    QT订阅ROS2信息并发布
    ros2humble qt出错
    • yudonghou123Y
      小猴同学
      系统ubuntu22.04 ROS2 Humble
      大佬们,就是我想结合QT5写一个可以订阅ros2节点信息并显示的界面,我将功能包写成这样
      ├── CMakeLists.txt
      ├── CMakeLists.txt.user
      ├── include
      │ └── ros2_qt_display
      │ ├── mainwindow.h
      │ └── rclcomm.h
      ├── package.xml
      ├── src
      │ ├── main.cpp
      │ ├── mainwindow.cpp
      │ └── rclcomm.cpp
      └── ui
      └── mainwindow.ui
      我的mainwindow.h:
      #ifndef MAINWINDOW_H
      #define MAINWINDOW_H
      #include <QMainWindow>
      #include "rclcomm.h"
      #include <iostream>
      QT_BEGIN_NAMESPACE
      namespace Ui {
      class MainWindow;
      QT_END_NAMESPACE
      class MainWindow : public QMainWindow
          Q_OBJECT
      public:
          explicit MainWindow(QWidget *parent = nullptr);
          ~MainWindow();
      private:
          Ui::MainWindow *ui;
          rclcomm *commNode;
      public slots:
          void on_getimuyaw(QString);
          void on_getimupitch(QString);
          void on_getimuroll(QString);
          void on_getimulat(QString);
          void on_getimulon(QString);
          void on_getimualt(QString);
          void on_getimuxangvel(QString);
          void on_getimuyangvel(QString);
          void on_getimuzangvel(QString);
          void on_getimuxspef(QString);
          void on_getimuyspef(QString);
          void on_getimuzspef(QString);
          void on_getimunvel(QString);
          void on_getimuevel(QString);
          void on_getimuvelerr(QString);
          void on_pushButton02_clicked();
          void on_pushButton01_clicked();
      #endif // MAINWINDOW_H
      然后我在mainwindow.cpp中调用这些:
      #include "mainwindow.h"
      #include "ui_mainwindow.h"
      MainWindow::MainWindow(QWidget *parent) :
          QMainWindow(parent),
          ui(new Ui::MainWindow)
          ui->setupUi(this);
          connect(ui->pushButton01,SIGNAL(clicked(bool)),this,SLOT(on_pushButton01_clicked()));
          connect(ui->pushButton02,SIGNAL(clicked(bool)),this,SLOT(on_pushButton02_clicked()));
          commNode=new rclcomm();
          connect(commNode,SIGNAL(getimuyaw(QString)),this,SLOT(on_getimuyaw(QString)));
          connect(commNode,SIGNAL(getimupitch(QString)),this,SLOT(on_getimupitch(QString)));
          connect(commNode,SIGNAL(getimuroll(QString)),this,SLOT(on_getimuroll(QString)));
          connect(commNode,SIGNAL(getimulat(QString)),this,SLOT(on_getimulat(QString)));
          connect(commNode,SIGNAL(getimulon(QString)),this,SLOT(on_getimulon(QString)));
          connect(commNode,SIGNAL(getimualt(QString)),this,SLOT(on_getimualt(QString)));
          connect(commNode,SIGNAL(getimuxangvel(QString)),this,SLOT(on_getimuxangvel(QString)));
          connect(commNode,SIGNAL(getimuyangvel(QString)),this,SLOT(on_getimuyangvel(QString)));
          connect(commNode,SIGNAL(getimuzangvel(QString)),this,SLOT(on_getimuzangvel(QString)));
          connect(commNode,SIGNAL(getimuxspef(QString)),this,SLOT(on_getimuxspef(QString)));
          connect(commNode,SIGNAL(getimuyspef(QString)),this,SLOT(on_getimuyspef(QString)));
          connect(commNode,SIGNAL(getimuzspef(QString)),this,SLOT(on_getimuzspef(QString)));
          connect(commNode,SIGNAL(getimunvel(QString)),this,SLOT(on_getimunvel(QString)));
          connect(commNode,SIGNAL(getimuevel(QString)),this,SLOT(on_getimuevel(QString)));
          connect(commNode,SIGNAL(getimuvelerr(QString)),this,SLOT(on_getimuvelerr(QString)));
      void MainWindow::on_getimuyaw(QString yaw){
          ui->textEdit_1->clear();
          ui->textEdit_1->setText(yaw);
      void MainWindow::on_getimupitch(QString pitch){
          ui->textEdit_2->clear();
          ui->textEdit_2->setText(pitch);
      void MainWindow::on_getimuroll(QString roll){
          ui->textEdit_3->clear();
          ui->textEdit_3->setText(roll);
      void MainWindow::on_getimulat(QString lat){
          ui->textEdit_4->clear();
          ui->textEdit_4->setText(lat);
      void MainWindow::on_getimulon(QString lon){
          ui->textEdit_5->clear();
          ui->textEdit_5->setText(lon);
      void MainWindow::on_getimualt(QString alt){
          ui->textEdit_6->clear();
          ui->textEdit_6->setText(alt);
      void MainWindow::on_getimuxangvel(QString xangvel){
          ui->textEdit_7->clear();
          ui->textEdit_7->setText(xangvel);
      void MainWindow::on_getimuyangvel(QString yangvel){
          ui->textEdit_8->clear();
          ui->textEdit_8->setText(yangvel);
      void MainWindow::on_getimuzangvel(QString zangvel){
