    建立话题发布的时候提示timer_callback referenced before assignment
    ros2通信 ros2-foxy
    2.1k
    • JerryNingJ
      JerryNing
      求解答!
        小鱼 技术大佬 @JerryNing
        @JerryNing 代码缩进有问题,退格一下:
        另外
        JerryNingJ 2 条回复 最后回复 回复 引用 0
        • JerryNingJ
          JerryNing @小鱼
          @小鱼 更改之后还是会提醒未声名timer_callback
          import rclpy
          from rclpy.node import Node
          from std_msgs.msg import String,UInt32
          class WriterNode(Node):
          def init(self,name):
              super().__init__(name)
              self.get_logger().info("dajiahao woshizuojia %s"%name)
              #声明并创建发布者
              self.pub_novel=self.create_publisher(String,"sexy_gril",10)
              self.count=0
              self.timer_period=5
              self.timer=self.create_timer(self.timer_period,timer_callback)
              self.account=80
              self.syb_money=self.create_subscription(UInt32,"sexy_girl_money",self.recv_money_callback,10)
          def recv_money_callback(self,money):
              self.account+=money.data
              self.get_logger().info("shoudaole%ddegaofei xianzaizhanghuliyou%dqian"%(money.data,self.count))
          def timer_callback(self):
              msg=String()
              msg.data="我是一个帅哥%d"%(self.count)
              self.pub_novel.publish(msg)
              self.get_logger().info("发布了一个章节的小说,内容是%s"%msg.data)
              self.count+=1
          def main(args=None):
          rclpy.init(args=args)
          li4_node=WriterNode("li5")
          rclpy.spin(li4_node)
          rclpy.shutdown()
          • JerryNingJ
            JerryNing @小鱼
              小鱼 技术大佬 @JerryNing
              @JerryNing 在 建立话题发布的时候提示timer_callback referenced before assignment 中说:
              self.timer_callback
