    小鱼文档第10章,建图过程中,rviz显示的小车抖动且地图出现虚影。
    ros2 rviz slam
    1.3k
    • 10948181231
      yusheni
      URDF代码使用的时小鱼在github上的,请问这种问题时什么原因?
      启动gezebo日志如下:
      yusheni@yusheni-virtual-machine:~/chapt8_ws$ ros2 launch fishbot_description gazebo.launch.py
      [INFO] [launch]: All log files can be found below /home/yusheni/.ros/log/2023-10-23-10-55-20-998742-yusheni-virtual-machine-7985
      [INFO] [gazebo-1]: process started with pid [7986]
      [INFO] [spawn_entity.py-2]: process started with pid [7988]
      [INFO] [robot_state_publisher-3]: process started with pid [7990]
      [robot_state_publisher-3] [WARN] [1698029721.218749417] [robot_state_publisher]: No robot_description parameter, but command-line argument available. Assuming argument is name of URDF file. This backwards compatibility fallback will be removed in the future.
      [robot_state_publisher-3] [INFO] [1698029721.230430009] [robot_state_publisher]: got segment base_footprint
      [robot_state_publisher-3] [INFO] [1698029721.231211913] [robot_state_publisher]: got segment base_link
      [robot_state_publisher-3] [INFO] [1698029721.231729844] [robot_state_publisher]: got segment caster_link
      [robot_state_publisher-3] [INFO] [1698029721.234462129] [robot_state_publisher]: got segment imu_link
      [robot_state_publisher-3] [INFO] [1698029721.235200791] [robot_state_publisher]: got segment laser_link
      [robot_state_publisher-3] [INFO] [1698029721.235726514] [robot_state_publisher]: got segment left_wheel_link
      [robot_state_publisher-3] [INFO] [1698029721.237213773] [robot_state_publisher]: got segment right_wheel_link
      [spawn_entity.py-2] [INFO] [1698029721.735390593] [spawn_entity]: Spawn Entity started
      [spawn_entity.py-2] [INFO] [1698029721.736613664] [spawn_entity]: Loading entity XML from file /home/yusheni/chapt8_ws/install/fishbot_description/share/fishbot_description/urdf/fishbot_base.urdf
      [spawn_entity.py-2] [INFO] [1698029721.738090255] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30
      [spawn_entity.py-2] [INFO] [1698029721.738957924] [spawn_entity]: Waiting for service /spawn_entity
      [gazebo-1] Gazebo multi-robot simulator, version 11.10.2
      [gazebo-1] Copyright (C) 2012 Open Source Robotics Foundation.
      [gazebo-1] Released under the Apache 2 License.
      [gazebo-1] http://gazebosim.org
      [gazebo-1]
      [gazebo-1]
      [spawn_entity.py-2] [INFO] [1698029722.749995673] [spawn_entity]: Calling service /spawn_entity
      [gazebo-1] [Msg] Waiting for master.
      [gazebo-1] [Msg] Connected to gazebo master @ http://127.0.0.1:11345
      [gazebo-1] [Msg] Publicized address: 192.168.187.128
      [gazebo-1] [Wrn] [GuiIface.cc:120] Could not find the Qt platform plugin "wayland" in ""
      [spawn_entity.py-2] [INFO] [1698029723.211948989] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [fishbot]
      [gazebo-1] [INFO] [1698029723.361446924] [diff_drive]: Wheel pair 1 separation set to [0.200000m]
      [gazebo-1] [INFO] [1698029723.362966191] [diff_drive]: Wheel pair 1 diameter set to [0.065000m]
      [gazebo-1] [INFO] [1698029723.365994012] [diff_drive]: Subscribed to [/cmd_vel]
      [gazebo-1] [INFO] [1698029723.370855855] [diff_drive]: Advertise odometry on [/odom]
      [gazebo-1] [INFO] [1698029723.378073224] [diff_drive]: Publishing odom transforms between [odom] and [base_footprint]
      [INFO] [spawn_entity.py-2]: process has finished cleanly [pid 7988]
      [gazebo-1] [INFO] [1698029723.414203824] [fishbot_joint_state]: Going to publish joint [right_wheel_joint]
      [gazebo-1] [INFO] [1698029723.414289619] [fishbot_joint_state]: Going to publish joint [left_wheel_joint]
      [gazebo-1] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/yusheni/.gazebo/models/yosemite"
      [gazebo-1] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/yusheni/.gazebo/models/youbot"
      [gazebo-1] [Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
      小鱼小 10948181231 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @1094818123
        @1094818123 跑慢一点
        10948181231 1 条回复 最后回复 回复 引用 0
        • 10948181231
          yusheni @1094818123
          @1094818123 谢谢大佬,解决了
          • 10948181231
            yusheni @小鱼
            @小鱼 谢谢大佬 解决了
