    建图前的准备2 发布odom的TF
    建图前的准备 odom
    1.2k
    • 26932262522
      命里有我
      ros2 run fishbot_bringup fishbot_bringup
      运行该指令之后没有输出(全部按照教程进行)
      fishbot_bringup.cpp 代码
      #include <rclcpp/rclcpp.hpp>
      #include <tf2/utils.h>
      public:
      // 创建一个订阅者,订阅"odom"话题的nav_msgs::msg::Odometry类型消息
      std::bind(&TopicSubscribe01::odom_callback, this, std::placeholders::1));
      tf_broadcaster
      private:
      // 回调函数,处理接收到的odom消息
      (void)msg;
      RCLCPP_INFO(this->get_logger(), "接收到里程计信息->底盘坐标系 tf :(%f,%f)",
      msg->pose.pose.position.x, msg->pose.pose.position.y)
      // 更新odom_msg_的姿态信息
      public:
      // 发布坐标变换信息
      void publish_tf()
      // 广播坐标变换信息
      // 初始化ROS节点
      rclcpp::init(argc, argv);
      // 创建一个TopicSubscribe01节点
      // 设置循环频率
      rclcpp::WallRate loop_rate(20.0);
      while (rclcpp::ok())
      // 处理回调函数
      rclcpp::spin_some(node);
      // 发布坐标变换信息
      node->publish_tf();
      // 控制循环频率
      loop_rate.sleep();
      // 关闭ROS节点
      rclcpp::shutdown();
      return 0;
      CMakeLists.txt 代码
      project(fishbot_bringup)
      endif()
      #find dependencies
      find_package(rclcpp REQUIRED)
      find_package(geometry_msgs REQUIRED)
      find_package(nav_msgs REQUIRED)
      find_package(tf2 REQUIRED)
      find_package(tf2_ros REQUIRED)
      set(dependencies
      rclcpp
      geometry_msgs
      nav_msgs
      tf2
      tf2_ros
      #uncomment the following section in order to fill in
      #further dependencies manually.
      #find_package(<dependency> REQUIRED)
      add_executable(fishbot_bringup src/fishbot_bringup.cpp)
      target_include_directories(fishbot_bringup PUBLIC
      $<BUILD_INTERFACE:${CMAKE_CURRENT_SOURCE_DIR}/include>
      $<INSTALL_INTERFACE:include>)
      target_compile_features(fishbot_bringup PUBLIC c_std_99 cxx_std_17) # Require C99 and C++17
      ament_target_dependencies(fishbot_bringup
      ${dependencies}
      install(TARGETS fishbot_bringup
      DESTINATION lib/${PROJECT_NAME})
      if(BUILD_TESTING)
      #the following line skips the linter which checks for copyrights
      #comment the line when a copyright and license is added to all source files
      #the following line skips cpplint (only works in a git repo)
      #comment the line when this package is in a git repo and when
      #a copyright and license is added to all source files
      endif()
      ament_package()
        小鱼 技术大佬 @2693226252
        @2693226252 要开agent,你要理解这段代码的意思,订阅odom发布tf
        twj0011001010T 26932262522 2 条回复 最后回复 回复 引用 0
        • twj0011001010T
          twj0011001010 @小鱼
          @小鱼 在 建图前的准备2 发布odom的TF 中说:
          鱼哥,请问agent是开有线的还是无线的
            小鱼 技术大佬 @twj0011001010
            @twj0011001010 无所谓,你要用那个开哪个
            twj0011001010T 1 条回复 最后回复 回复 引用 0
            • twj0011001010T
              twj0011001010 @小鱼
              @小鱼 我根据教程里的步骤来,发现我的odom没有发布话题,我也有线运行agent了,是不是因为需要雷达转接板才能实现,必须用无线运行吗
              • 26932262522
                命里有我 @小鱼
                @小鱼 开了agent还是不行
                小鱼小 3 2 条回复 最后回复 回复 引用 0
                  小鱼 技术大佬 @2693226252
                  @2693226252 https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
                  提问模板:
                  ## 标题:[清晰而简洁地总结您的问题]
                  ### 问题描述:
                  [在这里详细描述您遇到的问题。请确保您提供了足够的背景信息,以便其他人能够理解您的问题。]
                  ### 具体细节和研究:
                  - [列出任何相关细节或研究,以帮助回答者更好地理解您的问题。]
                  - [如果可能,请提供与您问题相关的链接或参考资料。]
                  ### 尝试过的解决方法:
                  - [描述您已经尝试过的任何解决方法或方法。这可以帮助其他人了解您遇到问题的具体情况,并避免给出与您已经尝试过的解决方案相同的答案。]
                  在发帖之前,请确保您已经在网站上搜索过您的问题,以确保它没有被回答过。感谢您的提问,社区会竭尽全力提供帮助!
                    @twj0011001010 请按照模板提问
                      轩窗听雨 @2693226252
                      @2693226252 解决了吗?
