    在编译autoware的标定工具箱出现的报错
    标定工具 报错
    • 5
      541477150
      wwt@wwt-B560M-AORUS-PRO-AX:~/CL_calibration_ws$ catkin_make
      Base path: /home/wwt/CL_calibration_ws
      Source space: /home/wwt/CL_calibration_ws/src
      Build space: /home/wwt/CL_calibration_ws/build
      Devel space: /home/wwt/CL_calibration_ws/devel
      Install space: /home/wwt/CL_calibration_ws/install
      #### Running command: "make cmake_check_build_system" in "/home/wwt/CL_calibration_ws/build"
      -- Using CATKIN_DEVEL_PREFIX: /home/wwt/CL_calibration_ws/devel
      -- Using CMAKE_PREFIX_PATH: /opt/ros/melodic
      -- This workspace overlays: /opt/ros/melodic
      -- Found PythonInterp: /usr/bin/python2 (found suitable version "2.7.17", minimum required is "2")
      -- Using PYTHON_EXECUTABLE: /usr/bin/python2
      -- Using Debian Python package layout
      -- Using empy: /usr/bin/empy
      -- Using CATKIN_ENABLE_TESTING: ON
      -- Call enable_testing()
      -- Using CATKIN_TEST_RESULTS_DIR: /home/wwt/CL_calibration_ws/build/test_results
      -- Found gtest sources under '/usr/src/googletest': gtests will be built
      -- Found gmock sources under '/usr/src/googletest': gmock will be built
      CMake Deprecation Warning at /usr/src/googletest/CMakeLists.txt:1 (cmake_minimum_required):
        Compatibility with CMake < 2.8.12 will be removed from a future version of
        CMake.
        Update the VERSION argument <min> value or use a ...<max> suffix to tell
        CMake that the project does not need compatibility with older versions.
      CMake Deprecation Warning at /usr/src/googletest/googlemock/CMakeLists.txt:41 (cmake_minimum_required):
        CMake.
      CMake Deprecation Warning at /usr/src/googletest/googletest/CMakeLists.txt:48 (cmake_minimum_required):
        CMake.
      -- Found PythonInterp: /usr/bin/python2 (found version "2.7.17")
      -- Using Python nosetests: /usr/bin/nosetests-2.7
      -- catkin 0.7.29
      -- BUILD_SHARED_LIBS is on
      -- ~~  traversing 6 packages in topological order:
      -- ~~  - autoware_build_flags
      -- ~~  - ls_calibration (metapackage)
      -- ~~  - glviewer
      -- ~~  - autoware_msgs
      -- ~~  - rosinterface
      -- ~~  - calibration_camera_lidar
      -- +++ processing catkin package: 'autoware_build_flags'
      -- ==> add_subdirectory(ls_calibration/autoware_build_flags)
      CMake Deprecation Warning at ls_calibration/autoware_build_flags/CMakeLists.txt:1 (cmake_minimum_required):
        CMake.
      -- +++ processing catkin metapackage: 'ls_calibration'
      -- ==> add_subdirectory(ls_calibration/ls_calibration)
      CMake Deprecation Warning at ls_calibration/ls_calibration/CMakeLists.txt:1 (cmake_minimum_required):
        CMake.
      -- +++ processing catkin package: 'glviewer'
      -- ==> add_subdirectory(ls_calibration/glviewer)
      CMake Deprecation Warning at ls_calibration/glviewer/CMakeLists.txt:1 (cmake_minimum_required):
        CMake.
      CMake Warning at /opt/ros/melodic/share/cmake_modules/cmake/Modules/FindEigen.cmake:62 (message):
        The FindEigen.cmake Module in the cmake_modules package is deprecated.
        Please use the FindEigen3.cmake Module provided with Eigen.  Change
        instances of find_package(Eigen) to find_package(Eigen3).  Check the
        FindEigen3.cmake Module for the resulting CMake variable names.
        ls_calibration/glviewer/CMakeLists.txt:15 (find_package)
      -- Eigen found (include: /usr/local/include/eigen3)
      CMake Warning (dev) at /usr/local/share/cmake-3.20/Modules/FindOpenGL.cmake:315 (message):
        Policy CMP0072 is not set: FindOpenGL prefers GLVND by default when
        available.  Run "cmake --help-policy CMP0072" for policy details.  Use the
        cmake_policy command to set the policy and suppress this warning.
