    求助handeye-calib的aruco result没有结果啥情况
    handeye-calib 手眼标定 aruco
    2.2k
    • 28496665612
      Kane
      我用的Astra Pro,运行了aruco_start_realsense_sdk.launch(内容修改了放下面)
      <launch>
           <include file="$(find astra_camera)/launch/astra_pro.launch">
              <arg name="enable_depth" value="false" />
           </include>
          <arg name="markerId"        default="6"/>
          <arg name="markerSize"      default="0.100"/>
          <arg name="eye"             default="left"/>
          <arg name="marker_frame"    default="aruco_marker_frame"/>
          <arg name="ref_frame"       default=""/>
          <arg name="corner_refinement" default="LINES" />
          <node pkg="aruco_ros" type="single" name="aruco_single">
              <remap from="/camera_info" to="/camera/color/camera_info" />
              <remap from="/image" to="/camera/color/image_raw" />
              <param name="image_is_rectified" value="True"/>
              <param name="marker_size"        value="$(arg markerSize)"/>
              <param name="marker_id"          value="$(arg markerId)"/>
              <param name="reference_frame"    value="$(arg ref_frame)"/>
              <param name="camera_frame"       value="stereo_gazebo_$(arg eye)_camera_optical_frame"/>
              <param name="marker_frame"       value="$(arg marker_frame)" />
              <param name="corner_refinement"  value="$(arg corner_refinement)" />
          </node>
          <node name="image_view" pkg="image_view" type="image_view" respawn="false" output="screen">
              <remap from="image" to="/aruco_single/result"/>
              <param name="autosize" value="true" />
          </node>
      </launch>
      但是在结果中并没有识别到我的aruco啥情况
      启动节点相关信息贴在下面
      wheeltec-client@ubuntu:~/Desktop/handeye-calib$ roslaunch handeye-calib aruco_start_realsense_sdk.launch
      ... logging to /home/wheeltec-client/.ros/log/f18563ce-4be8-11ee-ba1e-000c29bc7a6b/roslaunch-ubuntu-5778.log
      Press Ctrl-C to interrupt
      started roslaunch server http://192.168.0.100:38889/
      SUMMARY
      PARAMETERS
       * /aruco_single/camera_frame: stereo_gazebo_lef...
       * /aruco_single/corner_refinement: LINES
       * /aruco_single/image_is_rectified: True
       * /aruco_single/marker_frame: aruco_marker_frame
       * /aruco_single/marker_id: 6
       * /aruco_single/marker_size: 0.1
       * /aruco_single/reference_frame:
       * /camera/camera/camera_name: camera
       * /camera/camera/color_depth_synchronization: False
       * /camera/camera/color_format: RGB
       * /camera/camera/color_fps: 30
       * /camera/camera/color_height: 480
       * /camera/camera/color_info_uri:
       * /camera/camera/color_roi_height: -1
       * /camera/camera/color_roi_width: -1
       * /camera/camera/color_roi_x: -1
       * /camera/camera/color_roi_y: -1
       * /camera/camera/color_width: 640
       * /camera/camera/connection_delay: 100
       * /camera/camera/depth_align: False
       * /camera/camera/depth_format: Y11
       * /camera/camera/depth_fps: 30
       * /camera/camera/depth_height: 480
       * /camera/camera/depth_roi_height: -1
       * /camera/camera/depth_roi_width: -1
       * /camera/camera/depth_roi_x: -1
       * /camera/camera/depth_roi_y: -1
       * /camera/camera/depth_scale: 1
       * /camera/camera/depth_width: 640
       * /camera/camera/device_num: 1
       * /camera/camera/enable_color: True
       * /camera/camera/enable_d2c_viewer: False
       * /camera/camera/enable_depth: False
       * /camera/camera/enable_ir: True
       * /camera/camera/enable_point_cloud: True
       * /camera/camera/enable_point_cloud_xyzrgb: False
       * /camera/camera/enable_publish_extrinsic: False
       * /camera/camera/flip_color: False
       * /camera/camera/flip_depth: False
       * /camera/camera/flip_ir: False
       * /camera/camera/ir_format: Y10
       * /camera/camera/ir_fps: 30
       * /camera/camera/ir_height: 480
       * /camera/camera/ir_info_uri:
       * /camera/camera/ir_width: 640
       * /camera/camera/oni_log_level: verbose
       * /camera/camera/oni_log_to_console: False
       * /camera/camera/oni_log_to_file: False
       * /camera/camera/product_id: 0
       * /camera/camera/publish_tf: True
       * /camera/camera/serial_number:
       * /camera/camera/tf_publish_rate: 10.0
       * /camera/camera/use_uvc_camera: True
       * /camera/camera/uvc_camera_format: mjpeg
       * /camera/camera/uvc_flip: False
       * /camera/camera/uvc_product_id: 0x0501
       * /camera/camera/uvc_retry_count: 100
       * /camera/camera/uvc_vendor_id: 0x2bc5
       * /camera/camera/vendor_id: 0
       * /image_view/autosize: True
       * /rosdistro: melodic
       * /rosversion: 1.14.13
      NODES
          aruco_single (aruco_ros/single)
          image_view (image_view/image_view)
        /camera/
          camera (astra_camera/astra_camera_node)
      auto-starting new master
      process[master]: started with pid [5788]
      ROS_MASTER_URI=http://192.168.0.100:11311
      setting /run_id to f18563ce-4be8-11ee-ba1e-000c29bc7a6b
      process[rosout-1]: started with pid [5799]
      started core service [/rosout]
      process[camera/camera-2]: started with pid [5806]
      process[aruco_single-3]: started with pid [5807]
      process[image_view-4]: started with pid [5808]
      [ INFO] [1693917435.719332857]: Initializing nodelet with 8 worker threads.
