    一键安装ROS1 noetic失败
    一键安装 noetic ubuntu20.04
    2.5k
    • 15639888411
      笑嘻嘻
      一键安装ROS1 noetic失败,我是虚拟机VMware17,Ubuntu20.04,已经换源了,前面都很顺利,到这里突然就报错了。咋回事呢。求大佬指点。
        1335504328 @1563988841
        @1563988841 解决了吗佬
        • Z
          zxz0123
          同样错误,使用fishros脚本肯定搞不定了,下面是我手工安装的过程,供参考:
          1735 wget http://fishros.com/install -O fishros
          1736 ls
          1737 cat fishros
          1738 sudo apt update && sudo apt install curl gnupg2 lsb-release
          1739 curl -s https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc | sudo apt-key add -
          1740 cd /etc/apt/
          1741 ls
          1742 cd sources.list.d/
          1743 ls
          1744 cat ros-fish.list
          1745 sudo mv ros-fish.list ros-latest.list
          1746 sudo apt update
          1747 sudo apt install ros-noetic-desktop-full
          1748 sudo apt remove --purge ros-noetic-*
          1749 sudo apt autoremove
          1750 sudo apt clean
          1751 sudo apt update
          1752 sudo apt --fix-broken install
          1753 sudo apt dist-upgrade
          1754 sudo apt install ros-noetic-ros-base
          1755 sudo apt install ros-noetic-desktop ros-noetic-ros-base ros-noetic-perception
          1756 sudo apt install ros-noetic-simulators ros-noetic-urdf-sim-tutorial
          1757 sudo apt install ros-noetic-actionlib
          1758 sudo apt install libboost-dev
          1759 sudo apt install libboost1.71-dev
          1760 sudo apt install libstdc++-dev
          1761 sudo apt-get install aptitude
          1762 sudo aptitude install ros-noetic-ros-base
          1763 sudo sh -c '. /etc/lsb-release && echo "deb http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu/ lsb_release -cs main" > /etc/apt/sources.list.d/ros-latest.list'
          1764 sudo apt update
          1765 echo "deb http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu/ lsb_release -cs main"
          1766 echo "deb http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu/ $lsb_release -cs main"
          1767 lsb_release
          1768 sudo sh -c '. /etc/lsb-release && echo "deb http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu/ lsb_release -cs main" > /etc/apt/sources.list.d/ros-latest.list'
          1769 sudo apt update
          1770 sudo apt install ros-noetic-desktop-full
          1771 cd
          1772 sudo apt update
          1773 sudo apt upgrade
          1774 sudo apt --fix-broken install
          1775 sudo apt autoremove
          1776 sudo apt clean
          1777 sudo apt autoclean
          1778 sudo apt install aptitude
          1779 sudo aptitude install ros-noetic-desktop-full
          1780 rosversion roslaunch
          1781 sudo rosdep init
          1782 sudo rm /etc/ros/rosdep/sources.list.d/20-default.list
          1783 sudo rosdep init
          1784 rosdep update
          1785 /bin/zsh
          1786 docker ps -a
          1787 roscore
          1788 rosdep update
