    ROS2入门篇第3章-自定义接口RCLCPP实战colcon build失败
    编译出错 自定义接口
    1.5k
    • 6516968996
      651696899
      ROS2入门篇第3章-自定义接口RCLCPP实战colcon build失败代码也没问题啊,1df25682-30c8-4505-9fff-5727c8f7ab1b-image.png
      • 6516968996
        651696899
        # 直接使用ROS2原始的数据类型
        string content
        # 图像消息,调用sensor_msgs下的Image类型
        sensor_msgs/Image image
        • 6516968996
          651696899
          project(village_interfaces)
          endif()
          # find dependencies
          #添加对sensor_msgs的
          find_package(sensor_msgs REQUIRED)
          #添加消息文件和依赖
            "msg/Novel.msg"
             DEPENDENCIES sensor_msgs
          if(BUILD_TESTING)
          endif()
          ament_package()
          • 6516968996
            651696899
            <?xml version="1.0"?>
            <package format="3">
              <name>village_interfaces</name>
              <version>0.0.0</version>
              <maintainer email="lzh@todo.todo">lzh</maintainer>
              <license>TODO: License declaration</license>
              <depend>sensor_msgs</depend>
              <build_depend>rosidl_default_generators</build_depend>
              <exec_depend>rosidl_default_runtime</exec_depend>
              <export>
              </export>
            </package>
