    ros2在gazebo中控制lidar_joint旋转
    ros2 gazebo spawn ros2 control
    680
    • 8118775078
      JQK
      各位大佬,我想通过gazebo仿真实现控制单线雷达关节旋转,完成三维扫描,以下是我运行时的报错,主要在于“Spawn status: Entity [turtlebot3_waffle] already exists”
      ros2 launch turtlebot3_gazebo turtlebot3_house0.launch.py
      [INFO] [launch]: All log files can be found below /home/hql/.ros/log/2023-08-21-14-13-49-966433-hql-ZhaoYang-K4e-ITL-51997
      [INFO] [gzserver-1]: process started with pid [51999]
      [INFO] [gzclient   -2]: process started with pid [52001]
      [INFO] [spawn_entity.py-3]: process started with pid [52004]
      [INFO] [robot_state_publisher-4]: process started with pid [52007]
      [robot_state_publisher-4] Parsing robot urdf xml string.
      [robot_state_publisher-4] Link base_link had 7 children
      [robot_state_publisher-4] Link camera_link had 2 children
      [robot_state_publisher-4] Link camera_depth_frame had 1 children
      [robot_state_publisher-4] Link camera_depth_optical_frame had 0 children
      [robot_state_publisher-4] Link camera_rgb_frame had 1 children
      [robot_state_publisher-4] Link camera_rgb_optical_frame had 0 children
      [robot_state_publisher-4] Link caster_back_left_link had 0 children
      [robot_state_publisher-4] Link caster_back_right_link had 0 children
      [robot_state_publisher-4] Link imu_link had 0 children
      [robot_state_publisher-4] Link base_scan had 0 children
      [robot_state_publisher-4] Link wheel_left_link had 0 children
      [robot_state_publisher-4] Link wheel_right_link had 0 children
      [robot_state_publisher-4] [INFO] [1692598430.338458857] [robot_state_publisher]: got segment base_footprint
      [robot_state_publisher-4] [INFO] [1692598430.338521434] [robot_state_publisher]: got segment base_link
      [robot_state_publisher-4] [INFO] [1692598430.338526266] [robot_state_publisher]: got segment base_scan
      [robot_state_publisher-4] [INFO] [1692598430.338529278] [robot_state_publisher]: got segment camera_depth_frame
      [robot_state_publisher-4] [INFO] [1692598430.338532361] [robot_state_publisher]: got segment camera_depth_optical_frame
      [robot_state_publisher-4] [INFO] [1692598430.338535346] [robot_state_publisher]: got segment camera_link
      [robot_state_publisher-4] [INFO] [1692598430.338538123] [robot_state_publisher]: got segment camera_rgb_frame
      [robot_state_publisher-4] [INFO] [1692598430.338540907] [robot_state_publisher]: got segment camera_rgb_optical_frame
      [robot_state_publisher-4] [INFO] [1692598430.338543632] [robot_state_publisher]: got segment caster_back_left_link
      [robot_state_publisher-4] [INFO] [1692598430.338546345] [robot_state_publisher]: got segment caster_back_right_link
      [robot_state_publisher-4] [INFO] [1692598430.338549126] [robot_state_publisher]: got segment imu_link
      [robot_state_publisher-4] [INFO] [1692598430.338551809] [robot_state_publisher]: got segment wheel_left_link
      [robot_state_publisher-4] [INFO] [1692598430.338554579] [robot_state_publisher]: got segment wheel_right_link
      [spawn_entity.py-3] [INFO] [1692598430.699218816] [spawn_entity]: Spawn Entity started
      [spawn_entity.py-3] [INFO] [1692598430.699438523] [spawn_entity]: Loading entity published on topic robot_description
      [spawn_entity.py-3] [INFO] [1692598430.700504205] [spawn_entity]: Waiting for entity xml on robot_description
      [spawn_entity.py-3] [INFO] [1692598430.712174955] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30
      [spawn_entity.py-3] [INFO] [1692598430.712361052] [spawn_entity]: Waiting for service /spawn_entity
      [gzserver-1] Warning [parser.cc:833] XML Attribute[version] in element[sdf] not defined in SDF, ignoring.
      [gzserver-1] [INFO] [1692598431.457520457] [turtlebot3_imu]: <initial_orientation_as_reference> is unset, using default value of false to comply with REP 145 (world as orientation reference)
      [spawn_entity.py-3] [INFO] [1692598431.466083664] [spawn_entity]: Calling service /spawn_entity
      [spawn_entity.py-3] [INFO] [1692598431.479069834] [spawn_entity]: Spawn status: Entity [turtlebot3_waffle] already exists.
