    ros2用colcon编译时报错文件依赖找不到
    ros2编译报错 缺少依赖 ros2编译
    3.0k
    • 3307093903
      小豆
      Starting >>> example_topic_rclcpp
      --- stderr: example_topic_rclcpp
      /usr/bin/ld: /usr/lib/gcc/x86_64-linux-gnu/11/../../../x86_64-linux-gnu/Scrt1.o: in function `_start':
      (.text+0x1b): undefined reference to `main'
      gmake[2]: *** [CMakeFiles/topic_publisher_01.dir/build.make:159: topic_publisher_01] Error 1
      gmake[1]: *** [CMakeFiles/Makefile2:137: CMakeFiles/topic_publisher_01.dir/all] Error 2
      gmake: *** [Makefile:146: all] Error 2
      Failed   <<< example_topic_rclcpp [0.74s, exited with code 2]
      Summary: 0 packages finished [0.88s]
        1 package failed: example_topic_rclcpp
        1 package had stderr output: example_topic_rclcpp
      求问各位这里怎么出错的,一步一步跟着小鱼的教程来的,功能包也编译进去了,cmakelist和package都改了,文件目录也没错,但节点文件依旧标红,编译时也确实报了错
      替代文字
      • 3307093903
        小豆 @小鱼
        @小鱼 抱歉,我这一节都是直接复制黏贴,没注意看源码,其实原文"2.话题之RCLCPP实现"那里用API设计发布者时展示的源码只是面向对象设计的类TopicPublisher01,没有main函数,导致编译时报错了
          小鱼 技术大佬 @330709390
          @330709390 把设计到的文件代码都贴一下
          3307093903 1 条回复 最后回复 回复 引用 0
          • 3307093903
            小豆 @小鱼
            这是cmakelist
            project(example_topic_rclcpp)
            endif()
            # find dependencies
            find_package(rclcpp REQUIRED)
            if(BUILD_TESTING)
            endif()
            add_executable(topic_publisher_01 src/topic_publisher_01.cpp)
            ament_target_dependencies(topic_publisher_01 rclcpp std_msgs)
            ament_package()
            这是package.xml
            <?xml version="1.0"?>
            <package format="3">
              <name>example_topic_rclcpp</name>
              <version>0.0.0</version>
              <maintainer email="bigbean@todo.todo">bigbean</maintainer>
              <license>TODO: License declaration</license>
              <depend>rclcpp</depend>
              <depend>std_msgs</depend>
              <export>
              </export>
            </package>
            这是cpp文件
            #include "rclcpp/rclcpp.hpp"
            #include "std_msgs/msg/string.hpp"
            class TopicPublisher01 : public rclcpp::Node
            public:
                // 构造函数,有一个参数为节点名称
                TopicPublisher01(std::string name) : Node(name)
                    RCLCPP_INFO(this->get_logger(), "大家好,我是%s.", name.c_str());
                    // 创建发布者
                    command_publisher_ = this->create_publisher<std_msgs::msg::String>("command", 10);
                    // 创建定时器,500ms为周期,定时发布
                    timer_ = this->create_wall_timer(std::chrono::milliseconds(500), std::bind(&TopicPublisher01::timer_callback, this));
            private:
                void timer_callback()
                    // 创建消息
                    std_msgs::msg::String message;
                    message.data = "forward";
                    // 日志打印
                    RCLCPP_INFO(this->get_logger(), "Publishing: '%s'", message.data.c_str());
                    // 发布消息
                    command_publisher_->publish(message);
                // 声名定时器指针
                // 声明话题发布者指针
                rclcpp::Publisher<std_msgs::msg::String>::SharedPtr command_publisher_;
            这是文件夹顺序
            chapt3_ws
            --|src
            --|--|example_topic_rclcpp
            --|--|--|src
            --|--|--|--|topic_publisher_01,cpp
            --|--|--|CMakeLists.txt
            --|--|--|package.xml
            --|--|--|include
            --|--|--|--|example_topic_rclcpp
            3307093903 小鱼小 2 条回复 最后回复 回复 引用 0
            • 3307093903
              小豆 @330709390
              @330709390 调换过ament_package()的位置依旧报一样的错
                小鱼 技术大佬 @330709390
                @330709390 在 ros2用colcon编译时报错文件依赖找不到 中说:
                01,cpp
                01.cpp 吧
                另外你的cpp文件里没有main函数
                • 3307093903
                  小豆 @小鱼
                  • 3307093903 330709390 将这个主题标记为已解决,在
