    ros2一键安装下载很慢
    提问前必看 ros2一键安装
    603
    • 31809118223
      杨某啦啦啦
      Ubuntu18.04安装ros2 一键安装,卡在下载镜像这里,很慢很慢,换过源,翻过墙,换过网络,还是不行,而且在重试几次后,还没下载完他就让我给容器命名,开始安装,现在安装的不能用![替代文字](61098f4d-e501-4806-90be-23372162f362-image.png 图片地址)
      ---众多工具,等君来用---
      [6]:一键安装:nodejs
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [77]:测试模式:运行自定义工具测试
      请输入[]内的数字以选择:11
      --2023-04-09 00:05:06-- http://fishros.com/install/install1s/tools/tool_install_ros_with_docker.py
      已发出 HTTP 请求,正在等待回应... 200 OK
      长度: 11540 (11K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 11.27K --.-KB/s 用时 0.003s
      2023-04-09 00:05:07 (4.11 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_ros_with_docker.py” [11540/11540])
      --2023-04-09 00:05:07-- http://fishros.com/install/install1s/tools/tool_install_vscode.py
      长度: 1366 (1.3K) [application/octet-stream]
      2023-04-09 00:05:07 (384 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_vscode.py” [1366/1366])
      --2023-04-09 00:05:07-- http://fishros.com/install/install1s/tools/tool_install_docker.py
      2023-04-09 00:05:07 (595 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_docker.py” [2882/2882])
      [1]:noetic
      [2]:humble
      [3]:foxy
      [4]:galactic
      [5]:melodic
      [6]:rolling
      [7]:kinetic
      [8]:eloquent
      [9]:dashing
      [10]:crystal
      [11]:bouncy
      [12]:ardent
      [13]:lunar
      [14]:indigo
      请输入[]内的数字以选择:3
      你选择了foxy(ROS2),该版本目前状态:长期支持
      Run CMD Task:[docker version]
      [-]Result:success a0e4e17bddfbd388f38
      Run CMD Task:[sudo docker pull fishros2/ros:foxy-desktop ]
      foxy-desktop: Pulling from fishros2/ros
      d7bfe07ed847: Downloading 3.75MB
      bf1e38681d9b: Download complete
      8a44b59555aa: Downloading 3.964MB/5.547MB
      12f29772f338: Download complete
      0b699c33a199: Download complete
      eb42810f84e6: Downloading 3.771MB/120.1MB
      81f92457a493: Waiting
      476e616a9070: Waiting
      fa71ae8a0c62: Waiting
      dd9ad8294024: Waiting
      d0def727ac77: Waiting
      6bdbc4056f24: Waiting
      3875ea8ce72b: Waiting
      ![替代文字](f90fbfdd-75f2-4f37-9261-a78b16a304ce-image.png 图片地址)
      yang@ubuntu:~$ ros2 run turtlesim turtlesim_node
      请输入指令控制ros2: 重启(r) 进入(e) 启动(s) 关闭(c) 删除(d) 测试(t):
      e
      Error response from daemon: No such container: ros2
      yang@ubuntu:~$
      • 31809118223
        杨某啦啦啦
        这是文件里搜索ros的结果,不知道算不算安装完成
        ![替代文字](f751487d-d2a7-477a-8d98-b2fc3daf8455-image.png 图片地址)
          小鱼 技术大佬 @3180911822
          @3180911822 docker原因了,直接选1安装呢
          11989270601 16287993151 3 条回复 最后回复 回复 引用 0
          • 11989270601
            星河 @小鱼
            d73d123c-ab27-471c-8ad5-3d9e5b0bc14b-image.png master@master-virtual-machine:~$ source /opt/ros/humble/setup.bash
            bash: /opt/ros/humble/setup.bash: No such file or directory
            一键安装ros2之后还是出现了这个问题,并且/opt目录下只有一个文件夹container,咋回事鱼哥
            • 11989270601
              星河 @小鱼
              @小鱼 选1安装ros2是不是只能安装foxy版本
              • 16287993151
                早点睡晚安吧 @小鱼
                @小鱼 有没有不用docker 的 ros2 安装呢 箱装 humBle
