    求助nav2全向轮导航无法在y轴上移动
    Nav2
    nav2 全向轮
    • 24450244602
      小 羊 君
      导航只写了launch文件,基本和官方示例一样,只不过机器人模型是用的全向轮模型,slam用的gmapping
      1. 通过rqt工具可以看到cmd_vel_nav主题上y分量有示数,但cmd_vel上没有示数
      2. 直接在cmd_vel发布y分量的线速度,机器人能正常运动
      3. 这是我的参数文件:
        amcl:
        ros__parameters:
        use_sim_time: True
        alpha1: 0.2
        alpha2: 0.2
        alpha3: 0.2
        alpha4: 0.2
        alpha5: 0.2
        beam_skip_distance: 0.5
        beam_skip_threshold: 0.3
        do_beamskip: false
        global_frame_id: "map"
        lambda_short: 0.1
        laser_max_range: 100.0
        laser_min_range: -1.0
        max_beams: 60
        max_particles: 2000
        min_particles: 500
        odom_frame_id: "odom"
        pf_err: 0.05
        pf_z: 0.99
        recovery_alpha_fast: 0.0
        recovery_alpha_slow: 0.0
        resample_interval: 1
        robot_model_type: "omnidirectional"
        save_pose_rate: 0.5
        sigma_hit: 0.2
        tf_broadcast: true
        transform_tolerance: 1.0
        update_min_a: 0.2
        update_min_d: 0.25
        z_hit: 0.5
        z_max: 0.05
        z_rand: 0.5
        z_short: 0.05
        scan_topic: scan
      bt_navigator:
      ros__parameters:
      use_sim_time: True
      global_frame: map
      robot_base_frame: base_link
      odom_topic: /odom
      bt_loop_duration: 10
      default_server_timeout: 20
      plugin_lib_names:
      - nav2_smooth_path_action_bt_node
      - nav2_spin_action_bt_node
      - nav2_wait_action_bt_node
      - nav2_assisted_teleop_action_bt_node
      - nav2_back_up_action_bt_node
      - nav2_drive_on_heading_bt_node
      - nav2_globally_updated_goal_condition_bt_node
      - nav2_is_path_valid_condition_bt_node
      - nav2_truncate_path_local_action_bt_node
      - nav2_recovery_node_bt_node
      - nav2_path_expiring_timer_condition
      - nav2_single_trigger_bt_node
      - nav2_goal_updated_controller_bt_node
      - nav2_controller_cancel_bt_node
      - nav2_path_longer_on_approach_bt_node
      - nav2_wait_cancel_bt_node
      - nav2_spin_cancel_bt_node
      - nav2_back_up_cancel_bt_node
      - nav2_assisted_teleop_cancel_bt_node
      - nav2_drive_on_heading_cancel_bt_node
      bt_navigator_navigate_through_poses_rclcpp_node:
      ros__parameters:
      use_sim_time: True
      bt_navigator_navigate_to_pose_rclcpp_node:
      ros__parameters:
      use_sim_time: True
      controller_server:
      ros__parameters:
      use_sim_time: True
      controller_frequency: 20.0
      min_x_velocity_threshold: 0.001
      min_y_velocity_threshold: 0.5
      min_theta_velocity_threshold: 0.001
      failure_tolerance: 0.3
      progress_checker_plugin: "progress_checker"
      goal_checker_plugins: ["general_goal_checker"] # "precise_goal_checker"
      controller_plugins: ["FollowPath"]
      # Progress checker parameters
      progress_checker:
        plugin: "nav2_controller::SimpleProgressChecker"
        required_movement_radius: 0.5
        movement_time_allowance: 10.0
      # Goal checker parameters
      #precise_goal_checker:
      #  plugin: "nav2_controller::SimpleGoalChecker"
      #  xy_goal_tolerance: 0.25
      #  yaw_goal_tolerance: 0.25
      #  stateful: True
      general_goal_checker:
        stateful: True
      # DWB parameters
      FollowPath:
        plugin: "dwb_core::DWBLocalPlanner"
