    在vscode里面的终端一键下载的ROS,下载的时候没有问题,但是测试运行小乌龟就不行,而且电脑系统重装之前可以一切没问题重装之后就不行了
    一键安装 vscode终端 小乌龟无法启动
    1.0k
    • 30379741183
      北極光
      aurora_borealis@DESKTOP-4KV591G:~$ roscore
      ... logging to /home/aurora_borealis/.ros/log/a2268cbe-ff9d-11ed-aa85-00155db53ee7/roslaunch-DESKTOP-4KV591G-12683.log
      Press Ctrl-C to interrupt
      started roslaunch server http://DESKTOP-4KV591G:43315/
      ros_comm version 1.14.13
      SUMMARY
      PARAMETERS
      • /rosdistro: melodic
      • /rosversion: 1.14.13
      NODES
      auto-starting new master
      process[master]: started with pid [12697]
      ROS_MASTER_URI=http://DESKTOP-4KV591G:11311/
      setting /run_id to a2268cbe-ff9d-11ed-aa85-00155db53ee7
      process[rosout-1]: started with pid [12708]
      started core service [/rosout]
      ... logging to /home/aurora_borealis/.ros/log/a2268cbe-ff9d-11ed-aa85-00155db53ee7/roslaunch-DESKTOP-4KV591G-12814.log
      started roslaunch server http://DESKTOP-4KV591G:35349/
      SUMMARY
      PARAMETERS
      NODES
      RLException: roscore cannot run as another roscore/master is already running.
      Please kill other roscore/master processes before relaunching.
      The ROS_MASTER_URI is http://DESKTOP-4KV591G:11311/
      The traceback for the exception was written to the log file
      aurora_borealis@DESKTOP-4KV591G:~$ rosrun turtlesim turtlesim_node
      QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-aurora_borealis'
      qt.qpa.screen: QXcbConnection: Could not connect to display
      Could not connect to any X display.
        小鱼 技术大佬 @3037974118
        @3037974118 在 在vscode里面的终端一键下载的ROS,下载的时候没有问题,但是测试运行小乌龟就不行,而且电脑系统重装之前可以一切没问题重装之后就不行了 中说:
        主机终端 xhost +
