    不能安装桌面版
    一键安装,ros2 一键安装报错
    • P
      pxz4123
      一安装桌面版就出问题```求助大佬
      he following actions will resolve these dependencies:
        Keep the following packages at their current version:
      1.  libcurl4-gnutls-dev [Not Installed]
      2.  libgdal-dev [Not Installed]
      3.  libibus-1.0-dev [Not Installed]
      4.  libpcl-dev [Not Installed]
      5.  libsdl2-dev [Not Installed]
      6.  libvtk7-dev [Not Installed]
      7.  libvtk7-qt-dev [Not Installed]
      8.  ros-foxy-desktop [Not Installed]
      9.  ros-foxy-joy [Not Installed]
      10. ros-foxy-pcl-conversions [Not Installed]
      11. ros-foxy-sdl2-vendor [Not Installed]
      12. ros-foxy-teleop-twist-joy [Not Installed]
      13. unixodbc-dev [Not Installed]
        Upgrade the following packages:
      14. libpulsedsp [1:13.99.1-1ubuntu3.10 (now) -> 1:13.99.1-1ubuntu3.13 (focal-updates)]
      15. pulseaudio [1:13.99.1-1ubuntu3.10 (now) -> 1:13.99.1-1ubuntu3.13 (focal-updates)]
      16. pulseaudio-module-bluetooth [1:13.99.1-1ubuntu3.10 (now) -> 1:13.99.1-1ubuntu3.13 (focal-updates)]
      17. pulseaudio-utils [1:13.99.1-1ubuntu3.10 (now) -> 1:13.99.1-1ubuntu3.13 (focal-updates)]
      18. udev [245.4-4ubuntu3.20 (focal-security, now) -> 245.4-4ubuntu3.22 (focal-updates)]
      Accept this solution? [Y/n/q/?] n
      The following actions will resolve these dependencies:
      6.  libudev-dev [Not Installed]
      7.  libudev1 [245.4-4ubuntu3.20 (focal-security, now)]
      8.  libvtk7-dev [Not Installed]
      9.  libvtk7-qt-dev [Not Installed]
      10. ros-foxy-desktop [Not Installed]
      11. ros-foxy-joy [Not Installed]
      12. ros-foxy-pcl-conversions [Not Installed]
      13. ros-foxy-sdl2-vendor [Not Installed]
      14. ros-foxy-teleop-twist-joy [Not Installed]
      15. unixodbc-dev [Not Installed]
      16. libpulsedsp [1:13.99.1-1ubuntu3.10 (now) -> 1:13.99.1-1ubuntu3.13 (focal-updates)]
      17. pulseaudio [1:13.99.1-1ubuntu3.10 (now) -> 1:13.99.1-1ubuntu3.13 (focal-updates)]
      18. pulseaudio-module-bluetooth [1:13.99.1-1ubuntu3.10 (now) -> 1:13.99.1-1ubuntu3.13 (focal-updates)]
      19. pulseaudio-utils [1:13.99.1-1ubuntu3.10 (now) -> 1:13.99.1-1ubuntu3.13 (focal-updates)]
      Accept this solution? [Y/n/q/?] Y
      The following packages will be upgraded:
      libasound2 libasound2-data libpulse-mainloop-glib0 libpulse0 libpulsedsp pulseaudio pulseaudio-module-bluetooth pulseaudio-utils
      8 packages upgraded, 0 newly installed, 0 to remove and 196 not upgraded.
      Need to get 1,580 kB of archives. After unpacking 9,216 B will be used.
      Do you want to continue? [Y/n/?] Y
      Get: 1 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main amd64 libpulse-mainloop-glib0 amd64 1:13.99.1-1ubuntu3.13 [11.7 kB]
      Get: 2 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main amd64 libpulsedsp amd64 1:13.99.1-1ubuntu3.13 [21.7 kB]
      Get: 3 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main amd64 pulseaudio-utils amd64 1:13.99.1-1ubuntu3.13 [55.0 kB]
      Get: 4 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main amd64 pulseaudio-module-bluetooth amd64 1:13.99.1-1ubuntu3.13 [60.4 kB]
      Get: 5 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main amd64 pulseaudio amd64 1:13.99.1-1ubuntu3.13 [814 kB]
      Get: 6 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main amd64 libpulse0 amd64 1:13.99.1-1ubuntu3.13 [262 kB]
      Get: 7 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main amd64 libasound2 amd64 1.2.2-2.1ubuntu2.5 [335 kB]
      Get: 8 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main amd64 libasound2-data all 1.2.2-2.1ubuntu2.5 [20.1 kB]
      Fetched 1,580 kB in 2s (1,031 kB/s)
      (Reading database ... 272356 files and directories currently installed.)
