9.自定义接口RCLPY实战 错误
(base) ➜ src ros2 run example_interfaces_rclpy example_interfaces_control_02
[INFO] [1714230625.945848692] [example_interfaces_control_02]: 节点已启动:example_interfaces_control_02!
ModuleNotFoundError: No module named 'example_ros2_interfaces.example_ros2_interfaces_s__rosidl_typesupport_c'During handling of the above exception, another exception occurred:
File "/home/zhuohang/Documents/ros/pro4/src/install/example_interfaces_rclpy/lib/example_interfaces_rclpy/example_interfaces_control_02", line 33, in <module>
sys.exit(load_entry_point('example-interfaces-rclpy==0.0.0', 'console_scripts', 'example_interfaces_control_02')())
File "/home/zhuohang/Documents/ros/pro4/src/install/example_interfaces_rclpy/lib/python3.10/site-packages/example_interfaces_rclpy/example_interfaces_control_02.py", line 33, in main
node = ExampleInterfacesControl02("example_interfaces_control_02") # 新建一个节点
File "/home/zhuohang/Documents/ros/pro4/src/install/example_interfaces_rclpy/lib/python3.10/site-packages/example_interfaces_rclpy/example_interfaces_control_02.py", line 12, in init
self.client_ = self.create_client(MoveRobot,"move_robot")
msg_or_srv_type.class.import_type_support()
File "/home/zhuohang/Documents/ros/pro4/src/install/example_interfaces_rclpy/lib/python3.10/site-packages/example_ros2_interfaces/srv/_move_robot.py", line 268, in import_type_support
module = import_type_support('example_ros2_interfaces')
rosidl_generator_py.import_type_support_impl.UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'example_ros2_interfaces'
以上为错误信息,主要是想问一下那个example_ros2_interfaces包怎么引入,放在哪里,包里面有什么东西,这个包生成是按照7.ROS2接口介绍这个完成的,然后换了一个文件夹,就不知道应该放哪里,包要放什么东西了。
我也一样
怎么解决的 -
如在conda环境中使用,需保持conda环境中的python版本和ros2里的python版本一致,我这的是python3.10 。 已复现bug且解决。
