    使用雷达建图的时候,rviz2指令使用的时候出现问题,无法点云可视化
    点云 可视化 无法显示
    1.1k
      1117 年度VIP
        小鱼 技术大佬 @1117
        @1117 看视频,记得改QOS
          1117 年度VIP @小鱼
          @小鱼 li@ubantu:~/navigation_project/bot_ws$ ros2 launch ydlidar ydlidar_launch.py
          [INFO] [launch]: All log files can be found below /home/li/.ros/log/2025-04-28-00-24-59-566567-ubantu-13361
          [INFO] [ydlidar_node-1]: process started with pid [13372]
          [ydlidar_node-1] [INFO] [1745771099.897824559] [ydlidar_node]: [YDLIDAR INFO] Current ROS Driver Version: 1.0.1
          [ydlidar_node-1]
          [ydlidar_node-1] [2025-04-28 00:24:59][info] SDK initializing
          [ydlidar_node-1] [2025-04-28 00:24:59][info] SDK has been initialized
          [ydlidar_node-1] [2025-04-28 00:24:59][info] SDK Version: 1.2.9
          [ydlidar_node-1] [2025-04-28 00:25:00][info] Connect elapsed time 667 ms
          [ydlidar_node-1] [2025-04-28 00:25:00][info] Lidar successfully connected [/dev/ttyUSB0:115200]
          [ydlidar_node-1] [2025-04-28 00:25:00][info] Lidar running correctly! The health status good
          [ydlidar_node-1] [2025-04-28 00:25:00][info] Current Lidar Model Code 12
          [ydlidar_node-1] [2025-04-28 00:25:00][info] Check status, Elapsed time 0 ms
          [ydlidar_node-1] [2025-04-28 00:25:00][info] Lidar init success, Elapsed time [667]ms
          [ydlidar_node-1] [2025-04-28 00:25:01][info] Start to getting intensity flag
          [ydlidar_node-1] [2025-04-28 00:25:01][info] Auto set intensity 0
          [ydlidar_node-1] [2025-04-28 00:25:01][info] [YDLIDAR] End to getting intensity flag
          [ydlidar_node-1] [2025-04-28 00:25:01][info] [YDLIDAR] Create thread 0xA1200640
          [ydlidar_node-1] [2025-04-28 00:25:02][info] Successed to start scan mode, Elapsed time 1669 ms
          [ydlidar_node-1] [2025-04-28 00:25:02][info] Scan Frequency: 5.00Hz
          [ydlidar_node-1] [2025-04-28 00:25:02][info] Fixed Size: 720
          [ydlidar_node-1] [2025-04-28 00:25:02][info] Sample Rate: 3.00K
          [ydlidar_node-1] [2025-04-28 00:25:02][info] Single Fixed Size: 380
          [ydlidar_node-1] [2025-04-28 00:25:02][info] Successed to check the lidar, Elapsed time 490 ms
          [ydlidar_node-1] [2025-04-28 00:25:02][info] Now lidar is scanning...
          [ydlidar_node-1] [2025-04-28 00:25:06][error] Check Sum 0x5B12 != 0x1D35
          [ydlidar_node-1] [2025-04-28 00:25:23][error] Check Sum 0xDC68 != 0xD37E
          [ydlidar_node-1] [2025-04-28 00:25:32][error] Check Sum 0x4BC3 != 0x6911
          [ydlidar_node-1] [2025-04-28 00:25:34][error] Check Sum 0x85A4 != 0x903A
          [ydlidar_node-1] [2025-04-28 00:26:33][error] Check Sum 0x4436 != 0x582E
          [ydlidar_node-1] [2025-04-28 00:26:52][error] Check Sum 0x4E82 != 0x5608
          鱼哥,还是存在这个问题唉,如何我用命令看Qos,但是还是不知道为什么唉
          li@ubantu:~/navigation_project/bot_ws$ ros2 topic info /scan -v
          Type: sensor_msgs/msg/LaserScan
          Publisher count: 1
          Node name: ydlidar_node
          Node namespace: /
          Topic type: sensor_msgs/msg/LaserScan
          Endpoint type: PUBLISHER
          GID: 01.0f.85.ec.3c.34.dc.ed.00.00.00.00.00.00.12.03.00.00.00.00.00.00.00.00
          QoS profile:
          Reliability: BEST_EFFORT
          History (Depth): UNKNOWN
          Durability: VOLATILE
          Lifespan: Infinite
          Deadline: Infinite
          Liveliness: AUTOMATIC
          Subscription count: 0
          如何建图还是不行,找不到地图数据,我应该怎么办呢?怪焦虑的,我用的是树莓派4b加上小鱼你的二驱车。
            小鱼 技术大佬 @1117
            @1117 里程计话题是否正常
