    ros2的twist消息丢失
    cmdvel ros2-humble twist
      桥豆麻袋
      ros2的twist消息丢失
      我遇到了个奇怪的问题,反映在输出里面:
      Enter command: stop()
      [INFO] [1714134056.214406367] [move_robot]: Robot stopped
      Enter command: move_forward(0.2,2)
      Enter command:
      背景:我在编写完用指令控制小车以规定速度移动固定的距离时,发现stop命令可以执行,而move_forward(0.2,2)指令却无法发送twist消息,move_forward 方法的日志,没有正确调用。
      测试:代码在执行 move_forward 方法后立即退出了,而不等待机器人移动完毕,这可能是因为在发布 Twist 消息后,没有足够的时间给机器人移动到目标位置,我move_forward 方法后添加一个短暂的睡眠时间,发现还是没用;然后我在终端中输入命令来查看 /cmd_vel 话题消息,结果什么都没有,说明问题很可能出在发布速度命令的部分,但是我再次检查相关代码还是什么错误都没发现。
      希望可以得到帮助,万分感谢!
      整个程序代码:
      import rclpy
      from rclpy.node import Node
      from geometry_msgs.msg import Twist
      import time  # Import time for time management
      class MoveRobot(Node):
          def __init__(self):
              super().__init__('move_robot')
              self.publisher_ = self.create_publisher(Twist, 'cmd_vel', 10)
              self.speed = 0
              self.distance = 0
              self.timer_ = self.create_timer(0.1, self.timer_callback)
              self.start_time = 0
              self.command = None
          def timer_callback(self):
              if self.command == 'move_forward':
                  self.move_forward()
          def move_forward(self):
              twist = Twist()
              twist.linear.x = self.speed
              self.publisher_.publish(twist)
              self.get_logger().info('Published forward command with speed: {}'.format(self.speed))
              while time.time() - self.start_time < self.distance / self.speed:
                  time.sleep(0.1)
              self.stop()
          def stop(self):
              twist = Twist()
              self.get_logger().info('Robot stopped')
              self.command = None
          def parse_command(self, command):
              cmd_parts = command.split('(')
              cmd_name = cmd_parts[0]
              if cmd_name == 'stop':
                  self.stop()
                  return
              args = cmd_parts[1].strip(')').split(',')
              self.command = cmd_name
              self.speed = float(args[0])
              self.distance = float(args[1])
              self.start_time = time.time()  # Update start time using time.time()
      def main(args=None):
          rclpy.init(args=args)
          move_robot = MoveRobot()
          try:
              while rclpy.ok():
                  command = input('Enter command: ')
                  if command == 'exit':
                      break
                  move_robot.parse_command(command)
          finally:
              move_robot.destroy_node()
              rclpy.shutdown()
      if __name__ == '__main__':
        小鱼 技术大佬 @1787593592
        @1787593592 整个过程中缺少spin
