    参数是什么意思
    动手学ROS2
    ros2 navigation2
    1.0k
    • 35684851433
      一二一三八
      鱼哥和各位大佬好,我想请问nav2的参数配置文件中的参数意义,如下参数文件
      amcl:
      ros__parameters:
      use_sim_time: True
      alpha1: 0.2
      alpha2: 0.2
      alpha3: 0.2
      alpha4: 0.2
      alpha5: 0.2
      base_frame_id: "base_link"
      beam_skip_distance: 0.5
      beam_skip_threshold: 0.3
      do_beamskip: false
      global_frame_id: "map"
      lambda_short: 0.1
      laser_max_range: 100.0
      laser_min_range: -1.0
      max_beams: 60
      max_particles: 5000
      min_particles: 500
      initial_pose_x: 0.0
      initial_pose_y: 0.0
      initial_pose_a: 0.0
      initial_cov_xx: 32
      initial_cov_yy: 32
      initial_cov_zz: 32
      odom_frame_id: "odom"
      pf_err: 0.05
      pf_z: 0.99
      recovery_alpha_fast: 0.0
      recovery_alpha_slow: 0.0
      resample_interval: 1
      save_pose_rate: 0.5
      sigma_hit: 0.2
      tf_broadcast: true
      transform_tolerance: 10.0
      update_min_a: 0.2
      update_min_d: 0.25
      z_hit: 0.5
      z_max: 0.05
      z_rand: 0.5
      z_short: 0.05
      scan_topic: scan
      amcl_map_client:
      ros__parameters:
      use_sim_time: True
      amcl_rclcpp_node:
      ros__parameters:
      use_sim_time: True
      bt_navigator:
      ros__parameters:
      use_sim_time: True
      global_frame: map
      robot_base_frame: base_link
      odom_topic: /odom
      bt_loop_duration: 10
      default_server_timeout: 20
      plugin_lib_names:
      - nav2_spin_action_bt_node
      - nav2_wait_action_bt_node
      - nav2_back_up_action_bt_node
      - nav2_recovery_node_bt_node
      - nav2_single_trigger_bt_node
      - nav2_wait_cancel_bt_node
      - nav2_spin_cancel_bt_node
      - nav2_back_up_cancel_bt_node
      bt_navigator_rclcpp_node:
      ros__parameters:
      use_sim_time: True
      controller_server:
      ros__parameters:
      use_sim_time: True
      controller_frequency: 20.0
      min_y_velocity_threshold: 0.5
      failure_tolerance: 0.3
      # Progress checker parameters
      progress_checker:
        required_movement_radius: 0.5
        movement_time_allowance: 10.0
      # Goal checker parameters
      #precise_goal_checker:
      #  xy_goal_tolerance: 0.25
      #  yaw_goal_tolerance: 0.25
      #  stateful: True
      general_goal_checker:
        stateful: True
      # DWB parameters
      FollowPath:
        min_vel_x: 0.0
        min_vel_y: 0.0
        max_vel_x: 0.26
        max_vel_y: 0.0
        max_vel_theta: 1.0
        min_speed_xy: 0.0
        max_speed_xy: 0.26
        min_speed_theta: 0.0
        acc_lim_x: 2.5
        acc_lim_y: 0.0
        acc_lim_theta: 3.2
        decel_lim_x: -2.5
        decel_lim_y: 0.0
        decel_lim_theta: -3.2
        vx_samples: 20
        vy_samples: 5
        vtheta_samples: 20
        sim_time: 1.7
        linear_granularity: 0.05
        angular_granularity: 0.025
        transform_tolerance: 0.2
        trans_stopped_velocity: 0.25
        stateful: True
        BaseObstacle.scale: 0.02
        PathAlign.scale: 32.0
        GoalAlign.scale: 24.0
        PathDist.scale: 32.0
        GoalDist.scale: 24.0
        RotateToGoal.scale: 32.0
      ros__parameters:
      use_sim_time: True
      local_costmap:
      local_costmap:
      ros__parameters:
      update_frequency: 5.0
      publish_frequency: 2.0
      global_frame: odom
      use_sim_time: True
      rolling_window: true
      width: 3
      height: 3
      resolution: 0.05
      robot_radius: 0.12
      inflation_layer:
      cost_scaling_factor: 3.0
      inflation_radius: 0.35
      voxel_layer:
      enabled: True
      publish_voxel_map: True
      origin_z: 0.0
      z_resolution: 0.05
      z_voxels: 16
      max_obstacle_height: 2.0
      mark_threshold: 0
      observation_sources: scan
      scan:
      topic: /scan
      clearing: True
      marking: True
      data_type: "LaserScan"
      raytrace_max_range: 3.0
      raytrace_min_range: 0.0
      obstacle_max_range: 2.5
      obstacle_min_range: 0.0
      static_layer:
      local_costmap_client:
      ros__parameters:
      use_sim_time: True
      local_costmap_rclcpp_node:
      ros__parameters:
      use_sim_time: True
      global_costmap:
      global_costmap:
      ros__parameters:
      update_frequency: 1.0
      publish_frequency: 1.0
      global_frame: map
      use_sim_time: True
      robot_radius: 0.12
      resolution: 0.05
      track_unknown_space: true
      obstacle_layer:
      enabled: True
      scan:
      topic: /scan
      clearing: True
      marking: True
      static_layer:
      inflation_layer:
      global_costmap_client:
      ros__parameters:
      use_sim_time: True
      global_costmap_rclcpp_node:
      ros__parameters:
      use_sim_time: True
      map_server:
      ros__parameters:
      use_sim_time: True
      map_saver:
      ros__parameters:
      use_sim_time: True
      save_map_timeout: 5.0
      free_thresh_default: 0.25
      occupied_thresh_default: 0.65
      planner_server:
      ros__parameters:
      use_sim_time: True
      GridBased:
      tolerance: 0.5
      use_astar: false
      allow_unknown: true
      planner_server_rclcpp_node:
      ros__parameters:
      use_sim_time: True
      smoother_server:
      ros__parameters:
      use_sim_time: True
      simple_smoother:
      tolerance: 1.0e-10
      max_its: 1000
      do_refinement: True
      behavior_server:
      ros__parameters:
      cycle_frequency: 10.0
      behavior_plugins: ["spin", "backup", "drive_on_heading", "wait"]
      spin:
      plugin: "nav2_behaviors/Spin"
      backup:
      drive_on_heading:
      wait:
      plugin: "nav2_behaviors/Wait"
      global_frame: odom
      transform_tolerance: 0.1
      use_sim_time: true
      simulate_ahead_time: 2.0
      max_rotational_vel: 1.0
      min_rotational_vel: 0.4
      rotational_acc_lim: 3.2
      robot_state_publisher:
      ros__parameters:
      use_sim_time: True
      waypoint_follower:
      ros__parameters:
      loop_rate: 20
      stop_on_failure: false
      wait_at_waypoint:
      enabled: True
      waypoint_pause_duration: 200
      请问,其中的
      amcl_map_client:
      ros__parameters:
      use_sim_time: True
      amcl_rclcpp_node:
      ros__parameters:
      use_sim_time: True
      ros__parameters:
      use_sim_time: True
      等等这些在官网参数配置中看不到的节点配置是怎么来的?
      感谢!!!
