    windows下安装docker+ROS1,在第一次输入测试(t)命令时报错,无法进入容器
    docker+ros1 安装好后测试报错 容器无ports
    • 30379741183
      北極光
      Reading package lists... Done
      Building dependency tree
      python3-yaml is already the newest version (3.12-1build2).
      python3-distro is already the newest version (1.0.1-2).
      You might want to run 'apt --fix-broken install' to correct these.
      code : Depends: libsecret-1-0 (>= 0.18) but it is not going to be installed
      Depends: libxkbfile1 but it is not going to be installed
      Depends: xdg-utils (>= 1.0.2) but it is not going to be installed
      Recommends: libvulkan1 but it is not going to be installed
      E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
      --2023-05-31 17:39:13-- http://fishros.com/install/install1s/tools/base.py
      Length: 42293 (41K) [application/octet-stream]
      /tmp/fishinstall/tools/base 100%[===========================================>] 41.30K --.-KB/s in 0.08s
      2023-05-31 17:39:13 (537 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [42293/42293]
      [-]Result:success
      基础检查通过...
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      [6]:一键安装:nodejs
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [77]:测试模式:运行自定义工具测试
      [0]:quit
      请输入[]内的数字以选择:11
      --2023-05-31 17:39:19-- http://fishros.com/install/install1s/tools/tool_install_ros_with_docker.py
      Length: 11540 (11K) [application/octet-stream]
      Saving to: ‘/tmp/fishinstall/tools/tool_install_ros_with_docker.py’
      /tmp/fishinstall/tools/tool 100%[===========================================>] 11.27K --.-KB/s in 0.006s
      2023-05-31 17:39:20 (1.97 MB/s) - ‘/tmp/fishinstall/tools/tool_install_ros_with_docker.py’ saved [11540/11540]
      --2023-05-31 17:39:20-- http://fishros.com/install/install1s/tools/tool_install_vscode.py
      Length: 1366 (1.3K) [application/octet-stream]
      Saving to: ‘/tmp/fishinstall/tools/tool_install_vscode.py’
      /tmp/fishinstall/tools/tool 100%[===========================================>] 1.33K --.-KB/s in 0s
      2023-05-31 17:39:20 (316 MB/s) - ‘/tmp/fishinstall/tools/tool_install_vscode.py’ saved [1366/1366]
      --2023-05-31 17:39:20-- http://fishros.com/install/install1s/tools/tool_install_docker.py
      Length: 2882 (2.8K) [application/octet-stream]
      Saving to: ‘/tmp/fishinstall/tools/tool_install_docker.py’
      /tmp/fishinstall/tools/tool 100%[===========================================>] 2.81K --.-KB/s in 0.002s
      2023-05-31 17:39:20 (1.30 MB/s) - ‘/tmp/fishinstall/tools/tool_install_docker.py’ saved [2882/2882]
      欢迎使用一键安装ROS-Docker版,支持所有版本ROS,本工具由作者小鱼提供
      ================================1.版本选择======================================
      [1]:noetic
      [2]:humble
      [3]:foxy
      [4]:galactic
      [5]:melodic
      [6]:rolling
      [7]:kinetic
      [8]:eloquent
      [9]:dashing
      [10]:crystal
      [11]:bouncy
      [12]:ardent
      [13]:lunar
      [14]:indigo
      [0]:quit
      请输入[]内的数字以选择:5
      你选择了melodic(ROS1),该版本目前状态:长期支持
      ================================2.安装Docker======================================
      Run CMD Task:[docker version]
      [-]Result:success a0e4e17bddfbd388f38
      =================3.下载镜像(该步骤因网络原因会慢一些,若失败请重试)==================
      Run CMD Task:[sudo docker pull fishros2/ros:melodic-desktop-full ]
      melodic-desktop-full: Pulling from fishros2/ros
      Digest: sha256:3d95b89365e60cf96696288f32816e2324fd8c891d379f0e8fae62b08a22e763
      Status: Image is up to date for fishros2/ros:melodic-desktop-full
      docker.io/fishros2/ros:melodic-desktop-full
      ================================4.生成容器======================================
      请为你的melodic容器取个名字吧!