      Preparing to unpack .../0-libpulse-mainloop-glib0_1%3a13.99.1-1ubuntu3.13_amd64.deb ...
      Unpacking libpulse-mainloop-glib0:amd64 (1:13.99.1-1ubuntu3.13) over (1:13.99.1-1ubuntu3.10) ...
      Preparing to unpack .../1-libpulsedsp_1%3a13.99.1-1ubuntu3.13_amd64.deb ...
      Unpacking libpulsedsp:amd64 (1:13.99.1-1ubuntu3.13) over (1:13.99.1-1ubuntu3.10) ...
      Preparing to unpack .../2-pulseaudio-utils_1%3a13.99.1-1ubuntu3.13_amd64.deb ...
      Unpacking pulseaudio-utils (1:13.99.1-1ubuntu3.13) over (1:13.99.1-1ubuntu3.10) ...
      Preparing to unpack .../3-pulseaudio-module-bluetooth_1%3a13.99.1-1ubuntu3.13_amd64.deb ...
      Unpacking pulseaudio-module-bluetooth (1:13.99.1-1ubuntu3.13) over (1:13.99.1-1ubuntu3.10) ...
      Preparing to unpack .../4-pulseaudio_1%3a13.99.1-1ubuntu3.13_amd64.deb ...
      Unpacking pulseaudio (1:13.99.1-1ubuntu3.13) over (1:13.99.1-1ubuntu3.10) ...
      Preparing to unpack .../5-libpulse0_1%3a13.99.1-1ubuntu3.13_amd64.deb ...
      Unpacking libpulse0:amd64 (1:13.99.1-1ubuntu3.13) over (1:13.99.1-1ubuntu3.10) ...
      Preparing to unpack .../6-libasound2_1.2.2-2.1ubuntu2.5_amd64.deb ...
      Unpacking libasound2:amd64 (1.2.2-2.1ubuntu2.5) over (1.2.2-2.1ubuntu2.3) ...
      Preparing to unpack .../7-libasound2-data_1.2.2-2.1ubuntu2.5_all.deb ...
      Unpacking libasound2-data (1.2.2-2.1ubuntu2.5) over (1.2.2-2.1ubuntu2.3) ...
      Setting up libpulse0:amd64 (1:13.99.1-1ubuntu3.13) ...
      Setting up libpulsedsp:amd64 (1:13.99.1-1ubuntu3.13) ...
      Setting up libasound2-data (1.2.2-2.1ubuntu2.5) ...
      Setting up libpulse-mainloop-glib0:amd64 (1:13.99.1-1ubuntu3.13) ...
      Setting up pulseaudio-utils (1:13.99.1-1ubuntu3.13) ...
      Setting up libasound2:amd64 (1.2.2-2.1ubuntu2.5) ...
      Setting up pulseaudio (1:13.99.1-1ubuntu3.13) ...
      insserv: warning: script 'joindomain.sh' missing LSB tags and overrides
      Setting up pulseaudio-module-bluetooth (1:13.99.1-1ubuntu3.13) ...
      Processing triggers for systemd (245.4-4ubuntu3.20) ...
      Processing triggers for man-db (2.9.1-1) ...
      Processing triggers for dbus (1.12.16-2ubuntu2.3) ...
      Processing triggers for libc-bin (2.31-0ubuntu9.7) ...
      Current status: 196 (-8) upgradable.
      Run CMD Task:[sudo aptitude install ros-foxy-desktop -y]
      [] cmake{a} cmake-data{a} cppcheck{a} cython3{a} default-libmysqlclient-dev{a} freeglut3{a} gcc-7-base{a} gdal-data{a} google-mock{a} googletest{a} graphviz{a} hdf5-helpers{a} i965-va-driver{a} icu-devtools{a} intel-media-va-driver{a} javascript-common{a} libaacs0{a} libaec-dev{a} libaec0{a} libann0{a} libaom0{a} libarmadillo-dev{a} libarmadillo9{a} libarpack2{a} libarpack2-dev{a} libasan4{a} libasound2-dev{a} libassimp-dev{a} libassimp5{a} libavcodec-dev{a} libavcodec58{a} libavformat-dev{a} libavformat58{a} libavresample-dev{a} libavresample4{a} libavutil-dev{a} libavutil56{a} libbdplus0{a} libblas-dev{a} libblas3{a} libblkid-dev{a} libbluray2{a} libboost-all-dev{a} libboost-atomic-dev{a} libboost-atomic1.71-dev{a} libboost-atomic1.71.0{a} libboost-chrono-dev{a} libboost-chrono1.71-dev{a} libboost-container-dev{a} libboost-container1.71-dev{a} libboost-container1.71.0{a} libboost-context-dev{a} libboost-context1.71-dev{a} libboost-context1.71.0{a} libboost-coroutine-dev{a} libboost-coroutine1.71-dev{a} libboost-coroutine1.71.0{a} libboost-date-time-dev{a} libboost-date-time1.71-dev{a} libboost-dev{a} libboost-exception-dev{a} libboost-exception1.71-dev{a} libboost-fiber-dev{a} libboost-fiber1.71-dev{a} libboost-fiber1.71.0{a} libboost-filesystem-dev{a} libboost-filesystem1.71-dev{a} libboost-graph-dev{a} libboost-graph-parallel-dev{a} libboost-graph-parallel1.71-dev{a} libboost-graph-parallel1.71.0{a} libboost-graph1.71-dev{a} libboost-graph1.71.0{a} libboost-iostreams-dev{a} libboost-iostreams1.71-dev{a} libboost-locale-dev{a} libboost-locale1.71-dev{a} libboost-log-dev{a} libboost-log1.71-dev{a} libboost-log1.71.0{a} libboost-math-dev{a} libboost-math1.71-dev{a} libboost-math1.71.0{a} libboost-mpi-dev{a} libboost-mpi-python-dev{a} libboost-mpi-python1.71-dev{a} libboost-mpi-python1.71.0{a} libboost-mpi1.71-dev{a} libboost-mpi1.71.0{a} libboost-numpy-dev{a} libboost-numpy1.71-dev{a} libboost-numpy1.71.0{a} libboost-program-options-dev{a} libboost-program-options1.71-dev{a} libboost-program-options1.71.0{a} libboost-python-dev{a} libboost-python1.71-dev{a} libboost-python1.71.0{a} libboost-random-dev{a} libboost-random1.71-dev{a} libboost-random1.71.0{a} libboost-regex-dev{a} libboost-regex1.71-dev{a} libboost-serialization-dev{a} libboost-serialization1.71-dev{a} libboost-serialization1.71.0{a} libboost-stacktrace-dev{a} libboost-stacktrace1.71-dev{a} libboost-stacktrace1.71.0{a} libboost-system-dev{a} libboost-system1.71-dev{a} libboost-system1.71.0{a} libboost-test-dev{a} libboost-test1.71-dev{a} libboost-test1.71.0{a} libboost-thread-dev{a} libboost-thread1.71-dev{a} libboost-timer-dev{a} libboost-timer1.71-dev{a} libboost-timer1.71.0{a} libboost-tools-dev{a} libboost-type-erasure-dev{a} libboost-type-erasure1.71-dev{a} libboost-type-erasure1.71.0{a} libboost-wave-dev{a} libboost-wave1.71-dev{a} libboost-wave1.71.0{a} libboost1.71-dev{a} libboost1.71-tools-dev{a} libbullet-dev{a} libbullet2.88{a} libcaf-openmpi-3{a} libcdt5{a} libcfitsio-dev{a} libcfitsio-doc{a} libcfitsio8{a} libcgraph6{a} libcharls-dev{a} libcharls2{a} libchromaprint1{a} libcilkrts5{a} libclang1-10{a} libcoarrays-openmpi-dev{a} libcodec2-0.9{a} libconsole-bridge-dev{a} libcurl4-gnutls-dev{ab} libcurl4-openssl-dev{ab} libdap-dev{a} libdap25{a} libdapclient6v5{a} libdapserver7v5{a} libdbus-1-dev{a} libdc1394-22{a} libdc1394-22-dev{a} libegl-dev{a} libegl1-mesa-dev{a} libeigen3-dev{a} libepsilon-dev{a} libepsilon1{a} libevent-core-2.1-7{a} libevent-dev{a} libevent-extra-2.1-7{a} libevent-openssl-2.1-7{a} libevent-pthreads-2.1-7{a} libexif-dev{a} libexif-doc{a} libexpat1-dev{a} libfabric1{a} libffi-dev{a} libflann-dev{a} libflann1.9{a} libfontconfig1-dev{a} libfreetype-dev{a} libfreetype6-dev{a} libfreexl-dev{a} libfreexl1{a} libfyba-dev{a} libfyba0{a} libgcc-7-dev{a} libgdal-dev{a} libgdal26{a} libgdcm-dev{a} libgdcm3.0{a} libgeos-3.8.0{a} libgeos-c1v5{a} libgeos-dev{a} libgeotiff-dev{a} libgeotiff5{a} libgif-dev{a} libgl-dev{a} libgl1-mesa-dev{a} libgl2ps-dev{a} libgl2ps1.4{a} libgles-dev{a} libgles1{a} libgles2-mesa-dev{a} libglew-dev{a} libglew2.1{a} libglib2.0-dev{a} libglib2.0-dev-bin{a} libglu1-mesa-dev{a} libglvnd-dev{a} libglx-dev{a} libgme0{a} libgphoto2-dev{a} libgtest-dev{a} libgts-0.7-5{a} libgts-bin{a} libgvc6{a} libgvpr2{a} libhdf4-0-alt{a} libhdf4-alt-dev{a} libhdf5-103{a} libhdf5-cpp-103{a} libhdf5-dev{a} libhdf5-mpi-dev{a} libhdf5-openmpi-103{a} libhdf5-openmpi-dev{a} libhwloc-dev{a} libhwloc-plugins{a} libhwloc15{a} libibus-1.0-dev{ab} libibverbs-dev{a} libice-dev{a} libicu-dev{a} libigdgmm11{a} libilmbase-dev{a} libilmbase24{a} libjbig-dev{a} libjpeg-dev{a} libjpeg-turbo8-dev{a} libjpeg8-dev{a} libjs-jquery{a} libjs-jquery-ui{a} libjson-c-dev{a} libjsoncpp-dev{a} libjsoncpp1{a} libkml-dev{a} libkmlbase1{a} libkmlconvenience1{a} libkmldom1{a} libkmlengine1{a} libkmlregionator1{a} libkmlxsd1{a} liblab-gamut1{a} liblapack-dev{a} liblapack3{a} liblept5{a} libllvm10{a} liblz4-dev{a} liblzma-dev{a} libminizip-dev{a} libminizip1{a} libmount-dev{a} libmysqlclient-dev{a} libnetcdf-c++4{a} libnetcdf-cxx-legacy-dev{a} libnetcdf-dev{a} libnetcdf15{a} libnl-3-dev{a} libnl-route-3-dev{a} libnuma-dev{a} libogdi-dev{a} libogdi4.1{a} libogg-dev{a} libopencv-calib3d-dev{a} libopencv-calib3d4.2{a} libopencv-contrib-dev{a} libopencv-contrib4.2{a} libopencv-core-dev{a} libopencv-core4.2{a} libopencv-dev{a} libopencv-dnn-dev{a} libopencv-dnn4.2{a} libopencv-features2d-dev{a} libopencv-features2d4.2{a} libopencv-flann-dev{a} libopencv-flann4.2{a} libopencv-highgui-dev{a} libopencv-highgui4.2{a} libopencv-imgcodecs-dev{a} libopencv-imgcodecs4.2{a} libopencv-imgproc-dev{a} libopencv-imgproc4.2{a} libopencv-ml-dev{a} libopencv-ml4.2{a} libopencv-objdetect-dev{a} libopencv-objdetect4.2{a} libopencv-photo-dev{a} libopencv-photo4.2{a} libopencv-shape-dev{a} libopencv-shape4.2{a} libopencv-stitching-dev{a} libopencv-stitching4.2{a} libopencv-superres-dev{a} libopencv-superres4.2{a} libopencv-ts-dev{a} libopencv-video-dev{a} libopencv-video4.2{a} libopencv-videoio-dev{a} libopencv-videoio4.2{a} libopencv-videostab-dev{a} libopencv-videostab4.2{a} libopencv-viz-dev{a} libopencv-viz4.2{a} libopencv4.2-java{a} libopencv4.2-jni{a} libopenexr-dev{a} libopenexr24{a} libopengl-dev{a} libopenjp2-7-dev{a} libopenmpi-dev{a} libopenmpi3{a} libopenmpt0{a} libopenni-dev{a} libopenni-sensor-pointclouds0{a} libopenni0{a} libopenni2-0{a} libopenni2-dev{a} libpathplan4{a} libpcl-apps1.10{a} libpcl-common1.10{a} libpcl-dev{a} libpcl-features1.10{a} libpcl-filters1.10{a} libpcl-io1.10{a} libpcl-kdtree1.10{a} libpcl-keypoints1.10{a} libpcl-ml1.10{a} libpcl-octree1.10{a} libpcl-outofcore1.10{a} libpcl-people1.10{a} libpcl-recognition1.10{a} libpcl-registration1.10{a} libpcl-sample-consensus1.10{a} libpcl-search1.10{a} libpcl-segmentation1.10{a} libpcl-stereo1.10{a} libpcl-surface1.10{a} libpcl-tracking1.10{a} libpcl-visualization1.10{a} libpcre16-3{a} libpcre2-dev{a} libpcre2-posix2{a} libpcre3-dev{a} libpcre32-3{a} libpcrecpp0v5{a} libpmix2{a} libpng-dev{a} libpng-tools{a} libpoppler-dev{a} libpoppler