    ROS2环境异常
    ros2 ros2环境异常 ros2一键安装
    1.0k
    • 12903898241
      1290389824
      ########遇到了很多次,之前都是通过重装系统解决的################
      Failed to load entry point 'hello': librclpy_common.so: cannot open shared object file: No such file or directory
      The C extension '/opt/ros/foxy/lib/python3.8/site-packages/rclpy/_rclpy.cpython-38-x86_64-linux-gnu.so' failed to be imported while being present on the system. Please refer to 'https://index.ros.org/doc/ros2/Troubleshooting/Installation-Troubleshooting/#import-failing-even-with-library-present-on-the-system' for possible solutions
      /opt/ros/foxy/lib/python3.8/site-packages/ros2doctor/api/init.py: 108: UserWarning: Fail to call PackageCheck class functions.
      /opt/ros/foxy/lib/python3.8/site-packages/ros2doctor/api/init.py: 108: UserWarning: Fail to call PlatformCheck class functions.
      /opt/ros/foxy/lib/python3.8/site-packages/ros2doctor/api/init.py: 95: UserWarning: Check entry point TopicCheck fails to load.
      /opt/ros/foxy/lib/python3.8/site-packages/ros2doctor/api/init.py: 108: UserWarning: Fail to call TopicCheck class functions.
        小鱼 技术大佬 @1290389824
        @1290389824 有装conda吗
