2.1平台安装问题
    安装出错 安装失败了 真实小车
    5.8k
      1117 年度VIP @1117
      @1117 6a3bde78-f5a3-4951-b8cd-4adce9cf5ee8-image.png 一直卡在这里,最后也无法编译成功
        1117 年度VIP @1117
        @1117 Resolving fishbot dependencies...
        Platform Manager: Installing espressif32
        HTTPClientError:
        会出现这个
        小鱼小 1 3 条回复 最后回复 回复 引用 0
          小鱼 技术大佬 @1117
          @1117 换个网络,或者搞个代理
            1117 年度VIP @小鱼
            @小鱼 87f0bf8d-7fc7-4309-8ecf-f465ca0221a3-image.png 鱼哥,我重新试了n次,最后变成这样子了,这样子对吗?
              1117 年度VIP @1117
              @1117 * 正在执行任务: platformio run --target upload
              Processing fishbot (platform: espressif32; board: esp32dev; framework: arduino)
              Verbose mode can be enabled via -v, --verbose option
              CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32dev.html
              PLATFORM: Espressif 32 (6.10.0) > Espressif ESP32 Dev Module
              PACKAGES:
              • framework-arduinoespressif32 @ 3.20017.241212+sha.dcc1105b
              • tool-esptoolpy @ 1.40501.0 (4.5.1)
              • tool-mkfatfs @ 2.0.1
              • tool-mklittlefs @ 1.203.210628 (2.3)
              • tool-mkspiffs @ 2.230.0 (2.30)
              • toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
                Found 33 compatible libraries
                Scanning dependencies...
                No dependencies
                Building in release mode
                Retrieving maximum program size .pio/build/fishbot/firmware.elf
                Checking size .pio/build/fishbot/firmware.elf
                Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
                RAM: [= ] 6.6% (used 21464 bytes from 327680 bytes)
                Flash: [== ] 20.4% (used 267001 bytes from 1310720 bytes)
                Configuring upload protocol...
                AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
                CURRENT: upload_protocol = esptool
                Looking for upload port...
              Warning! Please install 99-platformio-udev.rules.
              More details: https://docs.platformio.org/en/latest/core/installation/udev-rules.html
              Auto-detected: /dev/ttyUSB0
              Uploading .pio/build/fishbot/firmware.bin
              esptool.py v4.5.1
              Serial port /dev/ttyUSB0
              A fatal error occurred: Could not open /dev/ttyUSB0, the port doesn't exist
              *** [upload] Error 2
              ======================================== [FAILED] Took 4.12 seconds ========================================
              • 终端进程“platformio 'run', '--target', 'upload'”已终止,退出代码: 1。
              • 终端将被任务重用,按任意键关闭。 鱼哥,我烧录的时候遇到这个是什么问题呀?我有识别到端口85527d0d-d4d0-45eb-ac93-5d8c15de1d09-image.png
                1117 年度VIP @1117
                @1117 b3dda13a-f8f8-4eae-99b9-9964200e47c7-image.png 这边显示又无法打开,然后我又多次给串口权限fcfccc56-a6dd-4f2e-a72a-11c3787dd63d-image.png ,然后这样子显示,鱼哥,俺有点儿迷惑
                小鱼小 1 2 条回复 最后回复 回复 引用 0
                  小鱼 技术大佬 @1117
                  @1117 看视频教程,都有讲,下载的时候不能打开串口监视器
                    1117 年度VIP @1117
                    @1117 鱼哥,为什么有时候可以有时候不可以!我也找了不同代理还换了网络,就是克隆不下来,上一个视频的倒是克隆下来了,这是怎么回事呢?
                      小鱼 技术大佬 @1117
                      @1117 刚check了下,代理网络是正常的 http://github.fishros.org/ 您那边再看下
                        1117 年度VIP @1117
                        @1117 谢谢鱼哥,但是很疑惑的一点就是我用你的那个代理也不能克隆下来,但是有时候又是可以的,然后,下载MicroROS-Agentd的时候!这个样子9c6cab80-4055-4c13-917e-dd3fd6cf2639-image.png ,后面我在主机下去下载,然后,复制到工作空间的src下面,如下所示bbfdf6f5-2521-49da-9aab-c7772910ea7c-image.png ,后面我解压后,然后colcon build 显示b5be3862-0037-4673-b3b7-a213f221a79c-image.png ,鱼哥,俺现在十分困惑,不理解
                          1117 年度VIP @小鱼
                          @小鱼 abbc05cf-278a-412b-915a-254ac239e9db-image.png 我把你的dai'li代理那个删了然后可以克隆,但是后面colcon build 显示这个是怎么回事呀?鱼哥
