    树莓派4b Ubuntu 18.04.5 LTS (GNU/Linux 5.4.0-1015-raspi armv7l) 一键安装失败
    ubuntu18.04 树莓派 4b ros一键安装
    • 28979453232
      ZERO ∞
      Welcome to Ubuntu 18.04.5 LTS (GNU/Linux 5.4.0-1015-raspi armv7l)
      Documentation: https://help.ubuntu.com
      Management: https://landscape.canonical.com
      Support: https://ubuntu.com/advantage
      System information as of Wed Mar 22 14:13:02 CST 2023
      System load: 2.97 Processes: 165
      Usage of /: 16.1% of 28.96GB Users logged in: 0
      Memory usage: 5% IP address for wlan0: 192.168.137.104
      Swap usage: 0%
      Strictly confined Kubernetes makes edge and IoT secure. Learn how MicroK8s
      just raised the bar for easy, resilient and secure K8s cluster deployment.
      https://ubuntu.com/engage/secure-kubernetes-at-the-edge
      Introducing Expanded Security Maintenance for Applications.
      Receive updates to over 25,000 software packages with your
      Ubuntu Pro subscription. Free for personal use.
      https://ubuntu.com/pro
      238 packages can be updated.
      193 updates are security updates.
      New release '20.04.5 LTS' available.
      Run 'do-release-upgrade' to upgrade to it.
      Your Hardware Enablement Stack (HWE) is supported until April 2023.
      Last login: Wed Mar 22 14:06:53 2023 from 192.168.137.1
      pi@ubuntu:~$ wget http://fishros.com/install -O fishros && bash fishros
      --2023-03-22 14:13:36-- http://fishros.com/install
      --2023-03-22 14:13:37-- http://fishros.com/install/
      Length: 582 [application/octet-stream]
      Saving to: ‘fishros’
      fishros 100%[===================>] 582 --.-KB/s in 0s
      2023-03-22 14:13:37 (14.7 MB/s) - ‘fishros’ saved [582/582]
      [sudo] password for pi:
      Sorry, try again.
      Reading package lists... Done
      Building dependency tree
      python3-yaml is already the newest version (3.12-1build2).
      python3-yaml set to manually installed.
      The following NEW packages will be installed:
      python3-distro
      0 upgraded, 1 newly installed, 0 to remove and 212 not upgraded.
      Need to get 11.2 kB of archives.
      After this operation, 58.4 kB of additional disk space will be used.
      Get:1 http://mirrors.aliyun.com/ubuntu-ports bionic/universe armhf python3-distro all 1.0.1-2 [11.2 kB]
      Fetched 11.2 kB in 0s (59.1 kB/s)
      Selecting previously unselected package python3-distro.
      (Reading database ... 169188 files and directories currently installed.)
      Preparing to unpack .../python3-distro_1.0.1-2_all.deb ...
      Unpacking python3-distro (1.0.1-2) ...
      Setting up python3-distro (1.0.1-2) ...
      --2023-03-22 14:14:33-- http://fishros.com/install/install1s/tools/base.py
      Length: 42195 (41K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 41.21K 47.0KB/s in 0.9s
      2023-03-22 14:14:34 (47.0 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [42195/42195]
      [-]Result:success
      基础检查通过...
      .-~-._ _.-~-.
      .' ~. .~ .__ .'// 开卷有益 \./ 书山有路 \ .
      .'// 可以多看看小鱼的文章 | 关注公众号鱼香ROS \ . .'// .-~"~~~~-._ | _,-~~~~"~-. \.
      |/__`
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      [6]:一键安装:nodejs
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [77]:测试模式:运行自定义工具测试
      [0]:quit
      请输入[]内的数字以选择:1
      --2023-03-22 14:15:19-- http://fishros.com/install/install1s/tools/tool_install_ros.py
      Length: 19050 (19K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 18.60K --.-KB/s in 0.04s
      2023-03-22 14:15:19 (426 KB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [19050/19050]
      --2023-03-22 14:15:19-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
      Length: 2457 (2.4K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 2.40K --.-KB/s in 0s
      2023-03-22 14:15:19 (30.8 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2457/2457]
      --2023-03-22 14:15:19-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
      Length: 7511 (7.3K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 7.33K --.-KB/s in 0.001s
      2023-03-22 14:15:19 (7.26 MB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [7511/7511]
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      [0]:quit
      请输入[]内的数字以选择:1
      欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
      请选择换源方式,如果不知道选什么请选2
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      [0]:quit
      请输入[]内的数字以选择:2
      [-]Result:success
      删除一个资源文件
      [-]Result:success
      [-]Result:success
      [-]Result:success
      检测到当前系统架构为[arm64:bionic],正在为你更换对应源..
