    安装第一步出现报错
    ros一键安装 ros安装
    • 2061786562
      浅札
      File "/tmp/fishinstall/install.py", line 92, in <module>
      File "/tmp/fishinstall/install.py", line 84, in main
      File "/tmp/fishinstall/tools/base.py", line 1233, in run_tool_file
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 390, in run
      self.install_ros()
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 377, in install_ros
      if not self.support_install(): return False
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 279, in support_install
      if (osversion.get_codename() not in ros_dist_dic.keys()) and (osversion.get_codename() not in ros2_dist_dic.keys()):
      File "/tmp/fishinstall/tools/base.py", line 684, in get_codename
      self.detect_os()
      File "/tmp/fishinstall/tools/base.py", line 644, in detect_os
      tools.base.OsNotDetected: Could not detect OS, tried ['zorin', 'windows', 'nixos', 'clearlinux', 'ubuntu', 'slackware', 'rocky', 'rhel', 'qnx', 'pop', 'osx', 'sailfishos', 'tizen', 'oracle', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'openembedded', 'neon', 'mx', 'mint', 'linaro', 'gentoo', 'funtoo', 'freebsd', 'fedora', 'elementary', 'elementary', 'debian', 'cygwin', 'euleros', 'centos', 'manjaro', 'buildroot', 'arch', 'amazon', 'alpine', 'almalinux']
        小鱼 技术大佬 @206178656
        @206178656 在 安装第一步出现报错 中说:
