    ROS2 一个节点能同时发布和订阅多个话题吗?
    ros2通信 发布订阅 机器人
    2.6k
    • 74934167
      Jarvis
      如题,在用jetson nano + pico做个机器人,过程中发现 一个节点中无法同时发布和订阅不同的话题,代码 如下:
      pico_info这个话题收不到回调,这个pico_info发布时成功了,没报错的
      import rclpy
      import json
      from rclpy.node import Node
      from std_msgs.msg import String
      from controller.service import init_server
      from controller.run_data import *
      class ControllerNode(Node):
      def __init__(self):
          super().__init__('controller_Node')
          self.command_publisher = self.create_publisher(String, 'controller', 10)
          self.create_subscription(String, 'pico_info', self.pico_info_callback, 6)
          init_server(self.command_publisher)
      def pico_info_callback(self, msg):
          global voltage12v
          print('Recive message: "%s"' % msg.data)
          # msg.data =  '{"target": "jarvis", "voltage12v": 11.32}'
          rec_json = json.loads(str(msg.data))
          voltage12v = int(rec_json['voltage12v'])
          set_voltage12v(voltage12v)
      def main(args=None):
      rclpy.init(args=args)
      controller_Node = ControllerNode()
      rclpy.spin(controller_Node)
      controller_Node.destroy_node()
      rclpy.shutdown()
      if name == 'main':
        小鱼 技术大佬 @7493416
        @7493416 有没有可能没有发布
        74934167 2 条回复 最后回复 回复 引用 0
        • 74934167
          Jarvis @小鱼
          最后由 7493416 编辑
          @小鱼 感谢大佬的回复,大佬的意思就是说ROS2是支持同时发布和订阅多个话题,是吧?是的话,我再排查一下消息是否发布成功;以下是发布消息节点的发布相关代码
          class LowerNode(Node):
              def __init__(self):
                  super().__init__('motion_node')
                  self.pico_publisher = self.create_publisher(String, 'pico_info', 10)
                  set_pico_publisher(self.pico_publisher)
                  self.create_subscription(String, 'recognition_obj', self.recognition_obj_callback, 10)
                  self.create_subscription(String, 'controller', self.controller_callback, 10)
                  uart_init()
                  _thread.start_new_thread(recv_data, (self.pico_publisher,))
          import serial as serial
          import time
          import random
          from motion.utils import command_util
          from motion.run_data import *
          my_uart = serial.Serial(port="/dev/ttyTHS1", baudrate=115200)
          def uart_init():
              if not my_uart.is_open:
                  my_uart.open()
          def send_data(s_data):
              s_data = s_data + "\n"
              print('Send data: ' + s_data)
              my_uart.write(s_data.encode())
              time.sleep(0.3)
          def recv_data(pico_publisher):
              while True:
                  r_data = my_uart.readline().decode()
                  print('recv data: ' + r_data)
                  if len(r_data) > 0:
                      s_msg = String() # 要发布的消息类型
                      s_msg.data = str(r_data)
                      pico_publisher.publish(s_msg)
                  time.sleep(0.2)
          • 74934167
            Jarvis @小鱼
            话题应该是发布成功了的。难道是接受问题?
              小鱼 技术大佬 @7493416
              @7493416 肯定支持的,是否发布成功用 ros2 topic echo 检查