        debug_trajectory_details: True
        min_vel_x: -0.26
        min_vel_y: -0.26
        max_vel_x: 0.26
        max_vel_y: 0.26
        max_vel_theta: 0.0
        min_speed_xy: -0.26
        max_speed_xy: 0.26
        min_speed_theta: 0.0
        # Add high threshold velocity for turtlebot 3 issue.
        # https://github.com/ROBOTIS-GIT/turtlebot3_simulations/issues/75
        acc_lim_x: 2.5
        acc_lim_y: 2.5
        acc_lim_theta: 0.0
        decel_lim_x: -2.5
        decel_lim_y: -2.5
        decel_lim_theta: 0.0
        vx_samples: 20
        vy_samples: 20
        vtheta_samples: 0
        sim_time: 1.7
        linear_granularity: 0.05
        angular_granularity: 0.025
        transform_tolerance: 0.2
        trans_stopped_velocity: 0.25
        short_circuit_trajectory_evaluation: True
        stateful: True
        critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
        BaseObstacle.scale: 0.02
        PathAlign.scale: 32.0
        PathAlign.forward_point_distance: 0.1
        GoalAlign.scale: 24.0
        GoalAlign.forward_point_distance: 0.1
        PathDist.scale: 32.0
        GoalDist.scale: 24.0
        RotateToGoal.scale: 32.0
        RotateToGoal.slowing_factor: 5.0
        RotateToGoal.lookahead_time: -1.0
      local_costmap:
      local_costmap:
      ros__parameters:
      update_frequency: 5.0
      publish_frequency: 2.0
      global_frame: odom
      use_sim_time: True
      rolling_window: true
      width: 3
      height: 3
      resolution: 0.05
      robot_radius: 0.22
      plugins: ["voxel_layer", "inflation_layer"]
      inflation_layer:
      cost_scaling_factor: 3.0
      inflation_radius: 0.55
      voxel_layer:
      plugin: "nav2_costmap_2d::VoxelLayer"
      enabled: True
      publish_voxel_map: True
      origin_z: 0.0
      z_resolution: 0.05
      z_voxels: 16
      max_obstacle_height: 2.0
      mark_threshold: 0
      observation_sources: scan
      scan:
      topic: /scan
      clearing: True
      marking: True
      data_type: "LaserScan"
      raytrace_max_range: 3.0
      raytrace_min_range: 0.0
      obstacle_max_range: 2.5
      obstacle_min_range: 0.0
      static_layer:
      global_costmap:
      global_costmap:
      ros__parameters:
      update_frequency: 1.0
      publish_frequency: 1.0
      global_frame: map
      use_sim_time: True
      robot_radius: 0.22
      resolution: 0.05
      track_unknown_space: true
      obstacle_layer:
      enabled: True
      scan:
      topic: /scan
      clearing: True
      marking: True
      static_layer:
      inflation_layer:
      map_server:
      ros__parameters:
      use_sim_time: True
      # Overridden in launch by the "map" launch configuration or provided default value.
      # To use in yaml, remove the default "map" value in the tb3_simulation_launch.py file & provide full path to map below.
      yaml_filename: ""
      map_saver:
      ros__parameters:
      use_sim_time: True
      save_map_timeout: 5.0
      free_thresh_default: 0.25
      occupied_thresh_default: 0.65
      planner_server:
      ros__parameters:
      expected_planner_frequency: 20.0
      use_sim_time: True
      planner_plugins: ["GridBased"]
      GridBased:
      plugin: "nav2_navfn_planner/NavfnPlanner"
      tolerance: 0.5
      use_astar: false
      allow_unknown: true
      smoother_server:
      ros__parameters:
      use_sim_time: True
      smoother_plugins: ["simple_smoother"]
      simple_smoother:
      plugin: "nav2_smoother::SimpleSmoother"
      tolerance: 1.0e-10
      max_its: 1000
      do_refinement: True
      behavior_server:
      ros__parameters:
      costmap_topic: local_costmap/costmap_raw
      footprint_topic: local_costmap/published_footprint
      cycle_frequency: 10.0
      behavior_plugins: ["spin", "backup", "drive_on_heading", "assisted_teleop", "wait"]
      spin:
      plugin: "nav2_behaviors/Spin"
      backup:
      plugin: "nav2_behaviors/BackUp"
      drive_on_heading:
      plugin: "nav2_behaviors/DriveOnHeading"
      wait:
      plugin: "nav2_behaviors/Wait"
      assisted_teleop:
      plugin: "nav2_behaviors/AssistedTeleop"
      global_frame: odom
      transform_tolerance: 0.1
      use_sim_time: true
      simulate_ahead_time: 2.0
      max_rotational_vel: 1.0
      min_rotational_vel: 0.4
      rotational_acc_lim: 3.2
      robot_state_publisher:
      ros__parameters:
      use_sim_time: True
      waypoint_follower:
      ros__parameters:
      use_sim_time: True
      loop_rate: 20
      stop_on_failure: false
      waypoint_task_executor_plugin: "wait_at_waypoint"
      wait_at_waypoint:
      plugin: "nav2_waypoint_follower::WaitAtWaypoint"
      enabled: True
      waypoint_pause_duration: 200
      velocity_smoother:
      ros__parameters:
      use_sim_time: True
      smoothing_frequency: 20.0
      scale_velocities: False
      feedback: "OPEN_LOOP"
      max_velocity: [0.26, 0.0, 1.0]
      min_velocity: [-0.26, 0.0, -1.0]
      max_accel: [2.5, 0.0, 3.2]
      max_decel: [-2.5, 0.0, -3.2]
      odom_topic: "odom"
      odom_duration: 0.1
      deadband_velocity: [0.0, 0.0, 0.0]
      velocity_timeout: 1.0
      26762394302 1 条回复 最后回复 回复 引用 0
      • 26762394302
        Tony Kerman @2445024460
        @2445024460
        velocity_smoother,参数有问题吧,你现在y轴的速度限制是0.0到0.0,改一下
        velocity_smoother:
        ros__parameters:
        max_velocity: [0.26, 0.26, 1.0]
        min_velocity: [-0.26, -0.26, -1.0]