      [spawn_entity.py-3] [ERROR] [1692598431.479316168] [spawn_entity]: Spawn service failed. Exiting.
      [gzserver-1] ../src/intel/isl/isl.c:2105: FINISHME: ../src/intel/isl/isl.c:isl_surf_supports_ccs: CCS for 3D textures is disabled, but a workaround is available.
      [ERROR] [spawn_entity.py-3]: process has died [pid 52004, exit code 1, cmd '/opt/ros/foxy/lib/gazebo_ros/spawn_entity.py -topic robot_description -entity turtlebot3_waffle --ros-args'].
      [INFO] [ros2-5]: process started with pid [52113]
      [gzclient   -2] ../src/intel/isl/isl.c:2105: FINISHME: ../src/intel/isl/isl.c:isl_surf_supports_ccs: CCS for 3D textures is disabled, but a workaround is available.
      [gzserver-1] [INFO] [1692598432.288202592] [camera_driver]: Publishing camera info to [/camera/camera_info]
      [gzserver-1] [INFO] [1692598432.303368286] [turtlebot3_diff_drive]: Wheel pair 1 separation set to [0.287000m]
      [gzserver-1] [INFO] [1692598432.303420511] [turtlebot3_diff_drive]: Wheel pair 1 diameter set to [0.066000m]
      [gzserver-1] [INFO] [1692598432.304143535] [turtlebot3_diff_drive]: Subscribed to [/cmd_vel]
      [gzserver-1] [INFO] [1692598432.304831018] [turtlebot3_diff_drive]: Advertise odometry on [/odom]
      [gzserver-1] [INFO] [1692598432.305499218] [turtlebot3_diff_drive]: Publishing odom transforms between [odom] and [base_footprint]
      [gzserver-1] [INFO] [1692598432.312081807] [turtlebot3_joint_state]: Going to publish joint [wheel_left_joint]
      [gzserver-1] [INFO] [1692598432.312118787] [turtlebot3_joint_state]: Going to publish joint [wheel_right_joint]
      [gzserver-1] [INFO] [1692598432.322473284] [gazebo_ros2_control]: Loading gazebo_ros2_control plugin
      [gzserver-1] [INFO] [1692598432.324913210] [gazebo_ros_control]: Starting gazebo_ros2_control plugin in namespace: /
      [gzserver-1] [INFO] [1692598432.324950093] [gazebo_ros_control]: Starting gazebo_ros2_control plugin in ros 2 node: gazebo_ros_control
      [gzserver-1] [ERROR] [1692598432.324987156] [gazebo_ros_control]: No parameter file provided. Configuration might be wrong
      [gzserver-1] [ERROR] [1692598432.325048344] [gazebo_ros_control]: failed to parse input yaml file(s)
      [ros2-5] Could not contact service /controller_manager/load_controller
      [ERROR] [ros2-5]: process has died [pid 52113, exit code 1, cmd 'ros2 control load_controller --set-state start joint_state_broadcaster'].
      [INFO] [ros2-6]: process started with pid [52213]
      [ros2-6] Could not contact service /controller_manager/load_controller
      [ERROR] [ros2-6]: process has died [pid 52213, exit code 1, cmd 'ros2 control load_controller --set-state start lidar_joint_position_controller'].