      [ INFO] [1693917435.722082159]: Starting camera node...
      [ INFO] [1693917435.725723763]: Creating camera node...
      [ INFO] [1693917435.726993259]: OBCameraNodeFactory::OBCameraNodeFactory
      [ INFO] [1693917435.727017125]: Initializing OBCameraNodeFactory...
      [ INFO] [1693917435.736957529]: init Done
      [ INFO] [1693917435.737009909]: Creating camera node done...
      [ INFO] [1693917435.737055413]: Query device
      [ INFO] [1693917435.737101052]: Found 1 devices
      [ INFO] [1693917435.737128977]: Device connected: (name, Astra) (uri, 2bc5/0403@3/8) (vendor, Orbbec)
      [ INFO] [1693917435.737157659]: Trying to open device: 2bc5/0403@3/8
      [ WARN] [1693917435.758409897]: Corner refinement options have been removed in ArUco 3.0.0, corner_refinement ROS parameter is deprecated
      [ INFO] [1693917435.777154523]: Using transport "raw"
      [ WARN] [1693917435.797969694]: normalizeImageIllumination is unimplemented!
      [ INFO] [1693917435.837597725]: OBCameraNodeFactory::onDeviceConnected Open device start
      Warning: USB events thread - failed to set priority. This might cause loss of data...
      [ INFO] [1693917435.908076975]: OBCameraNodeFactory::onDeviceConnected Open device done, STATUS 0
      [ INFO] [1693917435.908131452]: Device connected: Astra serial number: AC29B13006H
      [ INFO] [1693917435.908143750]: Start device
      [ INFO] [1693917435.922428941]: Stream depth is disabled
      [ INFO] [1693917435.930971520]: set ir video mode Resolution :640x480@30Hz
      format PIXEL_FORMAT_GRAY8
      [ INFO] [1693917435.932176716]: OBCameraNode::setupUVCCamera
      [ WARN] [1693917435.932231930]: Publishing dynamic camera transforms (/tf) at 10 Hz
      [ INFO] [1693917435.941890823]: open uvc camera
      [ INFO] [1693917436.016246721]: uvc config: vendor_id: 2bc5
      product_id: 501
      width: 640
      height: 480
      fps: 30
      serial_number: AC29B13006H
      format: mjpeg
      [ INFO] [1693917436.071739191]: open camera success
      [ INFO] [1693917436.071822644]: using default calibration URL
      [ INFO] [1693917436.071854523]: camera calibration URL: file:///home/wheeltec-client/.ros/camera_info/rgb_camera.yaml
      [ INFO] [1693917436.101592414]: using default calibration URL
      [ INFO] [1693917436.101639678]: camera calibration URL: file:///home/wheeltec-client/.ros/camera_info/ir_camera.yaml
      [ INFO] [1693917436.101988454]: OBCameraNode initialized
      [ INFO] [1693917436.102036440]: Start device  done
      [ INFO] [1693917436.215100515]: Image stream color subscribed
      [ INFO] [1693917436.215138519]: UVCCameraDriver image subscribed
      [ INFO] [1693917436.233684665]: set uvc mode 640x480@30 format mjpeg
      ^C[image_view-4] killing on exit
      [aruco_single-3] killing on exit
      [camera/camera-2] killing on exit
      [rosout-1] killing on exit
      [master] killing on exit
      shutting down processing monitor...
      ... shutting down processing monitor complete
      done
        小鱼 技术大佬 @2849666561
        @2849666561 markid 确认下
        28496665612 1 条回复 最后回复 回复 引用 0
        • 28496665612
          Kane @小鱼
          @小鱼 markid 是6没问题吧
          • 28496665612
            Kane @2849666561
            @2849666561 我在实验室找了一块板子 ,把他放在相机前有时候会闪出来一个result
            • 28496665612 2849666561 删除了该主题于
            • 小鱼小 小鱼 恢复了该主题于