-private-dev{a} libpq-dev{a} libpq5{a} libproj-dev{a} libproj15{a} libpsm-infinipath1{a} libpsm2-2{a} libpthread-stubs0-dev{a} libpulse-dev{a} libpyside2-dev{a} libpyside2-py3-5.14{a} libpython2-stdlib{a} libpython2.7-minimal{a} libpython2.7-stdlib{a} libpython3-dev{a} libpython3.8-dev{a} libqhull-dev{a} libqhull-r7{a} libqhull7{a} libqt5concurrent5{a} libqt5designer5{a} libqt5designercomponents5{a} libqt5help5{a} libqt5opengl5{a} libqt5opengl5-dev{a} libqt5positioning5{a} libqt5printsupport5{a} libqt5qml5{a} libqt5quick5{a} libqt5quickparticles5{a} libqt5quickshapes5{a} libqt5quicktest5{a} libqt5quickwidgets5{a} libqt5sensors5{a} libqt5sql5{a} libqt5sql5-sqlite{a} libqt5test5{a} libqt5webchannel5{a} libqt5webkit5{a} libqt5webkit5-dev{a} libqt5x11extras5{a} libqt5xml5{a} libraw1394-dev{a} libraw1394-tools{a} librhash0{a} libsdl2-dev{ab} libselinux1-dev{a} libsepol1-dev{a} libshiboken2-dev{a} libshiboken2-py3-5.14{a} libshine3{a} libsm-dev{a} libsnappy1v5{a} libsndio-dev{a} libsocket++1{a} libspatialite-dev{a} libspatialite7{a} libspdlog-dev{a} libspdlog1{a} libsqlite3-dev{a} libssh-gcrypt-4{a} libssl-dev{a} libstdc++-7-dev{a} libsuperlu-dev{a} libsuperlu5{a} libswresample-dev{a} libswresample3{a} libswscale-dev{a} libswscale5{a} libsz2{a} libtbb-dev{a} libtbb2{a} libtesseract4{a} libtheora-dev{a} libtiff-dev{a} libtiffxx5{a} libtinyxml-dev{a} libtinyxml2-6a{a} libtinyxml2-dev{a} libubsan0{a} libudev-dev{a} liburiparser-dev{a} liburiparser1{a} libva-drm2{a} libva-x11-2{a} libva2{a} libvdpau1{a} libvtk6.3{a} libvtk7-dev{a} libvtk7-java{a} libvtk7-jni{a} libvtk7-qt-dev{a} libvtk7.1p{a} libvtk7.1p-qt{a} libvulkan-dev{a} libwayland-bin{a} libwayland-dev{a} libwebp-dev{a} libx11-dev{a} libx264-155{a} libx265-179{a} libxau-dev{a} libxaw7-dev{a} libxcb1-dev{a} libxcursor-dev{a} libxdmcp-dev{a} libxerces-c-dev{a} libxerces-c3.2{a} libxext-dev{a} libxfixes-dev{a} libxft-dev{a} libxi-dev{a} libxinerama-dev{a} libxkbcommon-dev{a} libxml2-dev{a} libxmu-dev{a} libxmu-headers{a} libxnvctrl0{a} libxpm-dev{a} libxrandr-dev{a} libxrender-dev{a} libxss-dev{a} libxt-dev{a} libxv-dev{a} libxvidcore4{a} libxxf86vm-dev{a} libyaml-dev{a} libzstd-dev{a} libzvbi-common{a} libzvbi0{a} mesa-va-drivers{a} mesa-vdpau-drivers{a} mpi-default-bin{a} mpi-default-dev{a} odbcinst{a} odbcinst1debian2{a} opencv-data{a} openmpi-bin{a} openmpi-common{a} openni-utils{a} proj-bin{a} proj-data{a} pydocstyle{a} pyflakes{a} pyflakes3{a} pyqt5-dev{a} python-matplotlib-data{a} python-pkg-resources{a} python-pyflakes{a} python2{a} python2-minimal{a} python2.7{a} python2.7-minimal{a} python3-atomicwrites{a} python3-attr{a} python3-autobahn{a} python3-automat{a} python3-bs4{a} python3-cbor{a} python3-constantly{a} python3-cycler{a} python3-dev{a} python3-flake8{a} python3-hamcrest{a} python3-html5lib{a} python3-hyperlink{a} python3-ifcfg{a} python3-incremental{a} python3-kiwisolver{a} python3-lark{a} python3-lxml{a} python3-lz4{a} python3-matplotlib{a} python3-mccabe{a} python3-mock{a} python3-mpi4py{a} python3-numpy{a} python3-opencv{a} python3-pbr{a} python3-pluggy{a} python3-png{a} python3-psutil{a} python3-py{a} python3-pyasn1{a} python3-pyasn1-modules{a} python3-pycodestyle{a} python3-pydocstyle{a} python3-pydot{a} python3-pyflakes{a} python3-pyqrcode{a} python3-pyqt5{a} python3-pyqt5.qtsvg{a} python3-pyside2.qtcore{a} python3-pyside2.qtgui{a} python3-pyside2.qtsvg{a} python3-pyside2.qtwidgets{a} python3-pytest{a} python3-service-identity{a} python3-sip{a} python3-sip-dev{a} python3-snappy{a} python3-snowballstemmer{a} python3-soupsieve{a} python3-trie{a} python3-twisted{a} python3-twisted-bin{a} python3-txaio{a} python3-u-msgpack{a} python3-ubjson{a} python3-vtk7{a} python3-wcwidth{a} python3-webencodings{a} python3-wsaccel{a} python3-zope.interface{a} python3.8-dev{a} qdoc-qt5{a} qhelpgenerator-qt5{a} qt5-assistant{a} qt5-qmake{a} qt5-qmake-bin{a} qt5-qmltooling-plugins{a} qtattributionsscanner-qt5{a} qtbase5-dev{a} qtbase5-dev-tools{a} qtchooser{a} qtdeclarative5-dev{a} qtdeclarative5-dev-tools{a} qttools5-dev{a} qttools5-dev-tools{a} qttools5-private-dev{a} ros-foxy-action-msgs{a} ros-foxy-action-tutorials-cpp{a} ros-foxy-action-tutorials-interfaces{a} ros-foxy-action-tutorials-py{a} ros-foxy-actionlib-msgs{a} ros-foxy-ament-cmake{a} ros-foxy-ament-cmake-auto{a} ros-foxy-ament-cmake-copyright{a} ros-foxy-ament-cmake-core{a} ros-foxy-ament-cmake-cppcheck{a} ros-foxy-ament-cmake-cpplint{a} ros-foxy-ament-cmake-export-definitions{a} ros-foxy-ament-cmake-export-dependencies{a} ros-foxy-ament-cmake-export-include-directories{a} ros-foxy-ament-cmake-export-interfaces{a} ros-foxy-ament-cmake-export-libraries{a} ros-foxy-ament-cmake-export-link-flags{a} ros-foxy-ament-cmake-export-targets{a} ros-foxy-ament-cmake-flake8{a} ros-foxy-ament-cmake-gmock{a} ros-foxy-ament-cmake-gtest{a} ros-foxy-ament-cmake-include-directories{a} ros-foxy-ament-cmake-libraries{a} ros-foxy-ament-cmake-lint-cmake{a} ros-foxy-ament-cmake-pep257{a} ros-foxy-ament-cmake-pytest{a} ros-foxy-ament-cmake-python{a} ros-foxy-ament-cmake-ros{a} ros-foxy-ament-cmake-target-dependencies{a} ros-foxy-ament-cmake-test{a} ros-foxy-ament-cmake-uncrustify{a} ros-foxy-ament-cmake-version{a} ros-foxy-ament-cmake-xmllint{a} ros-foxy-ament-copyright{a} ros-foxy-ament-cppcheck{a} ros-foxy-ament-cpplint{a} ros-foxy-ament-flake8{a} ros-foxy-ament-index-cpp{a} ros-foxy-ament-index-python{a} ros-foxy-ament-lint{a} ros-foxy-ament-lint-auto{a} ros-foxy-ament-lint-cmake{a} ros-foxy-ament-lint-common{a} ros-foxy-ament-package{a} ros-foxy-ament-pep257{a} ros-foxy-ament-uncrustify{a} ros-foxy-ament-xmllint{a} ros-foxy-angles{a} ros-foxy-builtin-interfaces{a} ros-foxy-class-loader{a} ros-foxy-common-interfaces{a} ros-foxy-composition{a} ros-foxy-composition-interfaces{a} ros-foxy-console-bridge-vendor{a} ros-foxy-cv-bridge{a} ros-foxy-demo-nodes-cpp{a} ros-foxy-demo-nodes-cpp-native{a} ros-foxy-demo-nodes-py{a} ros-foxy-depthimage-to-laserscan{a} ros-foxy-desktop