      这是我的launch文件
      #!/usr/bin/env python3
      # Copyright 2019 ROBOTIS CO., LTD.
      # Licensed under the Apache License, Version 2.0 (the "License");
      # you may not use this file except in compliance with the License.
      # You may obtain a copy of the License at
      #     http://www.apache.org/licenses/LICENSE-2.0
      # Unless required by applicable law or agreed to in writing, software
      # distributed under the License is distributed on an "AS IS" BASIS,
      # WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
      # See the License for the specific language governing permissions and
      # limitations under the License.
      # Authors: Darby Lim, Ryan Shim
      import os
      from launch.actions import IncludeLaunchDescription
      from launch.actions import ExecuteProcess, IncludeLaunchDescription, RegisterEventHandler
      from launch.event_handlers import OnProcessExit
      import xacro
      TURTLEBOT3_MODEL = os.environ['TURTLEBOT3_MODEL']
          gazebo = IncludeLaunchDescription(
                      PythonLaunchDescriptionSource([os.path.join(
                          get_package_share_directory('gazebo_ros'), 'launch'), '/gazebo.launch.py']),
          use_sim_time = LaunchConfiguration('use_sim_time', default='true')
          world_file_name = 'turtlebot3_houses/' + TURTLEBOT3_MODEL + '.model'
          world = os.path.join(get_package_share_directory('turtlebot3_gazebo'),
                               'worlds', world_file_name)
          world = '/opt/ros/foxy/share/turtlebot3_gazebo/worlds/turtlebot3_houses/waffle.model'
          launch_file_dir = os.path.join(get_package_share_directory('turtlebot3_gazebo'), 'launch')
          pkg_gazebo_ros = get_package_share_directory('gazebo_ros')
          turtlebot3_description_path = os.path.join(
              get_package_share_directory('turtlebot3_description'))
          xacro_file = os.path.join(turtlebot3_description_path,
                                    'urdf',
                                    'turtlebot3_waffle.xacro.urdf')
          doc = xacro.parse(open(xacro_file))
          xacro.process_doc(doc)
          params = {'robot_description': doc.toxml()}
          node_robot_state_publisher = Node(
              output='screen',
              parameters=[params]
          spawn_entity = Node(package='gazebo_ros', executable='spawn_entity.py',
                              arguments=['-topic', 'robot_description',
                                         '-entity', 'turtlebot3_waffle'],
                              output='screen')
          load_joint_state_controller = ExecuteProcess(
              cmd=['ros2', 'control', 'load_controller', '--set-state', 'start',
                   'joint_state_broadcaster'],
              output='screen'
          load_position_controllers = ExecuteProcess(
                   'lidar_joint_position_controller'],
              output='screen'
          return LaunchDescription([
              RegisterEventHandler(
                  event_handler=OnProcessExit(
                      target_action=spawn_entity,
                      on_exit=[load_joint_state_controller],
                      target_action=load_joint_state_controller,
                      on_exit=[load_position_controllers],
              #gazebo,
                      os.path.join(pkg_gazebo_ros, 'launch', 'gzserver.launch.py')
                  launch_arguments={'world': world}.items(),
                   os.path.join(pkg_gazebo_ros, 'launch', 'gzclient.launch.py')
              spawn_entity,
              node_robot_state_publisher,
      我测试发现加载一个空的gazebo环境不会出现以上问题,且可以通过发布话题实现控制lidar_joint的运动,不知到原因是什么
        小鱼 技术大佬 @811877507
        @811877507 因为非空的world里已经有一个小车了,你再加载小车,so...
        8118775078 小鱼小 3 条回复 最后回复 回复 引用 0
        • 8118775078
          JQK @小鱼
          @小鱼 大佬,那我该怎么通过spawn加载房间环境和小车呢
          • 8118775078
            JQK @小鱼
            @小鱼 我是想用ros control控制house环境中的车的关节运动,大佬帮我看看有launch文件有问题吗
              小鱼 技术大佬 @小鱼
              @小鱼 把非空里的launch删除掉就好了
              8118775078 1 条回复 最后回复 回复 引用 0
              • 8118775078
                JQK @小鱼
                @小鱼 我发现我spawn_entity如果穿入的参数是topic的话,还能正常运行,只是gazebo不显示模型,但是如果参数是database的话,虽然gazebo显示模型,但是gazebo_ros_control报错,load_controller失败
                [INFO] [launch]: All log files can be found below /home/hql/.ros/log/2023-08-21-16-45-37-739355-hql-ZhaoYang-K4e-ITL-89542
                [INFO] [gzserver-1]: process started with pid [89544]
                [INFO] [gzclient   -2]: process started with pid [89546]
                [INFO] [spawn_entity.py-3]: process started with pid [89549]
                [INFO] [robot_state_publisher-4]: process started with pid [89551]
                [robot_state_publisher-4] [INFO] [1692607538.110385903] [robot_state_publisher]: got segment base_footprint
                [robot_state_publisher-4] [INFO] [1692607538.110440445] [robot_state_publisher]: got segment base_link
                [robot_state_publisher-4] [INFO] [1692607538.110444751] [robot_state_publisher]: got segment base_scan
                [robot_state_publisher-4] [INFO] [1692607538.110447557] [robot_state_publisher]: got segment camera_depth_frame
