moveit 3d感知碰撞检测
自己想将RGBD相机点云或深度信息生成octomap八叉树地图,用于机械臂碰撞检测,但无论是订阅点云话题还是深度话题生成八叉树地图都有问题。
一、使用点云
1. 文件描述
sensors_3d.yaml文件配置如下:
sensors: - sensor_plugin: occupancy_map_monitor/PointCloudOctomapUpdater point_cloud_topic: /camera/depth/cloudpoint max_range: 3.0 point_subsample: 1 padding_offset: 0.1 padding_scale: 1.0 max_update_rate: 1.0 filtered_cloud_topic: filtered_cloudrobot_moveit_sensor_manager.launch文件配置如下:
<launch> <param name="octomap_frame" type="string" value="base_link" /> <param name="octomap_resolution" type="double" value="0.05" /> <param name="max_range" type="double" value="5.0" /> <rosparam command="load" file="$(find robot_moveit_config)/config/sensors_3d.yaml" /> </launch>2. 问题描述
- 启动机械臂及相机,出现error:
[ERROR] [1678174747.334384818]: Failed to configure updater of type PointCloudUpdater
[ INFO] [1678174747.022084250]: rviz version 1.13.29 [ INFO] [1678174747.022134909]: compiled against Qt version 5.9.5 [ INFO] [1678174747.022151616]: compiled against OGRE version 1.9.0 (Ghadamon) [ INFO] [1678174747.029645233]: Forcing OpenGl version 0. [ INFO] [1678174747.175785274]: Stereo is NOT SUPPORTED [ INFO] [1678174747.175842817]: OpenGL device: Mesa DRI Intel(R) UHD Graphics (CML GT2) [ INFO] [1678174747.175865405]: OpenGl version: 3.0 (GLSL 1.3). [ INFO] [1678174747.321073047]: Publishing maintained planning scene on 'monitored_planning_scene' [ INFO] [1678174747.322693162]: MoveGroup debug mode is ON Starting planning scene monitors... [ INFO] [1678174747.322725369]: Starting planning scene monitor [ INFO] [1678174747.324119190]: Listening to '/planning_scene' [ INFO] [1678174747.324139491]: Starting world geometry update monitor for collision objects, attached objects, octomap updates. [ INFO] [1678174747.325355360]: Listening to '/collision_object' [ INFO] [1678174747.326541067]: Listening to '/planning_scene_world' for planning scene world geometry [ERROR] [1678174747.334384818]: Failed to configure updater of type PointCloudUpdater [ INFO] [1678174747.456998534]: Listening to '/attached_collision_object' for attached collision objects Planning scene monitors started. [ INFO] [1678174747.481787855]: Initializing OMPL interface using ROS parameters [ INFO] [1678174747.502816196]: Using planning interface 'OMPL' [ INFO] [1678174747.505507704]: Param 'default_workspace_bounds' was not set. Using default value: 10 [ INFO] [1678174747.505976933]: Param 'start_state_max_bounds_error' was set to 0.1 [ INFO] [1678174747.506200453]: Param 'start_state_max_dt' was not set. Using default value: 0.5 [ INFO] [1678174747.506649315]: Param 'start_state_max_dt' was not set. Using default value: 0.5 [ INFO] [1678174747.506877803]: Param 'jiggle_fraction' was set to 0.05 [ INFO] [1678174747.507102889]: Param 'max_sampling_attempts' was not set. Using default value: 100 [ INFO] [1678174747.507147464]: Using planning request adapter 'Add Time Parameterization' [ INFO] [1678174747.507166812]: Using planning request adapter 'Fix Workspace Bounds' [ INFO] [1678174747.507180821]: Using planning request adapter 'Fix Start State Bounds' [ INFO] [1678174747.507195990]: Using planning request adapter 'Fix Start State In Collision' [ INFO] [1678174747.507212386]: Using planning request adapter 'Fix Start State Path Constraints'二、使用深度图
1. 文件描述
sensors: - sensor_plugin: occupancy_map_monitor/DepthImageOctomapUpdater image_topic: /camera/depth/depth_raw queue_size: 5 near_clipping_plane_distance: 0.3 far_clipping_plane_distance: 5.0 shadow_threshold: 0.2 padding_scale: 4.0 padding_offset: 0.03 filtered_cloud_topic: filtered_cloudrobot_moveit_sensor_manager.launch文件配置如下:
- 启动机械臂及相机,出现error:
[ERROR] [1678175912.985854565]: Unexpected encoding type: 'mono16'. Ignoring input.,看着这原因应该是深度图输入格式有问题,是修改相机深度图编码格式吗?还是说,octomap 深度图订阅可以修改输入深度图格式?
请教大佬,这两种订阅话题格式出现的问题是由于什么原因导致的?还请指点一下解决方法,感谢!
