    3.7.3.1 自定义接口实践 编译报错
    编译失败 ros2编译
    4.4k
    • 11941006571
      @灵思皇后
      报错信息
      Failed <<< example_ros2_interfaces [0.50s, exited with code 1]
      Summary: 0 packages finished [0.63s]
      1 package failed: example_ros2_interfaces
      1 package had stderr output: example_ros2_interfaces
      ljy@ljy-LXiaoXinPro-16:~/roscode/chap3$ colcon build --packages-select example_ros2_interfaces
      Starting >>> example_ros2_interfaces
      --- stderr: example_ros2_interfaces
      CMake Error at /opt/ros/humble/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:93 (message):
      rosidl_generate_interfaces() the passed file 'srv/MoveRobot.srv' doesn't
      exist relative to the CMAKE_CURRENT_SOURCE_DIR
      '/home/ljy/roscode/chap3/example_ros2_interfaces'
      CMakeLists.txt:13 (rosidl_generate_interfaces)
      这是文件结构
      ─ example_ros2_interfaces
      │ ├── CMakeLists.txt
      │ ├── include
      │ │ └── example_ros2_interfaces
      │ ├── msg
      │ │ ├── RobotPose.msg
      │ │ └── RobotStatus.msg
      │ ├── package.xml
      │ └── srv
      │ └── Moveobot.srv
      这是cmakelists
      project(example_ros2_interfaces)
      endif()
      find dependencies
      find_package(geometry_msgs REQUIRED)
      "msg/RobotPose.msg"
      "msg/RobotStatus.msg"
      "srv/MoveRobot.srv"
      DEPENDENCIES geometry_msgs
      if(BUILD_TESTING)
      the following line skips the linter which checks for copyrights
      comment the line when a copyright and license is added to all source files
      the following line skips cpplint (only works in a git repo)
      comment the line when this package is in a git repo and when
      endif()
      ament_package()
      这是package.xml
      <?xml version="1.0"?>
      <package format="3">
      <name>example_ros2_interfaces</name>
      <version>0.0.0</version>
      <maintainer email="ljy@todo.todo">ljy</maintainer>
      <license>TODO: License declaration</license>
      <depend>rosidl_default_generators</depend>
      <depend>geometry_msgs</depend>
      <export>
      </export>
      </package>
      试过删除build没用,anaconda卸载后编译成功,再开机文件就乱了,然后建了一模一样的工作空间,编译又不通过。实在不知道怎么改了
      小鱼小 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @1194100657
        @1194100657 在 3.7.3.1 自定义接口实践 编译报错 中说:
        目录有没有存在中文之类的,构建目录位置是否正确
        11941006571 1 条回复 最后回复 回复 引用 0
        • 11941006571
          @灵思皇后 @小鱼
          @小鱼 目录没有中文,文件位置,编译的文件夹也没错。之前的代码编译都没有问题。
            小鱼 技术大佬 @1194100657
            看这个错误,你试试把目录带 install
            build 都删掉,一层层的看看,
            11941006571 3 条回复 最后回复 回复 引用 0
            • 11941006571
              @灵思皇后 @小鱼
              @小鱼 报错全文是这样的
                '/home/ljy/d2lros2/chap3/example_ros2_interfaces'
              • 11941006571
                @灵思皇后 @小鱼
                @小鱼 全删过不好使
                • 11941006571
                  @灵思皇后 @小鱼
                  /opt/ros/humble/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:93 是这样的
                    小鱼 技术大佬 @1194100657
                    @1194100657 有修改过bashrc吗,重新打开一个中断试试
                    • F
                      fadai33
                      目录结构错了,Moveobot.srv应该在srv下,你的这里是同级目录了,自然找不到报错。
                      1 条回复 最后回复 回复 引用 -1
