    jetson ros2-foxy 自定义消息
    ros2-foxy jetson python action
    506
    • 11615562431
      R.
      求指教!
      我在jetson上用一键安装的代码,安装了ros2-foxy版本,看起来环境没有问题。此时,我自定义了action文件,并用python搭建了一个action server和client。在我本地机器上(x86)上没有问题,但是在Jetson上运行报错(图片上传老是报错,复制的控制台日志):
      (py38) nvidia@nvidia-desktop:/mnt/work_dir/robot_ros/modules/grasp_det_action_client_node$ python grasp_action_client.py
      File "/opt/ros/foxy/lib/python3.8/site-packages/rosidl_generator_py/import_type_support_impl.py", line 46, in import_type_support
      return importlib.import_module(module_name, package=pkg_name)
      File "/home/nvidia/archiconda3/envs/py38/lib/python3.8/importlib/init.py", line 127, in import_module
      File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
      File "<frozen importlib._bootstrap>", line 991, in _find_and_load
      File "<frozen importlib._bootstrap>", line 973, in _find_and_load_unlocked
      ModuleNotFoundError: No module named 'robot_interfaces.robot_interfaces_s__rosidl_typesupport_c'
      File "grasp_action_client.py", line 74, in <module>
      File "grasp_action_client.py", line 68, in main
      action_client = GraspActionClient()
      File "grasp_action_client.py", line 17, in init
      self._action_client = ActionClient(self, GraspAction, 'grasp_det')
      File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/action/client.py", line 148, in init
      check_for_type_support(action_type)
      File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/type_support.py", line 29, in check_for_type_support
      msg_type.class.import_type_support()
      File "/mnt/work_dir/robot_ros/install/robot_interfaces/lib/python3.7/site-packages/robot_interfaces/action/_grasp_action.py", line 1186, in import_type_support
      module = import_type_support('robot_interfaces')
      File "/opt/ros/foxy/lib/python3.8/site-packages/rosidl_generator_py/import_type_support_impl.py", line 48, in import_type_support
      raise UnsupportedTypeSupport(pkg_name)
      rosidl_generator_py.import_type_support_impl.UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'robot_interfaces'
      Exception ignored in: <function ActionClient.del at 0xffff9c26b280>
      File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/action/client.py", line 605, in del
      self.destroy()
      File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/action/client.py", line 596, in destroy
      if self._client_handle is None:
      AttributeError: 'ActionClient' object has no attribute '_client_handle'
      测试python调用官方自带的 action_tutorials_interfaces.action.Fibonacci
      没有问题,用C++调用自定义的action也没有问题,python调用自定义的action就报错。
      求各位大佬解惑
      11615562431 1 条回复 最后回复 回复 引用 0
      • 11615562431
        R. @1161556243
        这是Cmakelist
        project(robot_interfaces)
        # Default to C99
        if(NOT CMAKE_C_STANDARD)
          set(CMAKE_C_STANDARD 99)
        endif()
        # Default to C++14
        if(NOT CMAKE_CXX_STANDARD)
          set(CMAKE_CXX_STANDARD 14)
        endif()
        endif()
        # find dependencies
          "msg/ObjectDetMsg1.msg"
          "msg/ObjectDetMsg2.msg"
          "msg/GraspMsg.msg"
          "msg/SuperGlueMsg.msg"
          "action/SuperGlueAction.action"
          "action/ObjectAction.action"
          "action/GraspAction.action"
        if(BUILD_TESTING)
          # uncomment the line when a copyright and license is not present in all source files
          #set(ament_cmake_copyright_FOUND TRUE)
          # uncomment the line when this package is not in a git repo
          #set(ament_cmake_cpplint_FOUND TRUE)
        endif()
        ament_package()
        • 11615562431
          R. @1161556243
          这是package
          <?xml version="1.0"?>
          <package format="3">
            <name>robot_interfaces</name>
            <version>0.0.0</version>
            <maintainer email="zr@todo.todo">zr</maintainer>
            <license>TODO: License declaration</license>
            <build_depend>rosidl_default_generators</build_depend>
            <exec_depend>rosidl_default_runtime</exec_depend>
            <export>
            </export>
          </package>
          • 11615562431
            R. @1161556243
            在初始化的时候就报错了,但是colcon build没有报错,并且ros2 interface show也可以看到到action的内容
            import rclpy
            from rclpy.action import ActionClient
            from rclpy.node import Node
            from robot_interfaces.action import GraspAction
            class GraspActionClient(Node):
                def __init__(self):
                    super().__init__('Grasp_action_client')
            • 11615562431
              R. @1161556243
              解决了,原因是python版本不匹配的问题
              在colcon build的时候,不知道为什么调用的是python3.7(改了默认的系统python路径也不行),导致编译出的so都是py37的。而我运行程序的conda环境是python3.8的,加载so就报错了。所以在colcon build之前,在cmakelist中,set指定下python3.8路径,就可以了
              • 11615562431 1161556243 将这个主题标记为已解决,在
