    dashing版安装navigation2报错rosdepc还有colcon build
    navigation2 dashing
    1.8k
    • 35088273523
      多读书
      wangjian@wangjian-Lenovo-Legion-Y7000:~/fishbot_ws$ rosdepc install -r --from-paths src --ignore-src --rosdistro $ROS_DISTRO -y
      欢迎使用国内版rosdep之rosdepc,我是作者小鱼!
      欢迎关注公众号《鱼香ROS》加入交流群
      小鱼rosdepc正式为您服务
      to system dependencies:
      nav2_behavior_tree: Cannot locate rosdep definition for [behaviortree_cpp_v3]
      nav2_bringup: Cannot locate rosdep definition for [slam_toolbox]
      smac_planner: Cannot locate rosdep definition for [ompl]
      nav2_bt_navigator: Cannot locate rosdep definition for [behaviortree_cpp_v3]
      nav2_util: Cannot locate rosdep definition for [launch_testing_ament_cmake]
      Continuing to install resolvable dependencies...
      #All required rosdeps installed successfully
      如果在使用过程中遇到任何问题,欢迎通过fishros.org.cn反馈,最后加入QQ交流群 686914208(入群口令:一键安装)
      wangjian@wangjian-Lenovo-Legion-Y7000:~/fishbot_ws$ colcon build --packages-up-to navigation2
      Starting >>> nav2_common
      Starting >>> nav_2d_msgs
      Finished <<< nav2_common [0.50s]
      Starting >>> nav2_msgs
      Starting >>> nav2_voxel_grid
      Finished <<< nav_2d_msgs [10.3s]
      Starting >>> dwb_msgs
      Finished <<< nav2_voxel_grid [13.1s]
      Finished <<< dwb_msgs [18.9s]
      Finished <<< nav2_msgs [36.6s]
      Starting >>> nav2_util
      --- stderr: nav2_util
      CMake Error at CMakeLists.txt:47 (find_package):
      By not providing "Findlaunch_testing_ament_cmake.cmake" in
      CMAKE_MODULE_PATH this project has asked CMake to find a package
      configuration file provided by "launch_testing_ament_cmake", but CMake did
      not find one.
      "launch_testing_ament_cmake" with any of the following names:
      launch_testing_ament_cmakeConfig.cmake
      launch_testing_ament_cmake-config.cmake
      Add the installation prefix of "launch_testing_ament_cmake" to
      CMAKE_PREFIX_PATH or set "launch_testing_ament_cmake_DIR" to a directory
      containing one of the above files. If "launch_testing_ament_cmake"
      installed.
      Failed <<< nav2_util [3.01s, exited with code 1]
      Summary: 5 packages finished [40.4s]
      1 package failed: nav2_util
      1 package had stderr output: nav2_util
      22 packages not processed
      wangjian@wangjian-Lenovo-Legion-Y7000:~/fishbot_ws$ navigation2
      navigation2:未找到命令
      wangjian@wangjian-Lenovo-Legion-Y7000:~/fishbot_ws$ source install/setup.bash
      wangjian@wangjian-Lenovo-Legion-Y7000:~/fishbot_ws$ ros2 pkg list | grep navigation2
      navigation2:未找到命令
      小鱼小 26932262522 3 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @3508827352
        @3508827352 手动安装下 sudo apt install ros-你的ROS版本代号-launch-testing-ament-cmake
          小鱼 技术大佬 @3508827352
          @3508827352 另外注意格式
          • 26932262522
            命里有我 @3508827352
            @3508827352 你好,我也遇到了和你一样的问题,colcon build失败,请问您解决了吗
