    换源更新失败
    一键安装 apt更新失败 后续程序可能会继续尝试 [\n
    • 11833285101
      西奥多
      [-]Result:success
      The following signatures couldn't be verified because the public key is not[|] The following signatures couldn't be verified because the public key is not[-]Result:code:100
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', '\n', "(appstreamcli:9296): GLib-CRITICAL **: 22:48:48.089: g_variant_builder_end: assertion '!GVSB(builder)->uniform_item_types || GVSB(builder)->prev_item_type != NULL || g_variant_type_is_definite (GVSB(builder)->type)' failed\n", '\n', "(appstreamcli:9296): GLib-CRITICAL **: 22:48:48.089: g_variant_new_variant: assertion 'value != NULL' failed\n", '\n', '(appstreamcli:9296): GLib-ERROR **: 22:48:48.089: g_variant_new_parsed: 11-13:invalid GVariant format string\n', 'Trace/breakpoint trap (core dumped)\n', "W: GPG error: http://packages.ros.org/ros/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F42ED6FBAB17C654\n", "E: The repository 'http://packages.ros.org/ros/ubuntu bionic InRelease' is not signed.\n", "W: GPG error: http://packages.ros.org/ros2/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F42ED6FBAB17C654\n", "E: The repository 'http://packages.ros.org/ros2/ubuntu bionic InRelease' is not signed.\n", "E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/cache/app-info -a -e /usr/bin/appstreamcli; then appstreamcli refresh-cache > /dev/null; fi'\n", 'E: Sub-process returned an error code\n']
      根据您的系统,为您推荐安装源为['https://packages.ros.org/ros/ubuntu/', 'https://packages.ros.org/ros2/ubuntu/']
      [-]Result:success
      [/] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected. Could not handshake: Error in th[|] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected. Could not handshake: Error in th[-]Result:code:100 0 443]
      检测到发生证书校验错误['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', '\n', "(appstreamcli:9595): GLib-CRITICAL **: 22:48:56.780: g_variant_builder_end: assertion '!GVSB(builder)->uniform_item_types || GVSB(builder)->prev_item_type != NULL || g_variant_type_is_definite (GVSB(builder)->type)' failed\n", '\n', "(appstreamcli:9595): GLib-CRITICAL **: 22:48:56.780: g_variant_new_variant: assertion 'value != NULL' failed\n", '\n', '(appstreamcli:9595): GLib-ERROR **: 22:48:56.780: g_variant_new_parsed: 11-13:invalid GVariant format string\n', 'Trace/breakpoint trap (core dumped)\n', "E: The repository 'https://packages.ros.org/ros/ubuntu bionic Release' does not have a Release file.\n", "E: The repository 'https://packages.ros.org/ros2/ubuntu bionic Release' does not have a Release file.\n", "E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/cache/app-info -a -e /usr/bin/appstreamcli; then appstreamcli refresh-cache > /dev/null; fi'\n", 'E: Sub-process returned an error code\n'],自动取消https校验,如有需要请手动删除:rm /etc/apt/apt.conf.d/99verify-peer.conf
      [-]Result:success
      Run CMD Task:[echo "Acquire { https::Verify-Peer false }" > /etc/apt/apt.conf.d/99verify-peer.conf]
      [-]Result:success
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', '\n', "(appstreamcli:9999): GLib-CRITICAL **: 22:49:09.331: g_variant_builder_end: assertion '!GVSB(builder)->uniform_item_types || GVSB(builder)->prev_item_type != NULL || g_variant_type_is_definite (GVSB(builder)->type)' failed\n", '\n', "(appstreamcli:9999): GLib-CRITICAL **: 22:49:09.331: g_variant_new_variant: assertion 'value != NULL' failed\n", '\n', '(appstreamcli:9999): GLib-ERROR **: 22:49:09.331: g_variant_new_parsed: 11-13:invalid GVariant format string\n', 'Trace/breakpoint trap (core dumped)\n', "W: GPG error: https://packages.ros.org/ros/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F42ED6FBAB17C654\n", "E: The repository 'https://packages.ros.org/ros/ubuntu bionic InRelease' is not signed.\n", "W: GPG error: https://packages.ros.org/ros2/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F42ED6FBAB17C654\n", "E: The repository 'https://packages.ros.org/ros2/ubuntu bionic InRelease' is not signed.\n", "E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/cache/app-info -a -e /usr/bin/appstreamcli; then appstreamcli refresh-cache > /dev/null; fi'\n", 'E: Sub-process returned an error code\n']
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', '\n', "(appstreamcli:10415): GLib-CRITICAL **: 22:49:17.813: g_variant_builder_end: assertion '!GVSB(builder)->uniform_item_types || GVSB(builder)->prev_item_type != NULL || g_variant_type_is_definite (GVSB(builder)->type)' failed\n", '\n', "(appstreamcli:10415): GLib-CRITICAL **: 22:49:17.813: g_variant_new_variant: assertion 'value != NULL' failed\n", '\n', '(appstreamcli:10415): GLib-ERROR **: 22:49:17.813: g_variant_new_parsed: 11-13:invalid GVariant format string\n', 'Trace/breakpoint trap (core dumped)\n', "W: GPG error: https://packages.ros.org/ros/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F42ED6FBAB17C654\n", "E: The repository 'https://packages.ros.org/ros/ubuntu bionic InRelease' is not signed.\n", "W: GPG error: https://packages.ros.org/ros2/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F42ED6FBAB17C654\n", "E: The repository 'https://packages.ros.org/ros2/ubuntu bionic InRelease' is not signed.\n", "E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/cache/app-info -a -e /usr/bin/appstreamcli; then appstreamcli refresh-cache > /dev/null; fi'\n", 'E: Sub-process returned an error code\n']
      四次换源后都失败了,请及时联系小鱼获取解决方案并处理!
      [-]Result:code:2
      [-]Result:code:2
      小鱼小 1 条回复 最后回复 回复 引用 1
        小鱼 技术大佬 @1183328510
        @1183328510 在 换源更新失败 中说:
        注意这里
        @小鱼 在 一键安装遇到NO_PUBKEY错误该怎么办? 中说:
        答案就是手动的添加KEY
        比如说缺少DCC9EFBF77E11517,用下面的这句话
        sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys DCC9EFBF77E11517
        根据你的错误提示,可劲的添加吧