          ui->textEdit_9->clear();
          ui->textEdit_9->setText(zangvel);
      void MainWindow::on_getimuxspef(QString xspef){
          ui->textEdit_10->clear();
          ui->textEdit_10->setText(xspef);
      void MainWindow::on_getimuyspef(QString yspef){
          ui->textEdit_11->clear();
          ui->textEdit_11->setText(yspef);
      void MainWindow::on_getimuzspef(QString zspef){
          ui->textEdit_12->clear();
          ui->textEdit_12->setText(zspef);
      void MainWindow::on_getimunvel(QString nvel){
          ui->textEdit_13->clear();
          ui->textEdit_13->setText(nvel);
      void MainWindow::on_getimuevel(QString evel){
          ui->textEdit_15->clear();
          ui->textEdit_15->setText(evel);
      void MainWindow::on_getimuvelerr(QString velerr){
          ui->textEdit_15->setText(velerr);
      void MainWindow::on_pushButton01_clicked()
          commNode->start();
      void MainWindow::on_pushButton02_clicked()
      MainWindow::~MainWindow()
          delete ui;
      我的终端始终爆出下面的问题:
      --- stderr: ros2_qt_display
      /usr/bin/ld: /usr/lib/gcc/x86_64-linux-gnu/11/../../../x86_64-linux-gnu/Scrt1.o: in function `_start':
      (.text+0x1b): undefined reference to `main'
      /usr/bin/ld: CMakeFiles/ros2_qt_display.dir/include/ros2_qt_display/moc_mainwindow.cpp.o: in function `MainWindow::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)':
      moc_mainwindow.cpp:(.text+0x93): undefined reference to `MainWindow::on_getimuyaw(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0xd1): undefined reference to `MainWindow::on_getimupitch(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x10f): undefined reference to `MainWindow::on_getimuroll(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x14d): undefined reference to `MainWindow::on_getimulat(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x18b): undefined reference to `MainWindow::on_getimulon(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x1c9): undefined reference to `MainWindow::on_getimualt(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x207): undefined reference to `MainWindow::on_getimuxangvel(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x245): undefined reference to `MainWindow::on_getimuyangvel(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x283): undefined reference to `MainWindow::on_getimuzangvel(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x2c1): undefined reference to `MainWindow::on_getimuxspef(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x2ff): undefined reference to `MainWindow::on_getimuyspef(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x33d): undefined reference to `MainWindow::on_getimuzspef(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x37b): undefined reference to `MainWindow::on_getimunvel(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x3b9): undefined reference to `MainWindow::on_getimuevel(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x3f4): undefined reference to `MainWindow::on_getimuvelerr(QString)'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x40e): undefined reference to `MainWindow::on_pushButton02_clicked()'
      /usr/bin/ld: moc_mainwindow.cpp:(.text+0x41c): undefined reference to `MainWindow::on_pushButton01_clicked()'
      /usr/bin/ld: CMakeFiles/ros2_qt_display.dir/include/ros2_qt_display/moc_mainwindow.cpp.o:(.data.rel.ro._ZTV10MainWindow[_ZTV10MainWindow]+0x28): undefined reference to `MainWindow::~MainWindow()'
      /usr/bin/ld: CMakeFiles/ros2_qt_display.dir/include/ros2_qt_display/moc_mainwindow.cpp.o:(.data.rel.ro._ZTV10MainWindow[_ZTV10MainWindow]+0x30): undefined reference to `MainWindow::~MainWindow()'
      /usr/bin/ld: CMakeFiles/ros2_qt_display.dir/include/ros2_qt_display/moc_mainwindow.cpp.o:(.data.rel.ro._ZTV10MainWindow[_ZTV10MainWindow]+0x1c8): undefined reference to `non-virtual thunk to MainWindow::~MainWindow()'
      /usr/bin/ld: CMakeFiles/ros2_qt_display.dir/include/ros2_qt_display/moc_mainwindow.cpp.o:(.data.rel.ro._ZTV10MainWindow[_ZTV10MainWindow]+0x1d0): undefined reference to `non-virtual thunk to MainWindow::~MainWindow()'
      /usr/bin/ld: CMakeFiles/ros2_qt_display.dir/include/ros2_qt_display/moc_rclcomm.cpp.o:(.data.rel.ro._ZTV7rclcomm[_ZTV7rclcomm]+0x70): undefined reference to `rclcomm::run()'
      gmake[2]: *** [CMakeFiles/ros2_qt_display.dir/build.make:208:ros2_qt_display] 错误 1
      gmake[1]: *** [CMakeFiles/Makefile2:137:CMakeFiles/ros2_qt_display.dir/all] 错误 2
      请问这是怎么回事呢,我用的VScode,请各位大佬提醒一下,谢谢
      芜湖
