    roscore验证失败,Ubuntu 22.04.2 LTS
    roscore ros2
    • 13532571281
      荔枝冰箱
      loujieyao@loujieyao-LEGION:~$ roscore
      File "/usr/bin/roscore", line 37, in <module>
      from roslaunch.nodeprocess import DEFAULT_TIMEOUT_SIGINT, DEFAULT_TIMEOUT_SIGTERM
      File "/usr/lib/python3/dist-packages/roslaunch/init.py", line 62, in <module>
      from .scriptapi import ROSLaunch
      File "/usr/lib/python3/dist-packages/roslaunch/scriptapi.py", line 42, in <module>
      import roslaunch.parent
      File "/usr/lib/python3/dist-packages/roslaunch/parent.py", line 54, in <module>
      import roslaunch.server
      File "/usr/lib/python3/dist-packages/roslaunch/server.py", line 80, in <module>
      from rosgraph_msgs.msg import Log
      ImportError: cannot import name 'Log' from 'rosgraph_msgs.msg' (/opt/ros/humble/local/lib/python3.10/dist-packages/rosgraph_msgs/msg/init.py)
        小鱼 技术大佬 @1353257128
        @1353257128 ubuntu22.04没有对应的ros版本吧
