键盘控制小车不动
链接小车时收到返回如下
[1684050279.548598] info | UDPv4AgentLinux.cpp | init | running... | port: 8888 [1684050279.549095] info | Root.cpp | set_verbose_level | logger setup | verbose_level: 6 [1684050280.011730] debug | UDPv4AgentLinux.cpp | recv_message | [==>> UDP <<==] | client_key: 0x00000000, len: 24, data: 0000: 80 00 00 00 00 01 10 00 58 52 43 45 01 00 01 0F 12 62 4A A7 81 00 FC 03 [1684050280.011807] info | Root.cpp | create_client | create | client_key: 0x12624AA7, session_id: 0x81 [1684050280.011842] info | SessionManager.hpp | establish_session | session established | client_key: 0x308431527, address: 192.168.0.106:53747 [1684050280.011972] debug | UDPv4AgentLinux.cpp | send_message | [** <<UDP>> **] | client_key: 0x12624AA7, len: 19, data: 0000: 81 00 00 00 04 01 0B 00 00 00 58 52 43 45 01 00 01 0F 00 [1684050280.016867] debug | UDPv4AgentLinux.cpp | recv_message | [==>> UDP <<==] | client_key: 0x12624AA7, len: 56, data: 0000: 81 80 00 00 01 07 2E 00 00 0A 00 01 01 03 00 01 1F 00 00 00 00 01 00 00 17 00 00 00 66 69 73 68 0020: 62 6F 74 5F 6D 6F 74 69 6F 6E 5F 63 6F 6E 74 72 6F 6C 00 79 00 00 73 67可以判断已经连上小车 但是执行命令
ros2 topic echo /odom收到返回
Could not determine the type for the passed topic且小车无法被键盘控制
@2496480233 用的是什么固件,另外 ros2 topic list 结果
@2496480233 micro ros系统用的是latest
@2496480233 ROS 2 版本之间差距很大,这个版本的和后面的已经完全不支持了,请使用ubuntu22.04 humble
我的系统是ubuntu22.04 humble,连接小车后得到的反馈也是这个问题,
运行```
ros2 topic echo /odom pose.pose收到返回The passed message type is invalid
同样小车无法用键盘控制
