    树莓派 ubuntu18.04一键安装ros melodic安装失败
    一键安装 ubuntu18.04
    1.3k
    • 11439738351
      Welcome to Ubuntu 18.04.5 LTS (GNU/Linux 5.4.0-1015-raspi aarch64)
      • Documentation: https://help.ubuntu.com
      • Management: https://landscape.canonical.com
      • Support: https://ubuntu.com/advantage
      System information as of Fri Mar 10 01:48:42 UTC 2023
      System load: 1.0 Processes: 127
      Usage of /: 6.2% of 28.53GB Users logged in: 1
      Memory usage: 14% IP address for wlan0: 192.168.43.253
      Swap usage: 0%
      • Strictly confined Kubernetes makes edge and IoT secure. Learn how MicroK8s
        just raised the bar for easy, resilient and secure K8s cluster deployment.
        https://ubuntu.com/engage/secure-kubernetes-at-the-edge
      238 packages can be updated.
      193 updates are security updates.
      New release '20.04.5 LTS' available.
      Run 'do-release-upgrade' to upgrade to it.
      Your Hardware Enablement Stack (HWE) is supported until April 2023.
      Last login: Fri Mar 10 01:46:11 2023 from 192.168.43.215
      jjj@jjj:~$ wget http://fishros.com/install -O fishros && bash fishros
      --2023-03-10 01:48:46-- http://fishros.com/install
      --2023-03-10 01:48:46-- http://fishros.com/install/
      Length: 582 [application/octet-stream]
      Saving to: ‘fishros’
      fishros 100%[===================>] 582 --.-KB/s in 0s
      2023-03-10 01:48:46 (25.6 MB/s) - ‘fishros’ saved [582/582]
      [sudo] password for jjj:
      E: Could not get lock /var/lib/dpkg/lock-frontend - open (11: Resource temporarily unavailable)
      E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
      --2023-03-10 01:48:51-- http://fishros.com/install/install1s/tools/base.py
      Length: 42195 (41K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 41.21K --.-KB/s in 0.1s
      2023-03-10 01:48:51 (341 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [42195/42195]
      [-]Result:success
      基础检查通过...
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      [6]:一键安装:nodejs
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [77]:测试模式:运行自定义工具测试
      [0]:quit
      请输入[]内的数字以选择:1
      --2023-03-10 01:48:58-- http://fishros.com/install/install1s/tools/tool_install_ros.py
      Length: 19050 (19K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 18.60K --.-KB/s in 0.08s
      2023-03-10 01:48:58 (243 KB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [19050/19050]
      --2023-03-10 01:48:58-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
      Length: 2457 (2.4K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 2.40K --.-KB/s in 0.001s
      2023-03-10 01:48:58 (1.85 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2457/2457]
      --2023-03-10 01:48:58-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
      Length: 7511 (7.3K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 7.33K --.-KB/s in 0.1s
      2023-03-10 01:48:59 (61.2 KB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [7511/7511]
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      [0]:quit
      请输入[]内的数字以选择:1
      欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
      请选择换源方式,如果不知道选什么请选2
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      [0]:quit
      请输入[]内的数字以选择:2
      [-]Result:success
      删除一个资源文件
      [-]Result:success
      [-]Result:success
      [-]Result:success
      检测到当前系统架构为[arm64:bionic],正在为你更换对应源..
      替换完成,尝试第一次更新....
      [-]Result:success st --upgradable' to see them.see
      搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
      ['Hit:1 https://mirrors.ustc.edu.cn/ubuntu-ports bionic InRelease', 'Hit:2 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates InRelease', 'Hit:3 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports InRelease', 'Hit:4 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security InRelease', 'Reading package lists...', 'Building dependency tree...', 'Reading state information...', "226 packages can be upgraded. Run 'apt list --upgradable' to see them."]
      镜像修复完成.....