      替换完成,尝试第一次更新....
      [|]Get:2 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates InRelease [88.7[-]Get:3 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports InRelease [83[/]Get:4 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security InRelease [88.[]Get:5 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/main armhf Packages [96[|]Get:6 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/main Translation-en [51[-]Get:7 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/restricted armhf Packag[/]Get:8 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/restricted Translation-[]Get:9 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/universe armhf Packages [8269 kB]
      [|]Get:10 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/universe Translation-e[-]Get:11 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/multiverse armhf Packa[/]Get:12 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/multiverse Translation[]Get:13 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf Pac[|]Get:14 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main Translati[-]Get:15 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/restricted arm[/]Get:16 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/restricted Tra[]Get:17 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/universe armhf[|]Get:18 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/universe Trans[-]Get:19 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/multiverse arm[/]Get:20 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/multiverse Tra[]Get:21 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports/main armhf P[|]Get:22 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports/main Transla[-]Get:23 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports/universe arm[/]Get:24 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports/universe Tra[]Get:25 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/main armhf Pa[|]Get:26 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/main Translat[-]Get:27 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/restricted ar[/]Get:28 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/restricted Tr[]Get:29 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/universe armh[|]Get:30 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/universe Tran[-]Get:31 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/multiverse ar[/]Get:32 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/multiverse Tr[-]Result:success st --upgradable' to see them.
      搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
      ['Get:1 https://mirrors.ustc.edu.cn/ubuntu-ports bionic InRelease [242 kB]', 'Get:2 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates InRelease [88.7 kB]', 'Get:3 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports InRelease [83.3 kB]', 'Get:4 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security InRelease [88.7 kB]', 'Get:5 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/main armhf Packages [968 kB]', 'Get:6 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/main Translation-en [516 kB]', 'Get:7 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/restricted armhf Packages [8360 B]', 'Get:8 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/restricted Translation-en [3584 B]', 'Get:9 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/universe armhf Packages [8269 kB]', 'Get:10 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/universe Translation-en [4941 kB]', 'Get:11 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/multiverse armhf Packages [129 kB]', 'Get:12 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/multiverse Translation-en [108 kB]', 'Get:13 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf Packages [1398 kB]', 'Get:14 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main Translation-en [535 kB]', 'Get:15 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/restricted armhf Packages [13.3 kB]', 'Get:16 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/restricted Translation-en [163 kB]', 'Get:17 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/universe armhf Packages [1602 kB]', 'Get:18 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/universe Translation-en [413 kB]', 'Get:19 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/multiverse armhf Packages [6200 B]', 'Get:20 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/multiverse Translation-en [6088 B]', 'Get:21 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports/main armhf Packages [53.1 kB]', 'Get:22 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports/main Translation-en [14.6 kB]', 'Get:23 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports/universe armhf Packages [17.7 kB]', 'Get:24 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports/universe Translation-en [8668 B]', 'Get:25 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/main armhf Packages [1119 kB]', 'Get:26 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/main Translation-en [449 kB]', 'Get:27 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/restricted armhf Packages [9412 B]', 'Get:28 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/restricted Translation-en [158 kB]', 'Get:29 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/universe armhf Packages [1066 kB]', 'Get:30 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/universe Translation-en [300 kB]', 'Get:31 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/multiverse armhf Packages [2668 B]', 'Get:32 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/multiverse Translation-en [3928 B]', 'Fetched 22.8 MB in 3min 13s (118 kB/s)', 'Reading package lists...', 'Building dependency tree...', 'Reading state information...', "212 packages can be upgraded. Run 'apt list --upgradable' to see them."]
      镜像修复完成.....
