    Platformio安装失败
    plateformio 一键安装
    2.4k
    • 32535196423
      3253519642
      下载Platformio插件失败,无法初始化
      Error: WARNING: Ignoring invalid distribution -latformio (/home/star/.platformio/penv/lib/python3.10/site-packages)
      WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))': /simple/pip/
      WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))': /simple/pip/
      W...
      使用一键安装的方式也无法安装
      开始下载ESP32开发依赖库~
      下载不使用代理会很慢(大约4小时左右),建议运行一键安装14开启代理后,导出终端代理可10分钟装好
      当前进度: 1/7
      Run CMD Task:[export HOME=/home/star/ && $HOME.platformio/penv/bin/pio pkg install --global --platform "platformio/espressif32@^6.4.0"]
      sh: 1: /home/star/.platformio/penv/bin/pio: not found
      当前进度: 2/7
      Run CMD Task:[export HOME=/home/star/ && $HOME.platformio/penv/bin/pio pkg install --global --tool "platformio/contrib-piohome"]
      当前进度: 3/7
      Run CMD Task:[export HOME=/home/star/ && $HOME.platformio/penv/bin/pio pkg install --global --tool "platformio/framework-arduinoespressif32"]
      当前进度: 4/7
      Run CMD Task:[export HOME=/home/star/ && $HOME.platformio/penv/bin/pio pkg install --global --tool "platformio/tool-scons"]
      当前进度: 5/7
      Run CMD Task:[export HOME=/home/star/ && $HOME.platformio/penv/bin/pio pkg install --global --tool "platformio/tool-mkfatfs"]
      当前进度: 6/7
      Run CMD Task:[export HOME=/home/star/ && $HOME.platformio/penv/bin/pio pkg install --global --tool "platformio/tool-mkspiffs"]
      当前进度: 7/7
      Run CMD Task:[export HOME=/home/star/ && $HOME.platformio/penv/bin/pio pkg install --global --tool "platformio/tool-mklittlefs"]
      安装,接下来你可以到vscode里新建工程了~!
      已经开启了代理也没用
      文件已存在,无需下载。
      终端通过环境变量设置: export http_proxy=http://127.0.0.1:7890 && export https_proxy=http://127.0.0.1:7890
      配置系统默认代理方式: 系统设置->网络->网络代理->手动->HTTP(127.0.0.1 7890)->HTTPS(127.0.0.1 7890)
      管理页面方法:https://fishros.org.cn/forum/topic/668
      INFO[0000] Start initial compatible provider 国外流量
      INFO[0000] Start initial compatible provider ChatGPT及其他AI
      INFO[0000] Start initial compatible provider Youtube
      INFO[0000] Start initial compatible provider 其他流量
      INFO[0000] Start initial compatible provider 哔哩哔哩
      INFO[0000] Start initial compatible provider 苹果服务
      INFO[0000] Start initial compatible provider 直接连接
      INFO[0000] Start initial compatible provider Netflix
      INFO[0000] Start initial compatible provider Steam
      INFO[0000] Start initial compatible provider Telegram
      INFO[0000] Start initial compatible provider 国外媒体
      请问大佬们怎么解决?
        小鱼 技术大佬 @3253519642
        @3253519642 先到vscode中安装插件
        32535196423 1 条回复 最后回复 回复 引用 0
        • 32535196423
          3253519642 @小鱼
          @小鱼 插件安装报的就是上面的第一个错误替代文字
            小鱼 技术大佬 @3253519642
            @3253519642 参考该教程看看:https://fishros.org.cn/forum/topic/1712/pio-安装指南2023-9月版本
            • 32535196423 3253519642 将这个主题标记为已解决,在
