    运行launch文件报错
    launch ros2 humble
    3.8k
    • yudonghou123Y
      小猴同学
      系统ubuntu22.04 ros2 humble
      我在先后运行两个launch文件时,一个终端报出下面问题:
      <launch>
        <arg name="uuv_name" default="eca_a9"/>
        <!-- Vehicle's initial position -->
        <arg name="x" default="0"/>
        <arg name="y" default="0"/>
        <arg name="z" default="-20"/>
        <arg name="yaw" default="0.0"/>
        <arg name="gui_on" default="true"/>
        <arg name="record" default="false"/>
        <arg name="bag_filename" default="recording.bag"/>
        <arg name="use_ned_frame" default="false"/>
        <arg name="joy_id" default="0"/>
        <include file="$(find-pkg-share eca_a9_description)/launch/upload_eca_a9.launch">
          <arg name="namespace" value="$(var uuv_name)"/>
          <arg name="x" value="$(var x)"/>
          <arg name="y" value="$(var y)"/>
          <arg name="z" value="$(var z)"/>
          <arg name="yaw" value="$(var yaw)"/>
        </include>
        <!-- This node just reads the trajectory and waypoint topics and publishes
             visualization markers for RViz -->
        <group if="$(var gui_on)">
          <group>
            <push-ros-namespace namespace="$(var uuv_name)"/>
            <node  pkg="uuv_control_utils"
                   exec="trajectory_marker_publisher.py"
                   name="trajectory_marker_publisher"
                   output="screen">
               <remap from="trajectory" to="dp_controller/trajectory"/>
               <remap from="waypoints" to="dp_controller/waypoints"/>
               <remap from="reference" to="dp_controller/reference"/>
            </node>
          </group>
        </group>
        <include file="$(find-pkg-share eca_a9_control)/launch/start_nmb_sm_control.launch"/>
        <include file="$(find-pkg-share uuv_control_utils)/launch/send_waypoints_file.launch">
          <arg name="uuv_name" value="eca_a9"/>
          <arg name="filename" value="$(find-pkg-share eca_a9_gazebo)/config/waypoint_set.yaml"/>
          <arg name="interpolator" value="dubins"/>
        </include>
        <!-- Initialize the recording afo the simulation according to the record flag  -->
       <!--   <include file="$(find eca_a9_gazebo)/launch/record_demo.launch">
          <arg name="record" value="$(arg record)"/>
          <arg name="use_ned_frame" value="$(arg use_ned_frame)"/>
          <arg name="bag_filename" value="$(arg bag_filename)"/>
        </include> -->
      </launch>
      <launch>
          <arg name="teleop_on" default="false"/>
          <arg name="axis_yaw" default="0"/>
          <arg name="axis_x" default="4"/>
          <arg name="axis_y" default="3"/>
          <arg name="axis_z" default="1"/>
          <arg name="Kd" default="[24.328999405818507,95.16574836816616,25.943377407248825,0,6.388371356010936,79.2844976871164]"/>
          <arg name="Ki" default="[0.0010232768152540483,0.0010232768152540483,0.0010232768152540483,0,0.11901644069756079,0.11901644069756079]"/>
          <arg name="slope" default="[0.9903858668992097,0.9903858668992097,0.9903858668992097,0,0.20796465986893387,0.20796465986893387]"/>
          <arg name="look_ahead_delay" default="2.0"/>
          <arg name="min_thrust" default="40"/>
          <include file="$(find-pkg-share eca_a9_control)/launch/start_control_allocator.launch"/>
          <group>
            <node pkg="uuv_trajectory_control"
                  exec="rov_nmb_sm_controller.py"
                  name="rov_nmb_sm_controller"
                  output="screen"
                  if="$(var use_ned_frame)">
              <!-- Remap necessary topics -->
              <remap from="odom" to="pose_gt_ned"/>
              <remap from="input_trajectory" to="dp_controller/input_trajectory"/>
              <remap from="error" to="dp_controller/error"/>
              <remap from="thruster_output" to="thruster_manager/input_stamped"/>
              <remap from="auv_command_output" to="control_allocation/control_input"/>
              <!-- Controller parameters -->
              <param name="subst_value" value="true">
                  <param name="saturation" value="200"/>
                  <param name="thrusters_only" value="false"/>
                  <param name="Kd" value="$(var Kd)"/>
                  <param name="Ki" value="$(var Ki)"/>
                  <param name="slope" value="$(var slope)"/>
                  <param name="inertial_frame_id" value="world_ned"/>
                  <param name="max_forward_speed" value="3.0"/>
                  <param name="use_stamped_poses_only" value="false"/>