      melodic1
      收到名字melodic1
      Run CMD Task:[users]
      [-]Result:success
      请手动输入你的用户名>>aurora_borealis
      Run CMD Task:[sudo docker run -dit --name=melodic1 -v /home/aurora_borealis:/home/aurora_borealis -v /tmp/.X11-unix:/tmp/.X11-unix -v /dev/dri:/dev/dri --device /dev/snd -e DISPLAY=unix$DISPLAY -w /home/aurora_borealis fishros2/ros:melodic-desktop-full]
      docker: Error response from daemon: Conflict. The container name "/melodic1" is already in use by container "85d2d1bf520e063bfa1e6ec0175d4894ce2fe0cafb3b2f25b4764bf6ae791f08". You have to remove (or rename) that container to be able to reuse that name.
      See 'docker run --help'.
      Run CMD Task:[docker exec -it melodic1 /bin/bash -c "echo -e '
      source /opt/ros/melodic/setup.bash' >> ~/.bashrc" ]
      Error response from daemon: Container 85d2d1bf520e063bfa1e6ec0175d4894ce2fe0cafb3b2f25b4764bf6ae791f08 is not running
      Run CMD Task:[xhost +local:]
      sh: 1: xhost: not found
      ================================5.生成命令======================================
      [-]Result:success
      Run CMD Task:[sudo chmod 777 /home/aurora_borealis/.fishros/bin/melodic1]
      ================================6.生成使用工具======================================
      为方便后续使用容器,请选择使用方式,若不知道怎么选,推荐套餐1,若不需要则可以选退出:
      [1]:套餐1:VsCode+插件(本地使用推荐)
      [2]:套餐2:SSH-Service(远程使用推荐)
      [0]:quit
      请输入[]内的数字以选择:1
      套餐1包含Vscode及其容器插件,开始安装。。
      欢迎使用一键安装Vscode,本工具由作者小鱼提供
      开始根据系统架构,为你下载对应版本的vscode~
      Run CMD Task:[sudo wget http://vscode.cdn.azure.cn/stable/6261075646f055b99068d3688932416f2346dd3b/code_1.73.1-1667967334_amd64.deb -O /tmp/vscode.deb]
      --2023-05-31 17:42:54-- http://vscode.cdn.azure.cn/stable/6261075646f055b99068d3688932416f2346dd3b/code_1.73.1-1667967334_amd64.deb
      Resolving vscode.cdn.azure.cn (vscode.cdn.azure.cn)... 222.199.191.35
      Connecting to vscode.cdn.azure.cn (vscode.cdn.azure.cn)|222.199.191.35|:80... connected.
      Length: 96706580 (92M) [application/octet-stream]
      Saving to: ‘/tmp/vscode.deb’
      /tmp/vscode.deb 100%[=================================================>] 92.23M 9.78MB/s in 9.9s
      2023-05-31 17:43:05 (9.34 MB/s) - ‘/tmp/vscode.deb’ saved [96706580/96706580]
      下载完成,接下来为你安装Vscode~
      Run CMD Task:[sudo dpkg -i /tmp/vscode.deb]
      [-]Result:code:1 (1.9-2) .....7334) ...stalled.)
      Run CMD Task:[rm -rf /tmp/vscode.deb]
      [-]Result:success
      安装完成~
      Run CMD Task:[code --install-extension ms-vscode-remote.remote-containers --user-data-dir]
      sh: 1: code: not found
      ===========================后续使用指令=================================
      后续可在任意终端输入melodic1来启动/停止/测试/删除容器
      ==============================文件存储位置===============================
      你的主目录已经和容器的对应目录做了映射
      ==============================问题反馈&&更新讨论=============================
      请访问社区的一键安装版块:https://fishros.org.cn/forum/topic/112
      aurora_borealis@DESKTOP-4KV591G:~$ melodic1
      /home/aurora_borealis/.fishros/bin/melodic1: line 1: xhost: command not found
      请输入指令控制melodic1: 重启(r) 进入(e) 启动(s) 关闭(c) 删除(d) 测试(t):
      t
      查看过melodic1这个容器,他没有ports
      请问一下怎么解决,谢谢!
      我是在unbuntu18.04的终端运行的:
