    在自定义服务环节出现了问题,求解决!
    ros2-foxy ros2通信
    448
    • JerryNingJ
      JerryNing
      • JerryNingJ
        JerryNing
        BorrowMoney.srv
        String name
        uint32 money
        bool success
        uint32 money
        • JerryNingJ
          JerryNing
          project(village_interfaces)
          Default to C99
          if(NOT CMAKE_C_STANDARD)
          set(CMAKE_C_STANDARD 99)
          endif()
          Default to C++14
          if(NOT CMAKE_CXX_STANDARD)
          set(CMAKE_CXX_STANDARD 14)
          endif()
          endif()
          find dependencies
          uncomment the following section in order to fill in
          further dependencies manually.
          find_package(<dependency> REQUIRED)
          if(BUILD_TESTING)
          the following line skips the linter which checks for copyrights
          uncomment the line when a copyright and license is not present in all source files
          uncomment the line when this package is not in a git repo
          endif()
          "msg/Novel.msg"
          "srv/BorrowMoney.srv"
          DEPENDENCIES sensor_msgs
          ament_package()
          • JerryNingJ
            JerryNing
            <?xml version="1.0"?>
            <package format="3">
            <name>village_interfaces</name>
            <version>0.0.0</version>
            <maintainer email="ning@todo.todo">ning</maintainer>
            <member_of_group>rosidl_interface_packages</member_of_group> #添加这一行
            <export>
            </export>
            </package>
              小鱼 技术大佬 @JerryNing
              @JerryNing 在 在自定义服务环节出现了问题,求解决! 中说:
              BorrowMoney.srv
              String name
              uint32 money
              bool success
              uint32 money
              srtring name
              String 小写的
