    ros1的autoware运行报错,各位大佬能不能帮忙解决一下
    AutoWare
    ros1 autoware1.13
    1.2k
    • 22153248332
      沫小景
      File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_core.py", line 16765, in <lambda>
      lambda event: event.callable(*event.args, **event.kw) )
      File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_core.py", line 9207, in SetLabel
      return core.Window_SetLabel(*args, **kwargs)
      File "/usr/lib/python2.7/encodings/utf_8.py", line 16, in decode
      return codecs.utf_8_decode(input, errors, True)
      UnicodeDecodeError: 'utf8' codec can't decode bytes in position 612-613: invalid continuation byte
      22153248332 1 条回复 最后回复 回复 引用 0
      • 22153248332
        沫小景 @2215324833
        @2215324833 已经解决,把系统语言换回英文就不报这个错了