        FindOpenGL found both a legacy GL library:
          OPENGL_gl_LIBRARY: /usr/lib/x86_64-linux-gnu/libGL.so
        and GLVND libraries for OpenGL and GLX:
          OPENGL_opengl_LIBRARY: /usr/lib/x86_64-linux-gnu/libOpenGL.so
          OPENGL_glx_LIBRARY: /usr/lib/x86_64-linux-gnu/libGLX.so
        OpenGL_GL_PREFERENCE has not been set to "GLVND" or "LEGACY", so for
        compatibility with CMake 3.10 and below the legacy GL library will be used.
        ls_calibration/glviewer/CMakeLists.txt:35 (find_package)
      This warning is for project developers.  Use -Wno-dev to suppress it.
      -- +++ processing catkin package: 'autoware_msgs'
      -- ==> add_subdirectory(ls_calibration/autoware_msgs)
      CMake Deprecation Warning at ls_calibration/autoware_msgs/CMakeLists.txt:1 (cmake_minimum_required):
        CMake.
      -- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
      -- autoware_msgs: 50 messages, 0 services
      -- +++ processing catkin package: 'rosinterface'
      -- ==> add_subdirectory(ls_calibration/rosinterface)
      -- +++ processing catkin package: 'calibration_camera_lidar'
      -- ==> add_subdirectory(ls_calibration/calibration_camera_lidar)
      CMake Deprecation Warning at ls_calibration/calibration_camera_lidar/CMakeLists.txt:1 (cmake_minimum_required):
        CMake.
        ls_calibration/calibration_camera_lidar/CMakeLists.txt:34 (find_package)
      -- Configuring done
      -- Generating done
      -- Build files have been written to: /home/wwt/CL_calibration_ws/build
      #### Running command: "make -j16 -l16" in "/home/wwt/CL_calibration_ws/build"
      [  1%] Automatic MOC for target glviewer
      [  1%] Built target std_msgs_generate_messages_nodejs
      [  1%] Built target geometry_msgs_generate_messages_nodejs
      [  1%] Built target glviewer_autogen
      [  1%] Built target sensor_msgs_generate_messages_nodejs
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_DTLane
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ImageLaneObjects
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ControlCommandStamped
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ImageObjects
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_CloudClusterArray
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ICPStat
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_WaypointState
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_TrafficLightResult
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_DetectedObject
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_RemoteCmd
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ObjLabel
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_Lane
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_LampCmd
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_Signals
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ColorSet
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_StateCmd
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_AdjustXY
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ProjectionMatrix
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ValueSet
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ImageRect
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ObjPose
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_SteerCmd
      [  1%] Built target jsk_recognition_msgs_generate_messages_nodejs
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ExtractedPosition
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_VehicleCmd
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ImageRectRanged
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_Centroids
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_SyncTimeDiff
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_VscanTracked
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_AccelCmd
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ImageObjTracked
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_LaneArray
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_VehicleStatus
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_DetectedObjectArray
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ImageObjRanged
      [  1%] Built target std_msgs_generate_messages_eus
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_NDTStat
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_TunedResult
      [  1%] Built target jsk_recognition_msgs_generate_messages_eus
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_SyncTimeMonitor
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_ScanImage
      [  1%] Built target sensor_msgs_generate_messages_eus
      [  1%] Built target geometry_msgs_generate_messages_eus
      [  1%] Built target std_msgs_generate_messages_cpp
      [  1%] Built target sensor_msgs_generate_messages_cpp
      [  1%] Built target geometry_msgs_generate_messages_cpp
      [  1%] Built target sensor_msgs_generate_messages_lisp
      [  1%] Built target jsk_recognition_msgs_generate_messages_cpp
      [  1%] Built target std_msgs_generate_messages_lisp
      [  1%] Built target geometry_msgs_generate_messages_lisp
      [  1%] Built target std_msgs_generate_messages_py
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_GeometricRectangle
      [  1%] Built target jsk_recognition_msgs_generate_messages_lisp
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_PointsImage
      [  1%] Built target _autoware_msgs_generate_messages_check_deps_BrakeCmd
      [  1%] Built target geometry_msgs_generate_messages_py
      [  2%] Automatic MOC for target rosinterface
      [  2%] Built target sensor_msgs_generate_messages_py
      [  2%] Built target jsk_recognition_msgs_generate_messages_py
      [  2%] Built target roscpp_generate_messages_eus
      [  2%] Built target topic_tools_generate_messages_py
      [  2%] Built target roscpp_generate_messages_py
      [  2%] Built target roscpp_generate_messages_lisp
      [  2%] Built target rosgraph_msgs_generate_messages_eus
      [  2%] Built target rosgraph_msgs_generate_messages_cpp
      [  2%] Built target roscpp_generate_messages_cpp
      [  2%] Built target rosgraph_msgs_generate_messages_lisp
      [  2%] Built target _autoware_msgs_generate_messages_check_deps_IndicatorCmd
      [  2%] Built target _autoware_msgs_generate_messages_check_deps_VscanTrackedArray
      [  2%] Built target rosgraph_msgs_generate_messages_nodejs
      [  2%] Built target _autoware_msgs_generate_messages_check_deps_TrafficLightResultArray
      [  2%] Built target rosinterface_autogen
      [  2%] Built target rosgraph_msgs_generate_messages_py
      [  2%] Built target roscpp_generate_messages_nodejs
      [  2%] Built target actionlib_msgs_generate_messages_lisp
      [  2%] Built target pcl_msgs_generate_messages_lisp
      [  2%] Built target jsk_footstep_msgs_generate_messages_lisp
      [  2%] Built target jsk_footstep_msgs_generate_messages_nodejs
      [  2%] Built target actionlib_msgs_generate_messages_eus
      [  2%] Built target actionlib_msgs_generate_messages_nodejs
      [  2%] Built target pcl_msgs_generate_messages_nodejs
      [  2%] Built target pcl_msgs_generate_messages_py
      [  2%] Built target pcl_msgs_generate_messages_eus
      [  2%] Built target jsk_footstep_msgs_generate_messages_py
      [  2%] Built target actionlib_msgs_generate_messages_cpp
      [  2%] Built target jsk_footstep_msgs_generate_messages_eus
      [  2%] Built target jsk_footstep_msgs_generate_messages_cpp
      [  2%] Built target pcl_msgs_generate_messages_cpp
      [  2%] Built target tf_generate_messages_py
      [  2%] Built target tf_generate_messages_cpp
      [  2%] Built target tf_generate_messages_eus
      [  2%] Built target actionlib_msgs_generate_messages_py
      [  2%] Built target actionlib_generate_messages_eus
      [  2%] Built target actionlib_generate_messages_cpp
      [  2%] Built target tf_generate_messages_lisp
      [  2%] Built target actionlib_generate_messages_lisp
      [  2%] Built target tf2_msgs_generate_messages_eus
      [  2%] Built target actionlib_generate_messages_nodejs
      [  2%] Built target actionlib_generate_messages_py
      [  2%] Built target tf_generate_messages_nodejs
      [  2%] Built target tf2_msgs_generate_messages_nodejs
      [  2%] Built target tf2_msgs_generate_messages_cpp
