    Ubuntu16.04一键安装ROS1失败
    一键安装 ros安装
    482
    • 9725074389
      曾雨昊_hust
      完整信息在下面回复
      • 9725074389
        曾雨昊_hust
        小鱼:检测当前系统ubuntu16.04:xenial 支持一键安装ROS
        [1]:更换系统源再继续安装
        [2]:不更换继续安装
        请输入[]内的数字以选择:1
        欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
        请选择换源方式,如果不知道选什么请选2
        [1]:仅更换系统源
        [2]:更换系统源并清理第三方源
        请输入[]内的数字以选择:2
        [-]Result:success
        删除一个资源文件
        [-]Result:success
        [-]Result:success
        [-]Result:success
        检测到当前系统架构为[i386:xenial],正在为你更换对应源..
        创建文件:/etc/apt/sources.list
        替换完成,尝试第一次更新....
        [|]Get:2 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates InRelease [99.8[-]Get:3 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports InRelease [97[/]Get:4 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security InRelease [99.[|]Get:6
        ...省略...
        i3[-]Result:code:100
        更新失败,开始更换导入方式并三次尝试...
        Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9]
        [-]Result:success                           -keyserver
        Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys DCC9EFBF77E11517]
        Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 54404762BBB6E853]
        Run CMD Task:[apt-get install debian-keyring debian-archive-keyring]
        [/]Package debian-keyring is not available, but is referred to by another packag[-]Result:code:100                            has been obsoleted, or
        Run CMD Task:[apt-key update]
        [\]gpg: key 437D05B5: "Ubuntu Archive Automatic Signing Key <ftpmaster@ubuntu.co[|]gpg: key FBB75451: "Ubuntu CD Image Automatic Signing Key <cdimage@ubuntu.com[-]gpg: key C0B21F32: "Ubuntu Archive Automatic Signing Key (2012) <ftpmaster@ub[/]gpg: key EFE21092: "Ubuntu CD Image Automatic Signing Key (2012) <cdimage@ubu[-]Result:success
        [|]Ign:9 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/restricted i386 Package[/]Ign:16 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/multiverse i386 Packag[\]Ign:20
        ...省略...
        https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/multiverse i3[-]Result:code:100
        如果出现问题NO_PUBKEY XXXXXXXX,请手动运行添加指令:apt-key adv --keyserver keyserver.ubuntu.com --recv-keys XXXXXXXX
        如:error: NO_PUBKEY 0E98404D386FA1D9
        运行指令:sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9
        镜像修复完成.....
        ...省略...
        apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial/main/binary-i386/Packages  404  Not Found\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial-updates/main/binary-i386/Packages  404  Not Found\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial-backports/main/binary-i386/Packages  404  Not Found\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial-security/main/binary-i386/Packages  404  Not Found\n', 'E: Some index files failed to download. They have been ignored, or old ones used instead.\n']
        [/]libcurl3-gnutls - easy-to-use client-side URL transfer library (GnuTLS flavou[-]Result:success                           placement
        [-]Result:code:100                            has been obsoleted, orage.
        [-]Result:success                           eplacement (new v2.x)
        [-]Result:success                           e and 0 not upgraded.
        [-]Result:code:2
        [-]Result:code:2
        导入密钥失败,开始更换导入方式并二次尝试...
        [-]Result:success
        [|]Ign:9 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/restricted i386 Package[/]Ign:16 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/multiverse i386 Packag[\]Ign:20 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/main i386 Pack[|]Ign:24 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/restricted i38[-]Ign:27 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/universe i386 [/]Ign:31 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/multiverse i38[|]  Cannot initiate the connection to mirrors.tuna.tsinghua.edu.cn:80 (2402:f00[/]  Cannot initiate the connection to mirrors.tuna.tsinghua.edu.cn:80 (2402:f00[\]Ign:37 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports/main i386 Pa[|]Ign:42 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports/universe i38[/]Ign:48 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/main i386 Pac[\]Ign:52 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/restricted i3[|]Ign:55 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/universe i386[-]Ign:59 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/multiverse i3[/]Ign:9 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/restricted i386 Package[|]Ign:16 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/multiverse i386 Packag[-]Ign:20 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/main i386 Pack[/]Ign:24
        ...省略...
        apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'W: Failed to fetch http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu/dists/xenial/InRelease  Cannot initiate the connection to mirrors.tuna.tsinghua.edu.cn:80 (2402:f000:1:400::2). - connect (101: Network is unreachable) [IP: 2402:f000:1:400::2 80]\n', 'W: Failed to fetch http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/dists/xenial/InRelease  Cannot initiate the connection to mirrors.tuna.tsinghua.edu.cn:80 (2402:f000:1:400::2). - connect (101: Network is unreachable) [IP: 2402:f000:1:400::2 80]\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial/main/binary-i386/Packages  404  Not Found\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial-updates/main/binary-i386/Packages  404  Not Found\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial-backports/main/binary-i386/Packages  404  Not Found\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial-security/main/binary-i386/Packages  404  Not Found\n', 'W: Some index files failed to download. They have been ignored, or old ones used instead.\n']
        [-]Result:success
        [-]Result:success
        ...省略...
        apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial/main/binary-i386/Packages  404  Not Found\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial-updates/main/binary-i386/Packages  404  Not Found\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial-backports/main/binary-i386/Packages  404  Not Found\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial-security/main/binary-i386/Packages  404  Not Found\n', 'E: Failed to fetch https://repo.huaweicloud.com/ros2/ubuntu/dists/xenial/main/binary-i386/Packages  404  Not Found\n', 'E: Some index files failed to download. They have been ignored, or old ones used instead.\n']
        [\]ros-kinetic-ros-base - A metapackage which extends ros_core and includes other basic non-robot tools like actionlib, dynamic reconfigure, nodelets, and plugi[-]Result:success
        [-]Result:success
        [|]Ign:8 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/main i386 Packa[-]Ign:12 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/restricted i38[/]Ign:15
        ...省略...
        apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'W: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial/InRelease  Failed to connect to mirrors.ustc.edu.cn port 443: Connection refused\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial-updates/main/binary-i386/Packages  404  Not Found\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial-backports/main/binary-i386/Packages  404  Not Found\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/xenial-security/main/binary-i386/Packages  404  Not Found\n', 'W: Some index files failed to download. They have been ignored, or old ones used instead.\n']
        根据您的系统,为您推荐安装源为['https://packages.ros.org/ros/ubuntu/', 'https://packages.ros.org/ros2/ubuntu/']
        [-]Result:success
        [\]Get:2 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates InRelease [99.8[|]Get:3 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports InRelease [97[-]Get:4
        ...省略...
        检测到发生证书校验错误['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', "E: The repository 'https://packages.ros.org/ros/ubuntu xenial Release' does not have a Release file.\n", "E: The repository 'https://packages.ros.org/ros2/ubuntu xenial Release' does not have a Release file.\n"],自动取消https校验,如有需要请手动删除:rm /etc/apt/apt.conf.d/99verify-peer.conf
        [-]Result:success
        Run CMD Task:[echo  "Acquire { https::Verify-Peer false }" > /etc/apt/apt.conf.d/99verify-peer.conf]
        [-]Result:success
        [\]Get:8 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/main Translation-en [56[-]  SSL: certificate subject name (*.osuosl.org) does not match target host nam[/]Get:10 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/main i386 DEP-11 Metad[\]Get:11
        ...省略...
        apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', "E: The repository 'https://packages.ros.org/ros/ubuntu xenial Release' does not have a Release file.\n", "E: The repository 'https://packages.ros.org/ros2/ubuntu xenial Release' does not have a Release file.\n"]
        [|]Get:3 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates InRelease [99.8[-]Get:4 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports InRelease [97[\]Get:6 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security InRelease [99.[/]  SSL: certificate subject name (*.osuosl.org) does not match target host nam[\]Ign:12 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/restricted i386 Packag[-]  SSL: certificate subject name (*.osuosl.org) does not match target host nam[\]Ign:20 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/multiverse i386 Packag[|]Ign:24
        ...省略...
        [-]Result:success
        [-]Result:success
        [\]Get:8 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/main Translation-en [56[|]Get:9 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/main i386 DEP-11 Metada[/]  SSL: certificate subject name (*.osuosl.org) does not match target host nam[\]Get:11 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/main DEP-11 64x64 Icon[|]Ign:12 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/restricted i386 Packag[-]Get:13 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/restricted Translation[/]Get:14 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/restricted i386 DEP-11[-]  SSL: certificate subject name (*.osuosl.org) does not match target host nam[/]Get:17 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/universe Translation-e[\]Get:18 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/universe i386 DEP-11 M[|]Get:19 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/universe DEP-11 64x64 [-]Ign:20 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/multiverse i386 Packag[/]Get:21 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/multiverse Translation[\]Get:22 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/multiverse i386 DEP-11[|]Get:23 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/multiverse DEP-11 64x6[-]Ign:24 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/main i386 Pack[/]Ign:28 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/restricted i38[\]Ign:31 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/universe i386 [|]Ign:35 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/multiverse i38[-]Ign:39 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports/main i386 Pa[/]Ign:44 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports/universe i38[|]Ign:50 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/main i386 Pac[-]Ign:54 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/restricted i3[/]Ign:57 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/universe i386[\]Ign:61 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/multiverse i3[|]Ign:12 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/restricted i386 Packag[/]Ign:20 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/multiverse i386 Packag[\]Ign:24 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/main i386 Pack[|]Ign:28 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/restricted i38[-]Ign:31 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/universe i386 [/]Ign:35 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/multiverse i38[\]Ign:39 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports/main i386 Pa[|]Ign:44 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports/universe i38[/]Ign:50 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/main i386 Pac[\]Ign:54 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/restricted i3[|]Ign:57 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/universe i386[-]Ign:61 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/multiverse i3[/]Ign:12 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/restricted i386 Packag[|]Ign:20 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/multiverse i386 Packag[-]Ign:24 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/main i386 Pack[/]Ign:28 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/restricted i38[\]Ign:31 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/universe i386 [|]Ign:35 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/multiverse i38[-]Ign:39 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports/main i386 Pa[/]Ign:44 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports/universe i38[-]Ign:50 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/main i386 Pac[/]Ign:54 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/restricted i3[\]Ign:57 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/universe i386[|]Ign:61 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/multiverse i3[-]Ign:12 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/restricted i386 Packag[\]Ign:20 https://mirrors.ustc.edu.cn/ubuntu-ports xenial/multiverse i386 Packag[|]Err:24 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/main i386 Pack[/]Ign:28 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/restricted i38[\]Ign:31 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/universe i386 [|]Ign:35 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-updates/multiverse i38[-]Err:39 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports/main i386 Pa[\]Ign:44 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-backports/universe i38[|]Err:50 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/main i386 Pac[/]Ign:54 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/restricted i3[\]Ign:57 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/universe i386[|]Ign:61 https://mirrors.ustc.edu.cn/ubuntu-ports xenial-security/multiverse i3[-]Result:code:100
        四次换源后都失败了,请及时联系小鱼获取解决方案并处理!
        [1]:kinetic(ROS1)
        请输入[]内的数字以选择:1
        请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
        [1]:kinetic(ROS1)桌面版
        [2]:kinetic(ROS1)基础版(小)
        请输入[]内的数字以选择:1
        Run CMD Task:[sudo apt install   ros-kinetic-desktop-full -y]
        Reading package lists... Done
        Building dependency tree
         ros-kinetic-desktop-full : Depends: ros-kinetic-desktop but it is not going to be installed
                                    Depends: ros-kinetic-perception but it is not going to be installed
                                    Depends: ros-kinetic-simulators but it is not going to be installed
                                    Depends: ros-kinetic-urdf-tutorial but it is not going to be installed
        E: Unable to correct problems, you have held broken packages.
        [-] ros-kinetic-desktop-full : Depends: ros-kinetic-desktop but it is not going [/]                            Depends: ros-kinetic-perception but it is not goi[\]                            Depends: ros-kinetic-simulators but it is not goi[|]                            Depends: ros-kinetic-urdf-tutorial but it is not [-]Result:code:100
        请注意我,检测你在安装过程中出现依赖问题,请在稍后输入n,再选择y,即可解决(若无法解决,清在稍后手动运行命令: sudo aptitude install ros-kinetic-desktop-full)
        确认了解情况,请输入回车继续安装
        Run CMD Task:[sudo apt install   ros-kinetic-desktop-full]
        [-]Result:success                           for working with catkin.
        [-] python-catkin-tools : Depends: python-catkin-pkg (>= 0.2.9) but it is not go[/]                       Depends: python-osrf-pycommon but it is not going to b[\]                       Depends: python-pkg-resources but it is not installabl[-]Result:code:100                           uptools but it is not installable
        [-]Result:success                           nager abstraction tool for ROS
        [-] python-rosdep : Depends: python-catkin-pkg but it is not going to be install[/]                 Depends: python-rosdistro but it is not going to be installe[-]                 Depends: python-rosdep-modules (>= 0.21.0) but it is not goi[-]Result:code:100
        Run CMD Task:[ls /opt/ros/kinetic/setup.bash]
        [-]Result:code:2
        [-]Result:code:2
        • 11989270601
          星河
          一键安装ros1的教程在哪儿?
          15657791391 1 条回复 最后回复 回复 引用 0
          • 15657791391
            ♚ @1198927060
            @1198927060 我也想问一键安装ros1的在哪
              小鱼 技术大佬 @972507438
              @972507438 在 Ubuntu16.04一键安装ROS1失败 中说:
              i386:xenial]
              i386 系统架构不被支持