ros-foxy-diagnostic-msgs{a} ros-foxy-domain-coordinator{a} ros-foxy-dummy-map-server{a} ros-foxy-dummy-robot-bringup{a} ros-foxy-dummy-sensors{a} ros-foxy-eigen3-cmake-module{a} ros-foxy-example-interfaces{a} ros-foxy-examples-rclcpp-minimal-action-client{a} ros-foxy-examples-rclcpp-minimal-action-server{a} ros-foxy-examples-rclcpp-minimal-client{a} ros-foxy-examples-rclcpp-minimal-composition{a} ros-foxy-examples-rclcpp-minimal-publisher{a} ros-foxy-examples-rclcpp-minimal-service{a} ros-foxy-examples-rclcpp-minimal-subscriber{a} ros-foxy-examples-rclcpp-minimal-timer{a} ros-foxy-examples-rclcpp-multithreaded-executor{a} ros-foxy-examples-rclpy-executors{a} ros-foxy-examples-rclpy-minimal-action-client{a} ros-foxy-examples-rclpy-minimal-action-server{a} ros-foxy-examples-rclpy-minimal-client{a} ros-foxy-examples-rclpy-minimal-publisher{a} ros-foxy-examples-rclpy-minimal-service{a} ros-foxy-examples-rclpy-minimal-subscriber{a} ros-foxy-fastcdr{a} ros-foxy-fastrtps{a} ros-foxy-fastrtps-cmake-module{a} ros-foxy-foonathan-memory-vendor{a} ros-foxy-geometry-msgs{a} ros-foxy-geometry2{a} ros-foxy-gmock-vendor{a} ros-foxy-gtest-vendor{a} ros-foxy-image-geometry{a} ros-foxy-image-tools{a} ros-foxy-image-transport{a} ros-foxy-interactive-markers{a} ros-foxy-intra-process-demo{a} ros-foxy-joy{a} ros-foxy-kdl-parser{a} ros-foxy-laser-geometry{a} ros-foxy-launch{a} ros-foxy-launch-ros{a} ros-foxy-launch-testing{a} ros-foxy-launch-testing-ament-cmake{a} ros-foxy-launch-testing-ros{a} ros-foxy-launch-xml{a} ros-foxy-launch-yaml{a} ros-foxy-libcurl-vendor{a} ros-foxy-libstatistics-collector{a} ros-foxy-libyaml-vendor{a} ros-foxy-lifecycle{a} ros-foxy-lifecycle-msgs{a} ros-foxy-logging-demo{a} ros-foxy-map-msgs{a} ros-foxy-message-filters{a} ros-foxy-nav-msgs{a} ros-foxy-orocos-kdl{a} ros-foxy-osrf-pycommon{a} ros-foxy-pcl-conversions{a} ros-foxy-pcl-msgs{a} ros-foxy-pendulum-control{a} ros-foxy-pendulum-msgs{a} ros-foxy-pluginlib{a} ros-foxy-python-cmake-module{a} ros-foxy-python-qt-binding{a} ros-foxy-qt-dotgraph{a} ros-foxy-qt-gui{a} ros-foxy-qt-gui-cpp{a} ros-foxy-qt-gui-py-common{a} ros-foxy-quality-of-service-demo-cpp{a} ros-foxy-quality-of-service-demo-py{a} ros-foxy-rcl{a} ros-foxy-rcl-action{a} ros-foxy-rcl-interfaces{a} ros-foxy-rcl-lifecycle{a} ros-foxy-rcl-logging-spdlog{a} ros-foxy-rcl-yaml-param-parser{a} ros-foxy-rclcpp{a} ros-foxy-rclcpp-action{a} ros-foxy-rclcpp-components{a} ros-foxy-rclcpp-lifecycle{a} ros-foxy-rclpy{a} ros-foxy-rcpputils{a} ros-foxy-rcutils{a} ros-foxy-resource-retriever{a} ros-foxy-rmw{a} ros-foxy-rmw-dds-common{a} ros-foxy-rmw-fastrtps-cpp{a} ros-foxy-rmw-fastrtps-shared-cpp{a} ros-foxy-rmw-implementation{a} ros-foxy-rmw-implementation-cmake{a} ros-foxy-robot-state-publisher{a} ros-foxy-ros-base{a} ros-foxy-ros-core{a} ros-foxy-ros-environment{a} ros-foxy-ros-workspace{a} ros-foxy-ros2action{a} ros-foxy-ros2bag{a} ros-foxy-ros2cli{a} ros-foxy-ros2component{a} ros-foxy-ros2doctor{a} ros-foxy-ros2interface{a} ros-foxy-ros2launch{a} ros-foxy-ros2lifecycle{a} ros-foxy-ros2multicast{a} ros-foxy-ros2node{a} ros-foxy-ros2param{a} ros-foxy-ros2pkg{a} ros-foxy-ros2run{a} ros-foxy-ros2service{a} ros-foxy-ros2topic{a} ros-foxy-rosbag2{a} ros-foxy-rosbag2-compression{a} ros-foxy-rosbag2-converter-default-plugins{a} ros-foxy-rosbag2-cpp{a} ros-foxy-rosbag2-storage{a} ros-foxy-rosbag2-storage-default-plugins{a} ros-foxy-rosbag2-transport{a} ros-foxy-rosgraph-msgs{a} ros-foxy-rosidl-adapter{a} ros-foxy-rosidl-cmake{a} ros-foxy-rosidl-default-generators{a} ros-foxy-rosidl-default-runtime{a} ros-foxy-rosidl-generator-c{a} ros-foxy-rosidl-generator-cpp{a} ros-foxy-rosidl-generator-py{a} ros-foxy-rosidl-parser{a} ros-foxy-rosidl-runtime-c{a} ros-foxy-rosidl-runtime-cpp{a} ros-foxy-rosidl-runtime-py{a} ros-foxy-rosidl-typesupport-c{a} ros-foxy-rosidl-typesupport-cpp{a} ros-foxy-rosidl-typesupport-fastrtps-c{a} ros-foxy-rosidl-typesupport-fastrtps-cpp{a} ros-foxy-rosidl-typesupport-interface{a} ros-foxy-rosidl-typesupport-introspection-c{a} ros-foxy-rosidl-typesupport-introspection-cpp{a} ros-foxy-rpyutils{a} ros-foxy-rqt-action{a} ros-foxy-rqt-common-plugins{a} ros-foxy-rqt-console{a} ros-foxy-rqt-graph{a} ros-foxy-rqt-gui{a} ros-foxy-rqt-gui-cpp{a} ros-foxy-rqt-gui-py{a} ros-foxy-rqt-image-view{a} ros-foxy-rqt-msg{a} ros-foxy-rqt-plot{a} ros-foxy-rqt-publisher{a} ros-foxy-rqt-py-common{a} ros-foxy-rqt-py-console{a} ros-foxy-rqt-reconfigure{a} ros-foxy-rqt-service-caller{a} ros-foxy-rqt-shell{a} ros-foxy-rqt-srv{a} ros-foxy-rqt-top{a} ros-foxy-rqt-topic{a} ros-foxy-rttest{a} ros-foxy-rviz-assimp-vendor{a} ros-foxy-rviz-common{a} ros-foxy-rviz-default-plugins{a} ros-foxy-rviz-ogre-vendor{a} ros-foxy-rviz-rendering{a} ros-foxy-rviz2{a} ros-foxy-sdl2-vendor{a} ros-foxy-sensor-msgs{a} ros-foxy-shape-msgs{a} ros-foxy-shared-queues-vendor{a} ros-foxy-spdlog-vendor{a} ros-foxy-sqlite3-vendor{a} ros-foxy-sros2{a} ros-foxy-sros2-cmake{a} ros-foxy-statistics-msgs{a} ros-foxy-std-msgs{a} ros-foxy-std-srvs{a} ros-foxy-stereo-msgs{a} ros-foxy-tango-icons-vendor{a} ros-foxy-teleop-twist-joy{a} ros-foxy-teleop-twist-keyboard{a} ros-foxy-tf2{a} ros-foxy-tf2-bullet{a} ros-foxy-tf2-eigen{a} ros-foxy-tf2-geometry-msgs{a} ros-foxy-tf2-kdl{a} ros-foxy-tf2-msgs{a} ros-foxy-tf2-py{a} ros-foxy-tf2-ros{a} ros-foxy-tf2-sensor-msgs{a} ros-foxy-tf2-tools{a} ros-foxy-tinyxml-vendor{a} ros-foxy-tinyxml2-vendor{a} ros-foxy-tlsf{a} ros-foxy-tlsf-cpp{a} ros-foxy-topic-monitor{a} ros-foxy-tracetools{a} ros-foxy-trajectory-msgs{a} ros-foxy-turtlesim{a} ros-foxy-uncrustify-vendor{a} ros-foxy-unique-identifier-msgs{a} ros-foxy-urdf{a} ros-foxy-urdfdom{a} ros-foxy-urdfdom-headers{a} ros-foxy-visualization-msgs{a} ros-foxy-yaml-cpp-vendor{a} ros-foxy-zstd-vendor{a} shiboken2{a} sip-dev{a} tcl-dev{a} tcl-vtk7{a} tcl8.6-dev{a} tk-dev{a} tk8.6-dev{a} uncrustify{a} unixodbc-dev{ab} uuid-dev{a} va-driver-all{a} vdpau-driver-all{a} vtk7{a} x11proto-core-dev{a} x11proto-dev{a} x11proto-input-dev{a} x11proto-randr-dev{a} x11proto-scrnsaver-dev{a} x11proto-xext-dev{a} x11proto-xf86vidmode-dev[-]Result:success .img-5.15.0-76-genericverrides..v1 amd64 245.4-4ubuntu3.22 [75.4 kB]
      Run CMD Task:[sudo apt-cache search python3-colcon-common-extensions ]
      [-]Result:success ackage aggregating colcon-core and common extensions.
      [-]Result:success buntu9.7) ........1.0-1) ...) ...b ..._all.deb ...b ...8.7 kB]02 B][108 kB]2 B]B]1.0-1 [7,508 B]
      [-]Result:success e and 194 not upgraded.tu1).
      Run CMD Task:[ls /opt/ros/foxy/setup.bash]
      [-]Result:code:2
      [-]Result:code:2
