    启动fishbot建图程序后应该从哪里提取定位数据?
    evo 定位
    16.4k
      小鱼 技术大佬 @siviechen
      @siviechen 那就真的可能没人发布frame,你可以把这里的做一下
      https://fishros.com/d2lros2/#/
      siviechenS 2 条回复 最后回复 回复 引用 0
      • siviechenS
        砖头 @小鱼
        @小鱼 行,我试试
        • siviechenS
          砖头 @小鱼
          @小鱼 我想起来教程里有个fishbot_bringup,我就直接拿来用了。但是虽然有了tf树,算法却还是跑不起起来。过程:
          #MicroRos
          #laser
          xhost + && sudo docker run  -it --rm  -v /dev:/dev -v /dev/shm:/dev/shm --privileged  -v /tmp/.X11-unix:/tmp/.X11-unix --device /dev/snd -e DISPLAY=unix$DISPLAY -p 8889:8888 registry.cn-hangzhou.aliyuncs.com/fishros/fishbot_laser
          #tf
          ros2 launch fishbot_bringup fishbot_bringup.launch.py
          #carto
          ros2 launch fishbot_cartographer cartographer.launch.py
          #显示tf树
          ros2 run rqt_tf_tree rqt_tf_tree
          #rqt_graph
          rqt_graph
          我个人觉得是ros2新增的qos的问题。启动carto后慢慢翻终端里的信息会找到这么两条:
          [cartographer_node-1] [WARN] [1692678150.099094890] [cartographer logger]: W0822 12:22:30.000000 11917 tf_bridge.cpp:53] Lookup would require extrapolation into the past.  Requested time 1692678149.889606 but the earliest data is at time 1692678149.949214, when looking up transform from frame [odom] to frame [base_link]
          [rviz2-3] [WARN] [1692678150.507302604] [rviz2]: New publisher discovered on topic '/scan', offering incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
          [ERROR] [cartographer_node-1]: process has died [pid 11917, exit code -6, cmd '/home/cxw/fishbot_ws/install/cartographer_ros/lib/cartographer_ros/cartographer_node -configuration_directory /home/cxw/fishbot/install/fishbot_cartographer/share/fishbot_cartographer/config -configuration_basename fishbot_2d.lua --ros-args -r __node:=cartographer_node --params-file /tmp/launch_params_w6i5hcn_'].
          第二条消息是说进程没了,感觉这应该是rqt_graph里连cartographer_node节点都刷不出来的原因?
          小鱼大佬的docker雷达按2启动建图不是很顺利吗,能想到是什么原因吗?
            小鱼 技术大佬 @siviechen
            @siviechen 改一些fishbot_bringup的代码,改成和教程中的一致:
            #include <rclcpp/rclcpp.hpp>
            #include <nav_msgs/msg/odometry.hpp>
            #include <tf2/utils.h>
            #include <tf2_ros/transform_broadcaster.h>
            class TopicSubscribe01 : public rclcpp::Node
            public:
              TopicSubscribe01(std::string name) : Node(name)
                // 创建一个订阅者,订阅"odom"话题的nav_msgs::msg::Odometry类型消息
                odom_subscribe_ = this->create_subscription<nav_msgs::msg::Odometry>(
                  "odom", rclcpp::SensorDataQoS(),
                  std::bind(&TopicSubscribe01::odom_callback, this, std::placeholders::_1));
                // 创建一个tf2_ros::TransformBroadcaster用于广播坐标变换
                tf_broadcaster_ = std::make_unique<tf2_ros::TransformBroadcaster>(this);
            private:
              rclcpp::Subscription<nav_msgs::msg::Odometry>::SharedPtr odom_subscribe_;
              std::unique_ptr<tf2_ros::TransformBroadcaster> tf_broadcaster_;
              nav_msgs::msg::Odometry odom_msg_;
              // 回调函数,处理接收到的odom消息
              void odom_callback(const nav_msgs::msg::Odometry::SharedPtr msg)
                (void)msg;
                RCLCPP_INFO(this->get_logger(), "接收到里程计信息->底盘坐标系 tf :(%f,%f)",
                            msg->pose.pose.position.x, msg->pose.pose.position.y);
                // 更新odom_msg_的姿态信息
                odom_msg_.pose.pose.position.x = msg->pose.pose.position.x;
                odom_msg_.pose.pose.position.y = msg->pose.pose.position.y;
                odom_msg_.pose.pose.position.z = msg->pose.pose.position.z;
                odom_msg_.pose.pose.orientation.x = msg->pose.pose.orientation.x;
                odom_msg_.pose.pose.orientation.y = msg->pose.pose.orientation.y;
                odom_msg_.pose.pose.orientation.z = msg->pose.pose.orientation.z;
                odom_msg_.pose.pose.orientation.w = msg->pose.pose.orientation.w;
            public:
              // 发布坐标变换信息
              void publish_tf()
                geometry_msgs::msg::TransformStamped transform;
                double seconds = this->now().seconds();
                transform.header.stamp = rclcpp::Time(static_cast<uint64_t>(seconds * 1e9));
                transform.header.frame_id = "odom";
                transform.child_frame_id = "base_footprint";
                transform.transform.translation.x = odom_msg_.pose.pose.position.x;
                transform.transform.translation.y = odom_msg_.pose.pose.position.y;
                transform.transform.translation.z = odom_msg_.pose.pose.position.z;
                transform.transform.rotation.x = odom_msg_.pose.pose.orientation.x;
                transform.transform.rotation.y = odom_msg_.pose.pose.orientation.y;
                transform.transform.rotation.z = odom_msg_.pose.pose.orientation.z;
                transform.transform.rotation.w = odom_msg_.pose.pose.orientation.w;
                // 广播坐标变换信息
                tf_broadcaster_->sendTransform(transform);
              // 初始化ROS节点
              rclcpp::init(argc, argv);
              // 创建一个TopicSubscribe01节点
              auto node = std::make_shared<TopicSubscribe01>("fishbot_bringup");
              // 设置循环频率
              rclcpp::WallRate loop_rate(20.0);
              while (rclcpp::ok())
                // 处理回调函数
                rclcpp::spin_some(node);
                // 发布坐标变换信息
                node->publish_tf();
                // 控制循环频率
                loop_rate.sleep();
              // 关闭ROS节点
              rclcpp::shutdown();
              return 0;
            siviechenS 1 条回复 最后回复 回复 引用 0
            • siviechenS
              砖头 @小鱼
              @小鱼 改完了,有两处不同:
              double seconds = this->now().seconds() ; //+ 1.0;   #41行
              rclcpp::WallRate loop_rate(20.0); //(1000.0);   #63行
              编译+source了。但是结果还是没有改变
