    第八章创建的模型在rviz2可视化中报Warning
    仿真
    ros2 rviz2 urdf配置 fishbot 动手学ros2
    1.4k
    • 3429184983
      C-002
      按照教程8.3 动手创建一个移动机器人添加机器人右轮,在使用rviz2查看效果时terminal回报Warning,请问是什么原因?是什么造成警报的?详细信息如下
      warning信息:
      [rviz2-3] Warning: Invalid frame ID "right_wheel_link" passed to canTransform argument source_frame - frame does not exist
      模型效果:
      终端输出:
      $ ros2 launch fishbot_description display_rviz2.launch.py
      [INFO] [launch]: All log files can be found below /home/ae/.ros/log/2023-05-16-15-20-14-965838-ae-ubuntu-22-9248
      [INFO] [robot_state_publisher-1]: process started with pid [9249]
      [INFO] [joint_state_publisher_gui-2]: process started with pid [9251]
      [INFO] [rviz2-3]: process started with pid [9253]
      [rviz2-3] Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
      [robot_state_publisher-1] [WARN] [1684221615.098850601] [robot_state_publisher]: No robot_description parameter, but command-line argument available.  Assuming argument is name of URDF file.  This backwards compatibility fallback will be removed in the future.
      [robot_state_publisher-1] [INFO] [1684221615.103959799] [robot_state_publisher]: got segment base_link
      [robot_state_publisher-1] [INFO] [1684221615.104012749] [robot_state_publisher]: got segment imu_link
      [robot_state_publisher-1] [INFO] [1684221615.104019117] [robot_state_publisher]: got segment laser_link
      [robot_state_publisher-1] [INFO] [1684221615.104023186] [robot_state_publisher]: got segment right_wheel_link
      [rviz2-3] [INFO] [1684221615.368455227] [rviz2]: Stereo is NOT SUPPORTED
      [rviz2-3] [INFO] [1684221615.368700274] [rviz2]: OpenGl version: 4.3 (GLSL 4.3)
      [rviz2-3] [INFO] [1684221615.402794128] [rviz2]: Stereo is NOT SUPPORTED
      [joint_state_publisher_gui-2] Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
      [rviz2-3]          at line 93 in ./src/buffer_core.cpp
      [joint_state_publisher_gui-2] [INFO] [1684221615.789086657] [joint_state_publisher_gui]: Centering
      机器人URDF文件:
      <?xml version="1.0"?>
      <robot name="fishbot">
          <!-- base link -->
          <link name="base_link">
              <visual>
                  <geometry>
                      <cylinder length="0.12" radius="0.10"/>
                  </geometry>
                  <material name="blue">
                  </material>
              </visual>
          </link>
          <!-- laser link -->
          <link name="laser_link">
              <visual>
                  <geometry>
                  </geometry>
                  <material name="black">
                      <color rgba="0.0 0.0 0.0 0.8" />
                  </material>
              </visual>
          </link>
          <!-- laser joint -->
              <parent link="base_link" />
              <child link="laser_link" />
              <origin xyz="0 0 0.075" />
          </joint>
          <!-- imu link -->
          <link name="imu_link">
              <visual>
                  <geometry>
                      <box size="0.01 0.01 0.01" />
                  </geometry>
                  <material name="red">
                      <color rgba="1.0 0.1 0.1 0.8" />
                  </material>
              </visual>
          </link>
          <!-- imu joint-->
              <child link="imu_link" />
              <origin xyz="0 0 0.02" />
          </joint>
          <!-- right wheel link -->
              <visual>
                  <origin xyz="0 0 0" rpy="1.57079 0 0" />
                  <geometry>
                      <cylinder length="0.04" radius="0.032" />
                  </geometry>
                  </material>
              </visual>
          </link>
          <!-- right wheel joint-->
              <origin xyz="-0.02 -0.10 -0.06" />
              <axis xyz="0 1 0" />
          </joint>
      </robot>
      小伊小 1 条回复 最后回复 回复 引用 0
        机器人小伊 @342918498
        @342918498 如果是启动时报一下没关系,因为 rviz 启动太快了,没来得及更新tf信息,如果一直报就是tf有问题了他