      [-]Result:success st --upgradable' to see them.see
      [/]libcurl3-gnutls - easy-to-use client-side URL transfer library (GnuTLS flavou[/]libcurl4-gnutls-dev - development files and documentation for libcurl (GnuTLS[]libcurl4-nss-dev - development files and documentation for libcurl (NSS flavo[|]libcurl4-openssl-dev - development files and documentation for libcurl (OpenS[/]libstrongswan-extra-plugins - strongSwan utility and crypto library (extra pl[|]cl-curry-compose-reader-macros - Reader macros for function partial applicati[|]flickcurl-doc - utilities to call the Flickr API from command line - document[-]gnupg1 - GNU privacy guard - a PGP implementation (deprecated "classic" versi[]golang-github-moul-http2curl-dev - Go package for convert Golang's http.Reque[]kubuntu-wallpapers-bionic - Selection of classic KDE wallpapers for Bionic Be[|]libcupt4-2-downloadmethod-curl - flexible package manager -- libcurl download[]libcurl-openssl1.0-dev - development files and documentation for libcurl (Ope[-]libflickcurl0-dbg - C library for accessing the Flickr API - debugging symbol[]libghc-curl-doc - Documentation for the libcurl Haskell bindings; documentati[|]libghc-curl-prof - Profiling libraries for the libcurl Haskell bindings; prof[-]libghc-hxt-doc - collection of tools for processing XML with Haskell; documen[]libghc-hxt-http-doc - Interface to native Haskell HTTP package HTTP; document[|]libghc-hxt-http-prof - Interface to native Haskell HTTP package HTTP; profili[-]libghc-hxt-prof - collection of tools for processing XML with Haskell; profil[/]libresource-retriever-dev - Robot OS resource_retriever library - development[]libwsman-curl-client-transport1 - Open Web Services Manager run-time librarie[-]Result:success age - all developer toolsnt filesMPD
      [-]Get:1 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf curl[/]Get:2 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf libc[-]Result:success buntu1.2) ...58.0-2ubuntu3.9) ...
      []Get:1 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf gpg-[|]Get:2 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf dirm[-]Get:3 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf gnup[/]Get:4 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf gpg []Get:5 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf gnup[|]Get:6 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf gpg-[-]Get:7 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf gpgs[/]Get:8 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf gpgc[]Get:9 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf gnup[|]Get:10 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf gpg[-]Get:11 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf gpg[/]Get:12 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/universe armhf[-]Result:success untu0.1) ... .....nstalled.)...
      [-]Result:success
      [-]Result:success
      [|]Get:6 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu bionic InRelease [4680 [/]Get:8 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic Release.gpg [833 []Get:9 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu bionic/main arm64 Packa[|]Get:10 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic/main arm64 Packa[-]Result:success st --upgradable' to see them.
      [-]Result:success e development metapackageKerberos
      [-]Result:success
      [/]Get:8 https://repo.huaweicloud.com/ros2/ubuntu bionic/main arm64 Packages [66[|]Get:10 https://repo.huaweicloud.com/ros/ubuntu bionic/main arm64 Packages [78[-]Result:success st --upgradable' to see them.
      [-]Result:success
      [|]Get:8 http://packages.ros.org/ros2/ubuntu bionic/main arm64 Packages [660 kB]
      [-]Result:success st --upgradable' to see them.044 kB]
      根据您的系统,为您推荐安装源为['https://packages.ros.org/ros/ubuntu/', 'https://packages.ros.org/ros2/ubuntu/']
      [-]Result:success
      [/] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected. Could not handshake: Error in th[|] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected. Could not handshake: Error in th[-]Result:code:100 134 443]
      检测到发生证书校验错误['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', "E: The repository 'https://packages.ros.org/ros/ubuntu bionic Release' does not have a Release file.\n", "E: The repository 'https://packages.ros.org/ros2/ubuntu bionic Release' no longer has a Release file.\n"],自动取消https校验,如有需要请手动删除:rm /etc/apt/apt.conf.d/99verify-peer.conf
      Run CMD Task:[touch /etc/apt/apt.conf.d/99verify-peer.conf]
      [-]Result:success
      Run CMD Task:[echo "Acquire { https::Verify-Peer false }" > /etc/apt/apt.conf.d/99verify-peer.conf]
      [-]Result:success
      [-]Result:success st --upgradable' to see them.786 kB]
      [-]Result:code:2
      [-]Result:code:2
