melodic一键安装cartographer报错Could not connect to ports.ubuntu.com:80
Ubuntu 18.04
ROS melodic 1.14.3一键安装Cartographer时遇到如下报错:
Run CMD Task:[sudo apt update] [-] Could not connect to ports.ubuntu.com:80 (185.125.190.36). - connect (111: Connection refused) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Could not connect to ports.ubuntu.com:80 (185.125.190.39). - connect (111: Connection refused) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::16). - connect (1[-]Result:success --upgradable' to see it.seports InRelease Run CMD Task:[sudo apt install ninja-build stow git -y] [-]Result:success e and 1 not upgraded. Run CMD Task:[mkdir -p cartographer_ws/src] [-]Result:success Run CMD Task:[git clone https://gitee.com/yuzi99url/cartographer_ros.git] [-]Result:success Run CMD Task:[git clone https://gitee.com/yuzi99url/cartographer.git] [-]Result:success Run CMD Task:[sudo apt-get install libamd2 libatlas3-base libbtf1 libcamd2 libccolamd2 libceres-dev libceres1 libcholmod3 libcxsparse3 libgflags-dev libgflags2.2 libgoogle-glog-dev libgoogle-glog0v5 libklu1 libldl2 liblua5.2-0 liblua5.2-dev libmetis5 libncurses5 libncursesw5 librbio2 libreadline-dev libspqr2 libsuitesparse-dev libtinfo-dev libtinfo5 libtool-bin libumfpack5 -y] [|] Could not connect to mirrors.tuna.tsinghua.edu.cn:80 (101.6.15.130). - connect (113: No route to host) Cannot initiate the conne[-]Result:code:100 s.tuna.tsinghua.edu.cn:80 (2402:f000:1:400::2). - connect (101: Network is unreachable) Run CMD Task:[sudo apt-get libgraphblas1 -y] [-]Result:code:100 Run CMD Task:[sudo apt-get remove ros-melodic-abseil-cpp -y] [-]Result:success e and 1 not upgraded.ved Run CMD Task:[bash src/cartographer/scripts/install_abseil.sh] [-]Result:code:128 Run CMD Task:[catkin_make_isolated --install --use-ninja] [-]Result:code:127 Run CMD Task:[sudo chmod -R 777 cartographer_ws] [-]Result:success
https://github.com/HuaYuXiao/UAV-Dynamic-Obstacle-Avoidance/issues/17
此回复已被删除! -
此回复已被删除! -
新的疑惑:
sudo apt-get libgraphblas1 -y这条指令似乎出错了?应该改成这个吗?
sudo apt-get install libgraphblas1 -y
