    arm下一键安装ros出现问题了
    ros一键安装 arm
    1.5k
    • Z
      zyd18342842908
      --2023-03-09 17:44:01-- http://fishros.com/install
      --2023-03-09 17:44:01-- http://fishros.com/install/
      Length: 582 [application/octet-stream]
      Saving to: ‘fishros’
      fishros 100%[============================================>] 582 --.-KB/s in 0s
      2023-03-09 17:44:01 (47.6 MB/s) - ‘fishros’ saved [582/582]
      Reading package lists... Done
      Building dependency tree
      Package python3-distro is not available, but is referred to by another package.
      This may mean that the package is missing, has been obsoleted, or
      is only available from another source
      E: Package 'python3-distro' has no installation candidate
      --2023-03-09 17:44:02-- http://fishros.com/install/install1s/tools/base.py
      Length: 42195 (41K) [application/octet-stream]
      /tmp/fishinstall/tools/base. 100%[============================================>] 41.21K --.-KB/s in 0.1s
      2023-03-09 17:44:02 (335 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [42195/42195]
      [-]Result:success
      基础检查通过...
      ---众多工具,等君来用---
      [6]:一键安装:nodejs
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [77]:测试模式:运行自定义工具测试
      请输入[]内的数字以选择:1
      --2023-03-09 17:44:08-- http://fishros.com/install/install1s/tools/tool_install_ros.py
      /tmp/fishinstall/tools/tool_ 100%[============================================>] 18.60K --.-KB/s in 0.07s
      2023-03-09 17:44:08 (279 KB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [19050/19050]
      --2023-03-09 17:44:08-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
      /tmp/fishinstall/tools/tool_ 100%[============================================>] 2.40K --.-KB/s in 0s
      2023-03-09 17:44:08 (55.8 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2457/2457]
      --2023-03-09 17:44:08-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
      /tmp/fishinstall/tools/tool_ 100%[============================================>] 7.33K --.-KB/s in 0.03s
      2023-03-09 17:44:08 (282 KB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [7511/7511]
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      请输入[]内的数字以选择:1
      欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
      请选择换源方式,如果不知道选什么请选2
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      请输入[]内的数字以选择:2
      [-]Result:success
      删除一个资源文件
      [-]Result:success
      [-]Result:success
      [-]Result:success
      检测到当前系统架构为[arm64:bionic],正在为你更换对应源..
      替换完成,尝试第一次更新....
      [-]Result:code:100 ports bionic-security/multiverse amd64 Packages,886 kB]B]
      更新失败,开始更换导入方式并三次尝试...
      Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9]
      []Executing: /tmp/apt-key-gpghome.AXcRKn6N1o/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1[-]Result:success
      Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys DCC9EFBF77E11517]
      []Executing: /tmp/apt-key-gpghome.VuEeXe7ujU/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys DCC9EFBF77E115[-]Result:success
      Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 54404762BBB6E853]
      []Executing: /tmp/apt-key-gpghome.xjXKKE2LlR/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 54404762BBB6E8[-]Result:success
      Run CMD Task:[apt-get install debian-keyring debian-archive-keyring]
      [-]Result:code:100 has been obsoleted, orother package.
      Run CMD Task:[apt-key update]
      [-]Result:success e Automatic Signing Key (2018) ftpmaster@ubuntu.com" not changed
      [-]Result:code:100 ports bionic-security/multiverse amd64 Packages[1,172 kB]
      如果出现问题NO_PUBKEY XXXXXXXX,请手动运行添加指令:apt-key adv --keyserver keyserver.ubuntu.com --recv-keys XXXXXXXX
      如:error: NO_PUBKEY 0E98404D386FA1D9
      运行指令:sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9
      镜像修复完成.....
      [-]Result:code:100 ports bionic-security/multiverse amd64 Packages3 kB] kB]
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/bionic/main/binary-amd64/Packages 404 Not Found [IP: 202.141.160.110 443]\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/bionic-updates/main/binary-amd64/Packages 404 Not Found [IP: 202.141.160.110 443]\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/bionic-backports/main/binary-amd64/Packages 404 Not Found [IP: 202.141.160.110 443]\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/bionic-security/main/binary-amd64/Packages 404 Not Found [IP: 202.141.160.110 443]\n', 'E: Some index files failed to download. They have been ignored, or old ones used instead.\n']
      [-]Result:success
      [-]Result:code:100 ports bionic-security/multiverse amd64 Packages[18.1 kB]
      []ros-melodic-end-effector - End-Effector package: provides a ROS-based set of standard interfaces to command rob[|]ros-melodic-ros-base - A metapackage which extends ros_core and includes other basic non-robot tools like actio[-]ros-bouncy-ros-base - A package which extends 'ros_core' and includes other basic functionalities like tf2 and [/]ros-crystal-ros-base - A package which extends 'ros_core' and includes other basic functionalities like tf2 and[]ros-dashing-ros-base - A package which extends 'ros_core' and includes other basic functionalities like tf2 and[|]ros-eloquent-ros-base - A package which extends 'ros_core' and includes other basic functionalities like tf2 an[-]Result:success
      [1]:melodic(ROS1)
      [2]:bouncy(ROS2)
      [3]:crystal(ROS2)
      [4]:dashing(ROS2)
      [5]:eloquent(ROS2)
      请输入[]内的数字以选择:1
      请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
      [1]:melodic(ROS1)桌面版
      [2]:melodic(ROS1)基础版(小)
      请输入[]内的数字以选择:1
      [-]Result:success
      File "/tmp/fishinstall/install.py", line 90, in <module>
      self.install_ros()
      for key in dic.keys():
      bash: /opt/ros/melodic/setup.bash: No such file or directory
        小鱼 技术大佬 @zyd18342842908
        @zyd18342842908 在 arm下一键安装ros出现问题了 中说:
        18121332981 1 条回复 最后回复 回复 引用 0
        • 18121332981
          ঞ辰筱 ໌້ᮨ꧔ꦿ᭄ @小鱼
          @小鱼 可能还是不是很懂,会返回“从公钥服务器接收失败,无数据”
            小鱼 技术大佬 @1812133298
            @1812133298 arm下只能装基础版
