    ros2和anaconda结合
    anaconda pytorch
    949
    • T
      tempxl
      系统是ubuntu22.04,目前用anaconda创建了一个python环境,想在ros中使用pytorch,按照该方法尝试了一下,添加了
      import sys
      sys.path.append('/home/xl/anaconda3/envs/drl/lib/python3.8/site-packages')
      import torch
      并且关闭了conda进行编译和运行,但是报了如下的错误
        File "/home/xl/ros2_ws/install/py_pubsub/lib/py_pubsub/talker", line 33, in <module>
          sys.exit(load_entry_point('py-pubsub==0.0.0', 'console_scripts', 'talker')())
        File "/home/xl/ros2_ws/install/py_pubsub/lib/py_pubsub/talker", line 25, in importlib_load_entry_point
          return next(matches).load()
        File "/usr/lib/python3.10/importlib/metadata/__init__.py", line 171, in load
          module = import_module(match.group('module'))
        File "/usr/lib/python3.10/importlib/__init__.py", line 126, in import_module
        File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
        File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
        File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
        File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
        File "<frozen importlib._bootstrap_external>", line 883, in exec_module
        File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
        File "/home/xl/ros2_ws/install/py_pubsub/lib/python3.10/site-packages/py_pubsub/publisher_member_function.py", line 18, in <module>
          import torch
        File "/home/xl/anaconda3/envs/drl/lib/python3.8/site-packages/torch/__init__.py", line 443, in <module>
          raise ImportError(textwrap.dedent('''
      ImportError: Failed to load PyTorch C extensions:
          It appears that PyTorch has loaded the `torch/_C` folder
          of the PyTorch repository rather than the C extensions which
          are expected in the `torch._C` namespace. This can occur when
          using the `install` workflow. e.g.
              $ python setup.py install && python -c "import torch"
          This error can generally be solved using the `develop` workflow
              $ python setup.py develop && python -c "import torch"  # This should succeed
          or by running Python from a different directory.
      T 1 条回复 最后回复 回复 引用 0
      • T
        tempxl @tempxl
        @tempxl 重新用virtulenv创建了一个虚拟环境,并且装上pytorch,发现可以正常使用
        小鱼小 2 2 条回复 最后回复 回复 引用 0
          小鱼 技术大佬 @tempxl
          @tempxl anacoda3的python版本和系统的ros版本应该不匹配
          T 1 条回复 最后回复 回复 引用 1
          • T
            tempxl @小鱼
            @小鱼 是的,anaconda创建的是python3.8,系统的是3.10
            773143907 1 条回复 最后回复 回复 引用 0
            • T tempxl 将这个主题标记为已解决,在
            • 773143907
              77314390 @tempxl
              @tempxl 在 ros2和anaconda结合 中说:
              你好,我也遇到了这个问题,我在conda环境python是3.7,系统是3.10, 因为想利用conda环境里的tensorflow包,然后在环境里运行不了,不知道是否因为两者python版本部匹配所导致的。
                β @tempxl
                只能重新创建虚拟环境吗?我现在跑的视觉只支持3.8版本的怎么办?
