    tf2转换关系建立成功,报错Could not transform base_link to lidar_mid: "base_link" passed to lookupTransform argument target_frame does not exist
    ros2tf2转换关系 lookuptransform
    • 10764322461
      噢勒
      Screenshot 2023-03-02 14:22:37.png Screenshot 2023-03-02 14:23:43.png
      这样定义的,每次就到catch了
      Screenshot from 2023-03-02 14-27-04.png Screenshot from 2023-03-02 14-27-19.png
      看结果就这样的
        小鱼 技术大佬 @1076432246
        @1076432246 请复制粘贴
        问题一定要描述清楚,终端打印一定复制粘贴,方便回答者检索和引用(你可以在linux系统上打开浏览器进社区
        10764322461 2 条回复 最后回复 回复 引用 0
        • 10764322461
          噢勒 @小鱼
          @小鱼 好的鱼哥
          std::unique_ptr<tf2_ros::Buffer> base_link_lidar_mid_tf_buffer_;
          std::shared_ptr<tf2_ros::TransformListener> base_link_lidar_mid_tf_listener_{nullptr};
          bool base_link_lidar_mid_transform_flag = false;
          tf2::Stampedtf2::Transform base_link_lidar_mid_transform;
          geometry_msgs::msg::TransformStamped tfGeom_lidar_mid;
          base_link_lidar_mid_tf_buffer_ =
          std::make_unique<tf2_ros::Buffer>(this->get_clock());
          // Buffer::lookupTransform(const std::string& target_frame, const std::string& source_frame, const ros::Time& time, const ros::Duration timeout)
          base_link_lidar_mid_tf_listener_ =
          std::make_shared<tf2_ros::TransformListener>(
          *base_link_lidar_mid_tf_buffer_);
          if (!base_link_lidar_mid_transform_flag)
          try {
          tfGeom_lidar_mid = base_link_lidar_mid_tf_buffer_->lookupTransform(
          "base_link", "lidar_mid", tf2::TimePointZero);
          base_link_lidar_mid_transform_flag = true;
          catch (const tf2::TransformException &ex) {
          RCLCPP_INFO(this->get_logger(), "Could not transform %s to %s: %s",
          "base_link", "lidar_mid", ex.what());
          tf2::convert(tfGeom_lidar_mid, base_link_lidar_mid_transform);
          • 10764322461
            噢勒 @小鱼
            @小鱼 鱼哥 这是终端打印的
            [Sensors_Fusion_node-1] [INFO] [1677828330.587144345] [Sensors_Fusion_node]: Could not transform base_link to lidar_mid: "base_link" passed to lookupTransform argument target_frame does not exist.
            [Sensors_Fusion_node-1] [INFO] [1677828331.585971687] [Sensors_Fusion_node]: Could not transform base_link to lidar_mid: "base_link" passed to lookupTransform argument target_frame does not exist.
            [Sensors_Fusion_node-1] [INFO] [1677828332.586446715] [Sensors_Fusion_node]: Could not transform base_link to lidar_mid: "base_link" passed to lookupTransform argument target_frame does not exist.
            [Sensors_Fusion_node-1] [INFO] [1677828333.585558863] [Sensors_Fusion_node]: Could not transform base_link to lidar_mid: "base_link" passed to lookupTransform argument target_frame does not exist.
            [Sensors_Fusion_node-1] [INFO] [1677828334.586966889] [Sensors_Fusion_node]: Could not transform base_link to lidar_mid: "base_link" passed to lookupTransform argument target_frame does not exist.
            [Sensors_Fusion_node-1] [INFO] [1677828335.586095871] [Sensors_Fusion_node]: Could not transform base_link to lidar_mid: "base_link" passed to lookupTransform argument target_frame does not exist.
            [Sensors_Fusion_node-1] [INFO] [1677828336.586538045] [Sensors_Fusion_node]: Could not transform base_link to lidar_mid: "base_link" passed to lookupTransform argument target_frame does not exist.
            [Sensors_Fusion_node-1] [INFO] [1677828337.587170264] [Sensors_Fusion_node]: Could not transform base_link to lidar_mid: "base_link" passed to lookupTransform argument target_frame does not exist.
            [Sensors_Fusion_node-1] [INFO] [1677828338.587091985] [Sensors_Fusion_node]: Could not transform base_link to lidar_mid: "base_link" passed to lookupTransform argument target_frame does not exist.
            [Sensors_Fusion_node-1] [INFO] [1677828339.585534715] [Sensors_Fusion_node]: Could not transform base_link to lidar_mid: "base_link" passed to lookupTransform argument target_frame does not exist.
            [Sensors_Fusion_node-1] [INFO] [1677828340.585897984] [Sensors_Fusion_node]: Could not transform base_link to lidar_mid: "base_link" passed to lookupTransform argument target_frame does not exist.
            通过 ros2 run tf2_tools view_frames.py
            [INFO] [1677828306.663303521] [view_frames]: Result:tf2_msgs.srv.FrameGraph_Response(frame_yaml="lidar_mid: \n parent: 'base_link'\n broadcaster: 'default_authority'\n rate: 10000.000\n most_recent_transform: 0.000000\n oldest_transform: 0.000000\n buffer_length: 0.000\nfront_mmwave: \n parent: 'base_link'\n broadcaster: 'default_authority'\n rate: 10000.000\n most_recent_transform: 0.000000\n oldest_transform: 0.000000\n buffer_length: 0.000\nrear_mmwave: \n parent: 'base_link'\n broadcaster: 'default_authority'\n rate: 10000.000\n most_recent_transform: 0.000000\n oldest_transform: 0.000000\n buffer_length: 0.000\n")
            ros2 run tf2_ros tf2_echo base_link lidar_mid
            [INFO] [1677828491.273727584] [tf2_echo]: Waiting for transform base_link -> lidar_mid: Invalid frame ID "base_link" passed to canTransform argument target_frame - frame does not exist
            At time 0.0
            • Translation: [0.067, 7.415, 0.490]
            • Rotation: in Quaternion [0.022, -0.020, -0.022, 0.999]
              At time 0.0
              At time 0.0
            与小乌龟的教程都一样 但是就是报这个问题了Could not transform base_link to lidar_mid: "base_link" passed to lookupTransform argument target_frame does not exist;一直进catch
