    ROS2Gazebo机械臂仿真,一直“蹦迪”
    机械臂运动规划
    gazebo urdf配置
    • 3596479103
      向上
      [gzserver-1] Warning [parser_urdf.cc:1134] multiple inconsistent <static> exists due to fixed joint reduction overwriting previous value [true] with [false].
      [spawn_entity.py-4] [INFO] [1685915855.651688492] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [xinsong_description]
      [INFO] [spawn_entity.py-4]: process has finished cleanly [pid 19870]
      [INFO] [ros2-5]: process started with pid [19986]
      [ros2-5] Could not contact service /controller_manager/load_controller
      [ERROR] [ros2-5]: process has died [pid 19986, exit code 1, cmd 'ros2 control load_controller --set-state active joint_state_broadcaster'].
      controller_manager 已经成功安装
      运行gazebo查询运行节点
      ros2 node list
      /gazebo
      /robot_state_publisher
      multiple inconsistent <static> exists due to fixed joint reduction overwriting previous value [true] with [false].这个已经检查过urdf文件,语法正确,不知道怎麼修改
      想问问是哪里问题
      • 8390109778
        Zyonia
        我也想知道,老哥弄出来了踢我一下
