    gazebo无法导入urdf模型,貌似是spawn_entity.py的问题,求解答
    动手学ROS2
    gazebo报错 fishbot
      luo
      luo-ub22@Nitro-AN515-57:~$ ros2 launch turtlebot3_gazebo turtlebot3_world.launch.py
      [INFO] [launch]: All log files can be found below /home/luo-ub22/.ros/log/2023-12-01-21-59-33-404812-Nitro-AN515-57-26296
      urdf_file_name : turtlebot3_burger.urdf
      [INFO] [gzserver-1]: process started with pid [26297]
      [INFO] [gzclient-2]: process started with pid [26299]
      [INFO] [robot_state_publisher-3]: process started with pid [26301]
      [INFO] [spawn_entity.py-4]: process started with pid [26303]
      [robot_state_publisher-3] [INFO] [1701439174.185340046] [robot_state_publisher]: got segment base_footprint
      [robot_state_publisher-3] [INFO] [1701439174.185437440] [robot_state_publisher]: got segment base_link
      [robot_state_publisher-3] [INFO] [1701439174.185442406] [robot_state_publisher]: got segment base_scan
      [robot_state_publisher-3] [INFO] [1701439174.185446789] [robot_state_publisher]: got segment caster_back_link
      [robot_state_publisher-3] [INFO] [1701439174.185468371] [robot_state_publisher]: got segment imu_link
      [robot_state_publisher-3] [INFO] [1701439174.185471157] [robot_state_publisher]: got segment wheel_left_link
      [robot_state_publisher-3] [INFO] [1701439174.185473939] [robot_state_publisher]: got segment wheel_right_link
      [spawn_entity.py-4] Traceback (most recent call last):
      [spawn_entity.py-4] File "/opt/ros/humble/lib/gazebo_ros/spawn_entity.py", line 30, in <module>
      [spawn_entity.py-4] from geometry_msgs.msg import Pose
      [spawn_entity.py-4] File "/opt/ros/humble/local/lib/python3.10/dist-packages/geometry_msgs/msg/init.py", line 3, in <module>
      [spawn_entity.py-4] from geometry_msgs.msg._accel_with_covariance import AccelWithCovariance # noqa: F401
      [spawn_entity.py-4] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
      [spawn_entity.py-4] File "/opt/ros/humble/local/lib/python3.10/dist-packages/geometry_msgs/msg/_accel_with_covariance.py", line 13, in <module>
      [spawn_entity.py-4] import numpy # noqa: E402, I100
      [spawn_entity.py-4] ModuleNotFoundError: No module named 'numpy'
      [ERROR] [spawn_entity.py-4]: process has died [pid 26303, exit code 1, cmd '/opt/ros/humble/lib/gazebo_ros/spawn_entity.py -entity burger -file /opt/ros/humble/share/turtlebot3_gazebo/models/turtlebot3_burger/model.sdf -x -2.0 -y -0.5 -z 0.01 --ros-args'].
        luo @17612478530
        最后由 17612478530 编辑
        查看以前的贴,不确定是conda问题,也不确定是numpy的问题,之前照着教程案例做出现同类错误,直接使用turtlebot3也是一样,急求解答。
        • 1 17612478530 将这个主题标记为已解决,在
        • 1 17612478530 将这个主题标记为未解决,在
          gazebo需要导入的是SDF模型,rviz才是urdf
          • M
            mericalandintent
            没有设置模型名称吧,如果用turtlebot3的话
