    树莓派一键安装ros melodic安装失败
    树莓派一键安装 一键安装ros1失败
    • niuniu_niu1N
      niuniu_niu1
      pi@raspberrypi:~ $ lsb_release -a
      No LSB modules are available.
      Distributor ID: Raspbian
      Description: Raspbian GNU/Linux 10 (buster)
      Release: 10
      Codename: buster
      pi@raspberrypi:~ $ ./fishros
      Reading package lists... Done
      Building dependency tree
      The following NEW packages will be installed:
      python3-distro python3-yaml
      0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
      Need to get 126 kB of archives.
      After this operation, 542 kB of additional disk space will be used.
      Get:1 http://mirrors.zju.edu.cn/raspbian/raspbian buster/main armhf python3-distro all 1.3.0-1 [14.3 kB]
      Get:2 http://mirrors.zju.edu.cn/raspbian/raspbian buster/main armhf python3-yaml armhf 3.13-2 [111 kB]
      Fetched 126 kB in 2s (58.5 kB/s)
      Selecting previously unselected package python3-distro.
      (Reading database ... 98848 files and directories currently installed.)
      Preparing to unpack .../python3-distro_1.3.0-1_all.deb ...
      Unpacking python3-distro (1.3.0-1) ...
      Selecting previously unselected package python3-yaml.
      Preparing to unpack .../python3-yaml_3.13-2_armhf.deb ...
      Unpacking python3-yaml (3.13-2) ...
      Setting up python3-distro (1.3.0-1) ...
      Setting up python3-yaml (3.13-2) ...
      --2023-03-28 13:50:53-- http://fishros.com/install/install1s/tools/base.py
      Length: 42195 (41K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 41.21K --.-KB/s in 0.08s
      2023-03-28 13:50:53 (545 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [42195/42195]
      [-]Result:success
      基础检查通过...
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      [6]:一键安装:nodejs
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [77]:测试模式:运行自定义工具测试
      [0]:quit
      请输入[]内的数字以选择:1
      --2023-03-28 13:51:03-- http://fishros.com/install/install1s/tools/tool_install_ros.py
      Length: 19050 (19K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 18.60K --.-KB/s in 0.04s
      2023-03-28 13:51:03 (513 KB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [19050/19050]
      --2023-03-28 13:51:03-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
      Length: 2457 (2.4K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 2.40K --.-KB/s in 0s
      2023-03-28 13:51:03 (19.2 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2457/2457]
      --2023-03-28 13:51:03-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
      Length: 7511 (7.3K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 7.33K --.-KB/s in 0.003s
      2023-03-28 13:51:03 (2.09 MB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [7511/7511]
      小鱼:检测当前系统debian10.13:buster 支持一键安装ROS
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      [0]:quit
      请输入[]内的数字以选择:1
      欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
      请选择换源方式,如果不知道选什么请选2
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      [0]:quit
      请输入[]内的数字以选择:2
      [-]Result:success
      删除一个资源文件
      [-]Result:success
      [-]Result:success
      [-]Result:success
      检测到当前系统架构为[arm64:buster],正在为你更换对应源..
      替换完成,尝试第一次更新....
      [|]Get:2 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease [5[-]Get:3 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease [/]Get:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[|] The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY DCC9[/] The following signatures couldn't be verified because the public key is not[|] The following signatures couldn't be verified because the public key is not[-]Err:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[/] The following signatures couldn't be verified because the public key is not[-]Result:code:100 KEY 54404762BBB6E853
      更新失败,开始更换导入方式并三次尝试...
      Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9]
      []Executing: /tmp/apt-key-gpghome.VHtO2DCTbc/gpg.1.sh --keyserver keyserver.ubu[-]Result:success
      Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys DCC9EFBF77E11517]
      []Executing: /tmp/apt-key-gpghome.VDwjHrbJlO/gpg.1.sh --keyserver keyserver.ubu[-]Result:success
      Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 54404762BBB6E853]
      []Executing: /tmp/apt-key-gpghome.uv4bM819Zt/gpg.1.sh --keyserver keyserver.ubu[-]Result:success
      Run CMD Task:[apt-get install debian-keyring debian-archive-keyring]
      [/]Package debian-keyring is not available, but is referred to by another packag[-]Result:code:100 has been obsoleted, or
      Run CMD Task:[apt-key update]
      []gpg: key 9165938D90FDDD2E: "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VF[-]Result:success
      [|]Get:2 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease [5[-]Get:3 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease [/]Get:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[]Get:5 https://mirrors.tuna.tsinghua.edu.cn/debian buster/main armhf Packages [|]Get:6 https://mirrors.tuna.tsinghua.edu.cn/debian buster/main Translation-en [-]Get:7 https://mirrors.tuna.tsinghua.edu.cn/debian buster/contrib armhf Packag[/]Get:8 https://mirrors.tuna.tsinghua.edu.cn/debian buster/contrib Translation-[]Get:9 https://mirrors.tuna.tsinghua.edu.cn/debian buster/non-free armhf Packa[|]Get:10 https://mirrors.tuna.tsinghua.edu.cn/debian buster/non-free Translatio[-]Get:11 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates/main armhf [/]Get:12 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates/main Transl[]Get:13 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/main armh[|]Get:14 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/main Tran[-]Get:15 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/contrib a[/]Get:16 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/contrib T[]Get:17 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/non-free [|]Get:18 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/non-free [-]Get:19 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates/ma[/]Get:20 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates/ma[]Get:21 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates/no[-]Result:success st --upgradable' to see them.
      搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
      ['Get:1 https://mirrors.tuna.tsinghua.edu.cn/debian buster InRelease [122 kB]', 'Get:2 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease [56.6 kB]', 'Get:3 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease [51.4 kB]', 'Get:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InRelease [34.8 kB]', 'Get:5 https://mirrors.tuna.tsinghua.edu.cn/debian buster/main armhf Packages [7,706 kB]', 'Get:6 https://mirrors.tuna.tsinghua.edu.cn/debian buster/main Translation-en [5,969 kB]', 'Get:7 https://mirrors.tuna.tsinghua.edu.cn/debian buster/contrib armhf Packages [40.1 kB]', 'Get:8 https://mirrors.tuna.tsinghua.edu.cn/debian buster/contrib Translation-en [44.2 kB]', 'Get:9 https://mirrors.tuna.tsinghua.edu.cn/debian buster/non-free armhf Packages [62.1 kB]', 'Get:10 https://mirrors.tuna.tsinghua.edu.cn/debian buster/non-free Translation-en [88.9 kB]', 'Get:11 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates/main armhf Packages [8,784 B]', 'Get:12 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates/main Translation-en [6,915 B]', 'Get:13 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/main armhf Packages [477 kB]', 'Get:14 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/main Translation-en [411 kB]', 'Get:15 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/contrib armhf Packages [7,732 B]', 'Get:16 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/contrib Translation-en [8,080 B]', 'Get:17 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/non-free armhf Packages [13.0 kB]', 'Get:18 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/non-free Translation-en [39.5 kB]', 'Get:19 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates/main armhf Packages [464 kB]', 'Get:20 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates/main Translation-en [256 kB]', 'Get:21 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates/non-free Translation-en [344 B]', 'Fetched 15.6 MB in 12s (1,298 kB/s)', 'Reading package lists...', 'Building dependency tree...', 'Reading state information...', "721 packages can be upgraded. Run 'apt list --upgradable' to see them."]
      镜像修复完成.....
      [|]Get:2 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease [5[-]Get:3 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease [/]Get:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[-]Result:success st --upgradable' to see them.
      [-]cl-curry-compose-reader-macros - Reader macros for function partial applicati[-]libcupt4-2-downloadmethod-curl - flexible package manager -- libcurl download[]libcurl3-gnutls - easy-to-use client-side URL transfer library (GnuTLS flavou[]libcurl4-gnutls-dev - development files and documentation for libcurl (GnuTLS[|]libcurl4-nss-dev - development files and documentation for libcurl (NSS flavo[-]libcurl4-openssl-dev - development files and documentation for libcurl (OpenS[/]flickcurl-doc - utilities to call the Flickr API from command line - document[/]libflickcurl0-dbg - C library for accessing the Flickr API - debugging symbol[]forensics-extra - Forensics Environment - extra console components (metapacka[|]gnupg1 - GNU privacy guard - a PGP implementation (deprecated "classic" versi[-]golang-github-moul-http2curl-dev - Go package for convert Golang's http.Reque[|]libghc-curl-doc - Documentation for the libcurl Haskell bindings; documentati[-]libghc-curl-prof - Profiling libraries for the libcurl Haskell bindings; prof[]libghc-hxt-doc - collection of tools for processing XML with Haskell; documen[|]libghc-hxt-prof - collection of tools for processing XML with Haskell; profil[-]libghc-hxt-http-doc - Interface to native Haskell HTTP package HTTP; document[/]libghc-hxt-http-prof - Interface to native Haskell HTTP package HTTP; profili[]libresource-retriever-dev - Robot OS resource_retriever library - development[]librust-curl+http2-dev - Rust bindings to libcurl for making HTTP requests - [|]librust-curl-dev - Rust bindings to libcurl for making HTTP requests - Rust s[-]librust-curl-sys+http2-dev - Native bindings to the libcurl library - feature[/]librust-curl-sys+libnghttp2-sys-dev - Native bindings to the libcurl library []librust-curl-sys-dev - Native bindings to the libcurl library - Rust source c[|]librust-git2+curl-dev - Bindings to libgit2 for interoperating with git repos[-]librust-git2-curl-dev - Backend for an HTTP transport in libgit2 powered by l[/]librust-libgit2-sys+curl-dev - Native bindings to the libgit2 library - featu[]librust-libgit2-sys+curl-sys-dev - Native bindings to the libgit2 library - f[/]libstrongswan-extra-plugins - strongSwan utility and crypto library (extra pl[/]golang-github-ssgelm-cookiejarparser-dev - Go library that parses a curl cook[-]Result:success ect inputstream addon for Kodi
      [-]Get:1 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates/mai[/]Get:2 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates/mai[-]Result:success +rpt2+rpi1+deb10u1) ...u4) ...
      []Get:1 https://mirrors.tuna.tsinghua.edu.cn/debian buster/main armhf gnupg2 al[-]Result:success ...0u2_all.deb ...stalled.)
      [-]Result:success
      [-]Result:success
      [|]Get:2 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease [5[-]Get:3 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease [/]Get:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[/]Get:8 http://packages.ros.org/ros2/ubuntu buster/main arm64 Packages [59.5 kB[-]Result:success st --upgradable' to see them.
      [-]Result:success r Robot OS roscpp-coreageKerberos
      [-]Result:success
      [-]Result:success
      [-]Get:3 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease [5[/]Get:4 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease [|]Get:6 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[-]Result:success st --upgradable' to see them.
      [-]Result:success
      [-]Get:3 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease [5[/]Get:4 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease []Get:5 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[-]Result:success st --upgradable' to see them.
      [-]Get:3 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease [5[]Get:5 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease [|]Get:6 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[-]Result:success st --upgradable' to see them.
      [-]Result:code:2
      [-]Result:code:2
        小鱼 技术大佬 @niuniu_niu1
        @niuniu_niu1 在 树莓派一键安装ros melodic安装失败 中说:
        https://fishros.org.cn/forum/topic/136/一键安装遇到no_pubkey错误该怎么办
