ubuntu20.04安装ros 1 noetic失败
#依赖问题
我是按照换源并且清除第三方源的选项进行安装
洁厕到出现依赖问题
E: Unable to correct problems, you have held broken packages.
ros-noetic-desktop-full : Depends: ros-noetic-desktop but it is not going t[/] Depends: ros-noetic-perception but it is not goin[] Depends: ros-noetic-simulators but it is not goin[|] Depends: ros-noetic-urdf-sim-tutorial but it is n[-]Result:code:100
#安装失败code_text请注意我,检测你在安装过程中出现依赖问题,请在稍后输入n,再选择y,即可解决
确认了解情况,请输入回车继续安装
的确,我先“n”后“y”选择方案,但是出现了
[-]Result:success for working with catkin.Run CMD Task:[sudo apt install python3-catkin-tools -y]
[-]Result:success e and 5 not upgraded.Run CMD Task:[sudo apt-cache search python3-rosdep ]
[]python3-rosdep2 - rosdep package manager abstraction tool for Robot OS (Pyth[-]Result:success anager abstraction tool for ROSRun CMD Task:[sudo apt install python3-rosdep -y]
[-]Result:success e and 5 not upgraded.Run CMD Task:[ls /opt/ros/noetic/setup.bash]
[-]Result:code:2安装失败了,请打开鱼香社区:https://fishros.org.cn/forum 在一键安装专区反馈问题...
[-]Result:code:2欢迎加入机器人学习交流QQ群:438144612(入群口令:一键安装)
如在使用过程中遇到问题,请打开:https://fishros.org.cn/forum 进行反馈 -
@moon_and_star2022 在 ubuntu20.04安装ros 1 noetic失败 中说:
给下完整日志
