    编译一个官方动作服务器节点时,出现“‘NodeOptions’ in namespace ‘rclcpp’ does not name a type”
    ros2 编译失败
    • Z
      z_xu_dong
      错误信息
      error: ‘NodeOptions’ in namespace ‘rclcpp’ does not name a type
      42 | create_node_instance(const rclcpp::NodeOptions & options) = 0;
      In file included from /opt/ros/humble/include/rclcpp_components/rclcpp_components/register_node_macro.hpp:19,
      from /home/dong/projects/learning_ros2/src/learning_action/src/ActionServer.c++:5:
      /opt/ros/humble/include/rclcpp_components/rclcpp_components/node_factory_template.hpp:43:38:
      ** error: ‘NodeOptions’ in namespace ‘rclcpp’ does not name a type**
      43 | create_node_instance(const rclcpp::NodeOptions & options) override
      系统及ROS版本
      Ubuntu22.04+ros humble
      具体操作
      我在编写一个动作服务器节点时,编译总是不通过。我编写的代码如下:
      #include <memory>
      #include <string>
      #include <functional>
      #include "rclcpp_components/register_node_macro.hpp"
      #include "rclcpp/rclcpp.hpp"
      #include "rclcpp_action/rclcpp_action.hpp"
      #include "learning_interfaces/action/move_action.hpp"
      using namespace std::placeholders;
      class ActionSeverNode : public rclcpp::Node
        using MoveAction = learning_interfaces::action::MoveAction;
        using GoalHandle = rclcpp_action::ServerGoalHandle<MoveAction>;
      public:
        explicit ActionSeverNode(const rclcpp::NodeOptions &options = rclcpp::NodeOptions())
            : Node("ServerNode", options) //explicit?
          sever_ = rclcpp_action::create_server<MoveAction>(this,
                                                            "move_action",
                                                            std::bind(&ActionSeverNode::goalCallback, this, _1, _2),
                                                            std::bind(&ActionSeverNode::cancelCallback, this, _1),
                                                            std::bind(&ActionSeverNode::AcceptCallback, this, _1));
      private:
        rclcpp_action::GoalResponse goalCallback(const rclcpp_action::GoalUUID uuid,
                                                 MoveAction::Goal::ConstSharedPtr goal_)
          RCLCPP_INFO(this->get_logger(), "Received goal.dist = %ld", goal_->dist);
          (void)uuid;
          return rclcpp_action::GoalResponse::ACCEPT_AND_EXECUTE;
        rclcpp_action::CancelResponse cancelCallback(const std::shared_ptr<GoalHandle> handle_)
          RCLCPP_INFO(this->get_logger(), "Received request to cancle goal.");
          (void)handle_;
          return rclcpp_action::CancelResponse::ACCEPT;
        void AcceptCallback(const std::shared_ptr<GoalHandle> handle_)
          std::thread(std::bind(&ActionSeverNode::excute_action, this, _1), handle_).detach(); // learn thread.
        void excute_action(const std::shared_ptr<GoalHandle> handle_)
          rclcpp::Rate loop_rate(1);
          auto goal = handle_->get_goal();
          auto feedback = std::make_shared<MoveAction::Feedback>();
          auto state = feedback->state;
          auto result = std::make_shared<MoveAction::Result>();
          if (goal->enable)
            if (handle_->is_canceling())
              result->finish = false;
              handle_->canceled(result);
              RCLCPP_INFO(this->get_logger(), "cancel.");
              return;
            for (int i = 0; i < goal->dist; ++i)
              state = i;
              handle_->publish_feedback(feedback);
            loop_rate.sleep();
          if (rclcpp::ok())
            result->finish = true;
            handle_->succeed(result);
            RCLCPP_INFO(this->get_logger(), "successed.");
      private:
        rclcpp_action::Server<MoveAction>::SharedPtr sever_;
      RCLCPP_COMPONENTS_REGISTER_NODE(ActionSeverNode);
      Z 1 条回复 最后回复 回复 引用 0
      • Z
        z_xu_dong @z_xu_dong
        @z_xu_dong 我知道原因了,因为我在登记节点宏那行末尾加了分号
        RCLCPP_COMPONENTS_REGISTER_NODE(ActionSeverNode);   ❌
        RCLCPP_COMPONENTS_REGISTER_NODE(ActionSeverNode)   ✔
        • Z
          @z_xu_dong 最后一行创建组件的问题 但不知道问题具体出在哪
          • Z
            • 小鱼小 小鱼 将这个主题标记为已解决,在