      [/]libcurl3-gnutls - easy-to-use client-side URL transfer library (GnuTLS flavou[/]libcurl4-gnutls-dev - development files and documentation for libcurl (GnuTLS[]libcurl4-nss-dev - development files and documentation for libcurl (NSS flavo[|]libcurl4-openssl-dev - development files and documentation for libcurl (OpenS[/]libstrongswan-extra-plugins - strongSwan utility and crypto library (extra pl[|]cl-curry-compose-reader-macros - Reader macros for function partial applicati[|]flickcurl-doc - utilities to call the Flickr API from command line - document[-]gnupg1 - GNU privacy guard - a PGP implementation (deprecated "classic" versi[]golang-github-moul-http2curl-dev - Go package for convert Golang's http.Reque[]kubuntu-wallpapers-bionic - Selection of classic KDE wallpapers for Bionic Be[|]libcupt4-2-downloadmethod-curl - flexible package manager -- libcurl download[]libcurl-openssl1.0-dev - development files and documentation for libcurl (Ope[-]libflickcurl0-dbg - C library for accessing the Flickr API - debugging symbol[]libghc-curl-doc - Documentation for the libcurl Haskell bindings; documentati[|]libghc-curl-prof - Profiling libraries for the libcurl Haskell bindings; prof[-]libghc-hxt-doc - collection of tools for processing XML with Haskell; documen[]libghc-hxt-http-doc - Interface to native Haskell HTTP package HTTP; document[|]libghc-hxt-http-prof - Interface to native Haskell HTTP package HTTP; profili[-]libghc-hxt-prof - collection of tools for processing XML with Haskell; profil[/]libresource-retriever-dev - Robot OS resource_retriever library - development[]libwsman-curl-client-transport1 - Open Web Services Manager run-time librarie[-]Result:success age - all developer toolsnt filesMPD
      [-]Result:code:100
      [-]Result:code:100
      [-]Result:success
      [-]Result:success
      [|]Get:2 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu bionic InRelease [4680 [|]Get:6 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic Release.gpg [833 [/]Get:8 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu bionic/main arm64 Packa[|]Get:10 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic/main arm64 Packa[-]Result:success st --upgradable' to see them.
      [/]ros-melodic-end-effector - End-Effector package: provides a ROS-based set of []ros-melodic-ros-base - A metapackage which extends ros_core and includes other basic non-robot tools like actionlib, dynamic reconfigure, nodelets, and plugi[|]ros-bouncy-ros-base - A package which extends 'ros_core' and includes other b[-]ros-crystal-ros-base - A package which extends 'ros_core' and includes other [/]ros-dashing-ros-base - A package which extends 'ros_core' and includes other []ros-eloquent-ros-base - A package which extends 'ros_core' and includes other[-]Result:success
      [1]:melodic(ROS1)
      [2]:bouncy(ROS2)
      [3]:crystal(ROS2)
      [4]:dashing(ROS2)
      [5]:eloquent(ROS2)
      [0]:quit
      请输入[]内的数字以选择:1
      请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
      [1]:melodic(ROS1)桌面版
      [2]:melodic(ROS1)基础版(小)
      [0]:quit
      请输入[]内的数字以选择:1
      [|]aptitude-common - architecture independent files for the aptitude package man[-]aptitude-doc-en - English manual for aptitude, a terminal-based package manag[/]libcwidget-dev - high-level terminal interface library for C++ (development f[-]apticron-systemd - Simple tool to mail about pending package updates - system[]aptitude-doc-es - Spanish manual for aptitude, a terminal-based package manag[|]aptitude-doc-fi - Finnish manual for aptitude, a terminal-based package manag[-]aptitude-doc-fr - French manual for aptitude, a terminal-based package manage[/]aptitude-doc-it - Italian manual for aptitude, a terminal-based package manag[]aptitude-doc-ja - Japanese manual for aptitude, a terminal-based package mana[-]aptitude-doc-ru - Russian manual for aptitude, a terminal-based package manag[-]gbrainy - brain teaser game and trainer to have fun and to keep your brain tr[-]Result:success end for Debian
      [-]Result:code:100
      [-]Result:code:100
      [-]Result:code:100
      [-]Result:code:100
      []python-rosdep2 - rosdep package manager abstraction tool for Robot OS (Python[-]Result:success nager abstraction tool for ROS
      [-]Result:code:100
      [-]Result:code:2
      [-]Result:code:2
        小鱼 技术大佬 @1143973835
        @1143973835 在 树莓派 ubuntu18.04一键安装ros melodic安装失败 中说:
        试试这句指令