      [  2%] Built target tf2_msgs_generate_messages_lisp
      [  2%] Built target tf2_msgs_generate_messages_py
      [  2%] Built target bond_generate_messages_eus
      [  2%] Built target dynamic_reconfigure_generate_messages_nodejs
      [  2%] Built target nodelet_generate_messages_lisp
      [  2%] Built target dynamic_reconfigure_generate_messages_lisp
      [  2%] Built target bond_generate_messages_cpp
      [  2%] Built target nodelet_generate_messages_py
      [  2%] Built target nodelet_generate_messages_eus
      [  2%] Built target topic_tools_generate_messages_cpp
      [  2%] Built target nodelet_generate_messages_nodejs
      [  2%] Built target bond_generate_messages_lisp
      [  2%] Built target dynamic_reconfigure_generate_messages_cpp
      [  2%] Built target topic_tools_generate_messages_eus
      [  2%] Built target topic_tools_generate_messages_nodejs
      [  2%] Built target topic_tools_generate_messages_lisp
      [  2%] Built target nodelet_topic_tools_gencfg
      [  2%] Built target dynamic_reconfigure_generate_messages_py
      [  2%] Built target pcl_ros_gencfg
      [  2%] Built target std_srvs_generate_messages_lisp
      [  2%] Built target dynamic_reconfigure_generate_messages_eus
      [  2%] Built target bond_generate_messages_py
      Consolidate compiler generated dependencies of target glviewer
      [  2%] Built target nodelet_generate_messages_cpp
      [  2%] Built target std_srvs_generate_messages_eus
      [  2%] Built target std_srvs_generate_messages_cpp
      [  2%] Built target dynamic_reconfigure_gencfg
      [  2%] Built target std_srvs_generate_messages_nodejs
      [  2%] Built target bond_generate_messages_nodejs
      Consolidate compiler generated dependencies of target rosinterface
      [  2%] Built target std_srvs_generate_messages_py
      [ 19%] Built target autoware_msgs_generate_messages_nodejs
      [ 37%] Built target autoware_msgs_generate_messages_eus
      [ 57%] Built target autoware_msgs_generate_messages_py
      [ 72%] Built target autoware_msgs_generate_messages_lisp
      [ 88%] Built target autoware_msgs_generate_messages_cpp
      [ 89%] Built target glviewer
      [ 91%] Built target rosinterface
      [ 91%] Automatic MOC for target calibration_publisher
      [ 92%] Automatic MOC for target calibrationtoolkit
      [ 92%] Automatic MOC for target calibration_test
      [ 92%] Built target calibration_publisher_autogen
      [ 92%] Built target calibrationtoolkit_autogen
      [ 92%] Built target calibration_test_autogen
      Consolidate compiler generated dependencies of target calibration_publisher
      Consolidate compiler generated dependencies of target calibration_test
      Consolidate compiler generated dependencies of target calibrationtoolkit
      [ 93%] Linking CXX executable /home/wwt/CL_calibration_ws/devel/lib/calibration_camera_lidar/calibration_publisher
      [ 96%] Built target calibration_test
      [ 97%] Built target calibrationtoolkit
      [ 97%] Automatic MOC for target calibration_toolkit
      CMakeFiles/calibration_publisher.dir/nodes/calibration_publisher/calibration_publisher.cpp.o:在函数‘main’中:
      /usr/local/opencv341/include/opencv2/core/cvstd.inl.hpp:156:对‘cv::read(cv::FileNode const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)’未定义的引用
      ls_calibration/calibration_camera_lidar/CMakeFiles/calibration_publisher.dir/build.make:344: recipe for target '/home/wwt/CL_calibration_ws/devel/lib/calibration_camera_lidar/calibration_publisher' failed
      make[2]: *** [/home/wwt/CL_calibration_ws/devel/lib/calibration_camera_lidar/calibration_publisher] Error 1
      CMakeFiles/Makefile2:4745: recipe for target 'ls_calibration/calibration_camera_lidar/CMakeFiles/calibration_publisher.dir/all' failed
      make[1]: *** [ls_calibration/calibration_camera_lidar/CMakeFiles/calibration_publisher.dir/all] Error 2
      make[1]: *** 正在等待未完成的任务....
      [ 97%] Built target calibration_toolkit_autogen
      Makefile:145: recipe for target 'all' failed
      make: *** [all] Error 2
      Invoking "make -j16 -l16" failed
        小鱼 技术大佬 @541477150
        @541477150 在 在编译autoware的标定工具箱出现的报错 中说:
        看着句应该是opencv依赖问题。