                  <param name="look_ahead_delay" value="$(var look_ahead_delay)"/>
                  <param name="min_thrust" value="$(var min_thrust)"/>
                  <param name="dubins">
                    <param name="radius" value="25"/>
                    <param name="max_pitch" value="0.09"/>
                  </param>
                 <!-- saturation: 200
                 thrusters_only: false
                 Kd: $(var Kd)
                 Ki: $(var Ki)
                 slope: $(var slope)
                 inertial_frame_id: world_ned
                 max_forward_speed: 3.0
                 use_stamped_poses_only: false
                 look_ahead_delay: $(var look_ahead_delay)
                 min_thrust: $(var min_thrust)
                 dubins:
                  radius: 25
                  max_pitch: 0.09 -->
              </param>
            </node>
                  output="screen"
                  unless="$(var use_ned_frame)">
              <remap from="odom" to="pose_gt"/>
                  <param name="inertial_frame_id" value="world"/>
                  </param>
                 Kd: $(var Kd)
                 Ki: $(var Ki)
                 slope: $(var slope)
                 dubins:
                   radius: 25
                  max_pitch: 0.09 -->
              </param>
            </node>
          </group>
              <node name="rviz" pkg="rviz2" exec="rviz2" output="screen" args="-d $(find-pkg-share eca_a9_control)/rviz/eca_a9_control.rviz"/>
          </group>
      </launch>
      终端输出问题:
      [ERROR] [launch]: Caught exception in launch (see debug for traceback): Caught exception when trying to load file of format [launch]: nested parameters and value attributes are mutually exclusive
      请问各位大佬,这是怎么回事呢?
      芜湖
      yudonghou123Y 1 条回复 最后回复 回复 引用 0
      • yudonghou123Y yudonghou123 将这个主题转为问答主题,在
      • yudonghou123Y
        小猴同学 @yudonghou123
        @yudonghou123 大佬们,我发现是这个launch文件出错了,大佬们能帮我看看是launch标签用的不对吗?
        <launch>
           <!--     <arg name="teleop_on" default="false"/>
            <arg name="axis_z" default="1"/> -->
            <arg name="subst_value" default="true"/>
            <arg name="saturation" default="200"/>
            <arg name="thrusters_only" default="false"/>
            <arg name="max_forward_speed" default="3.0"/>
            <arg name="use_stamped_poses_only" default="false"/>
            <arg name="inertial_frame_id" default="world"/><!-- 和use_ned_frame有关 -->
            <group if="$(var use_ned_frame)">
                    output="screen">
                    </param>
                </param>
              </node>
            </group>
            <group unless="$(var use_ned_frame)">
                    output="screen">
                <param name="subst_value" value="$(var subst_value)">
                    <param name="saturation" value="($var saturation)"/>
                    <param name="thrusters_only" value="($var thrusters_only)"/>
                    <param name="inertial_frame_id" value="$(var inertial_frame_id)"/>
                    <param name="max_forward_speed" value="$(var max_forward_speed)"/>
                    <param name="use_stamped_poses_only" value="$(var use_stamped_poses_only)"/>
                   </param>
                  </param>
              </node>
            </group>
            <!-- <group if="$(var gui_on)">
            </group> -->
        </launch>
        芜湖
          这个launch文件的格式看起来没有问题,但可能是缺少一些必要的节点或参数导致无法正常运行。您可以提供更多的错误信息或日志信息,以便更好地诊断问题所在。
          • yudonghou123Y
            小猴同学 @小伊
            @小伊 终端输出问题如下
            芜湖
              这个错误提示表明在加载一个 .launch 文件时出现了错误,可能是因为在该文件中同时使用了 <param> 标签和 value 属性,这两个是互斥的。
              你可以通过检查该 .launch 文件,找到并删除同时使用 <param> 和 value 的标签,或者将它们分别使用不同的标签进行定义。如果你仍然无法解决问题,请尝试提供更详细的错误信息和相关的代码片段,以便我们更好地帮助你解决问题。
              • yudonghou123Y
                小猴同学 @小伊
                @小伊 代码是这样的
                <launch>
                            output="screen">
                            </param>
                        </param>
                      </node>
                    </group>
                            output="screen">
                           </param>
                          </param>
                      </node>
                    </group>
                    </group> -->
                </launch>
                芜湖
                  因为帐号不够,导致您的问题处理时出现错误,如有帐号分享请发给小伊!
                  • yudonghou123Y
                    小猴同学 @小伊
                    @小伊 在launch文件出现这种问题怎么解决
                    芜湖