                [robot_state_publisher-4] [INFO] [1692607538.110450364] [robot_state_publisher]: got segment camera_depth_optical_frame
                [robot_state_publisher-4] [INFO] [1692607538.110453364] [robot_state_publisher]: got segment camera_link
                [robot_state_publisher-4] [INFO] [1692607538.110456010] [robot_state_publisher]: got segment camera_rgb_frame
                [robot_state_publisher-4] [INFO] [1692607538.110458649] [robot_state_publisher]: got segment camera_rgb_optical_frame
                [robot_state_publisher-4] [INFO] [1692607538.110461414] [robot_state_publisher]: got segment caster_back_left_link
                [robot_state_publisher-4] [INFO] [1692607538.110464076] [robot_state_publisher]: got segment caster_back_right_link
                [robot_state_publisher-4] [INFO] [1692607538.110466752] [robot_state_publisher]: got segment imu_link
                [robot_state_publisher-4] [INFO] [1692607538.110469360] [robot_state_publisher]: got segment wheel_left_link
                [robot_state_publisher-4] [INFO] [1692607538.110472023] [robot_state_publisher]: got segment wheel_right_link
                [spawn_entity.py-3] [INFO] [1692607538.789917495] [spawn_entity]: Spawn Entity started
                [spawn_entity.py-3] [INFO] [1692607538.790110541] [spawn_entity]: Loading entity XML from Gazebo Model Database
                [spawn_entity.py-3] [INFO] [1692607538.790595980] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30
                [spawn_entity.py-3] [INFO] [1692607538.790753386] [spawn_entity]: Waiting for service /spawn_entity
                [spawn_entity.py-3] [INFO] [1692607539.043183064] [spawn_entity]: Calling service /spawn_entity
                [gzserver-1] [INFO] [1692607539.295802329] [turtlebot3_imu]: <initial_orientation_as_reference> is unset, using default value of false to comply with REP 145 (world as orientation reference)
                [spawn_entity.py-3] [INFO] [1692607539.351107675] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [turtlebot3_waffle]
                [INFO] [spawn_entity.py-3]: process has finished cleanly [pid 89549]
                [INFO] [ros2-5]: process started with pid [89678]
                [gzserver-1] [INFO] [1692607540.028915368] [camera_driver]: Publishing camera info to [/camera/camera_info]
                [gzserver-1] [INFO] [1692607540.063431383] [turtlebot3_diff_drive]: Wheel pair 1 separation set to [0.287000m]
                [gzserver-1] [INFO] [1692607540.063480234] [turtlebot3_diff_drive]: Wheel pair 1 diameter set to [0.066000m]
                [gzserver-1] [INFO] [1692607540.064669715] [turtlebot3_diff_drive]: Subscribed to [/cmd_vel]
                [gzserver-1] [INFO] [1692607540.065357436] [turtlebot3_diff_drive]: Advertise odometry on [/odom]
                [gzserver-1] [INFO] [1692607540.065961237] [turtlebot3_diff_drive]: Publishing odom transforms between [odom] and [base_footprint]
                [gzserver-1] [INFO] [1692607540.072362177] [turtlebot3_joint_state]: Going to publish joint [wheel_left_joint]
                [gzserver-1] [INFO] [1692607540.072400319] [turtlebot3_joint_state]: Going to publish joint [wheel_right_joint]
                [gzserver-1] [INFO] [1692607540.082506411] [gazebo_ros2_control]: Loading gazebo_ros2_control plugin
                [gzserver-1] [INFO] [1692607540.084576222] [gazebo_ros_control]: Starting gazebo_ros2_control plugin in namespace: /
                [gzserver-1] [INFO] [1692607540.084612420] [gazebo_ros_control]: Starting gazebo_ros2_control plugin in ros 2 node: gazebo_ros_control
                [gzserver-1] [ERROR] [1692607540.084640023] [gazebo_ros_control]: No parameter file provided. Configuration might be wrong
                [gzserver-1] [ERROR] [1692607540.084681996] [gazebo_ros_control]: failed to parse input yaml file(s)
                [ERROR] [ros2-5]: process has died [pid 89678, exit code 1, cmd 'ros2 control load_controller --set-state start joint_state_broadcaster'].
                [INFO] [ros2-6]: process started with pid [89768]
                [ERROR] [ros2-6]: process has died [pid 89768, exit code 1, cmd 'ros2 control load_controller --set-state start lidar_joint_position_controller'].
                • 8118775078
                  JQK @811877507
                  @811877507 launch文件:
                  import os
                  import xacro
                                                'urdf',
                          output='screen',
                          parameters=[params]
                                          arguments=[#'-topic', 'robot_description',
                                              '-database', 'turtlebot3_waffle',
                                          output='screen')
                          output='screen'
                          output='screen'
                          gazebo,
                          # IncludeLaunchDescription(
                          #     PythonLaunchDescriptionSource(
                          #         os.path.join(pkg_gazebo_ros, 'launch', 'gzserver.launch.py')
                          #     launch_arguments={'world': world}.items(),
                          #      os.path.join(pkg_gazebo_ros, 'launch', 'gzclient.launch.py')
                          spawn_entity,
