    如何在不使用nav2_amcl节点的情况下实现单点导航?
    Nav2
    ros2 galactic nav2
    • 3748703613
      孤独的幸存者
      我自己写了一个定位的节点可以发布map->odom的tf转换。
      我的机器人上面有里程计节点提供odom->base_link的tf转换。
      因为我是直接使用平面图作为map的,不需要LIDAR来进行建图和定位,但是我不知道如何配置navigation.yaml.
      我尝试调用nav2_bringup里的navigation.launch.py且使用了下面这个yaml文件:
      # GPS WPF CHANGES:
      # - amcl params where removed. They are not needed because global localization is provided
      #   by an ekf node on robot_localization fusing gps data with local odometry sources
      # - static layer is removed from both costmaps, in this tutorial we assume there is no map
      #   of the environment
      # - global costmap is set to be rolling to allow the robot to traverse big environment by
      #   following successive relatively close waypoints that fit in a smaller rolling costmap
      bt_navigator:
        ros__parameters:
          global_frame: map
          robot_base_frame: base_link
          odom_topic: /odom
          bt_loop_duration: 10
          default_server_timeout: 20
          navigators: ["navigate_to_pose", "navigate_through_poses"]
          navigate_to_pose:
            plugin: "nav2_bt_navigator/NavigateToPoseNavigator"
          navigate_through_poses:
            plugin: "nav2_bt_navigator/NavigateThroughPosesNavigator"
          plugin_lib_names:
            # - nav2_smooth_path_action_bt_node
            - nav2_spin_action_bt_node
            - nav2_wait_action_bt_node
            # - nav2_assisted_teleop_action_bt_node
            - nav2_back_up_action_bt_node
            # - nav2_drive_on_heading_bt_node
            # - nav2_globally_updated_goal_condition_bt_node
            # - nav2_is_path_valid_condition_bt_node
            # - nav2_are_error_codes_active_condition_bt_node
            # - nav2_would_a_controller_recovery_help_condition_bt_node
            # - nav2_would_a_planner_recovery_help_condition_bt_node
            # - nav2_would_a_smoother_recovery_help_condition_bt_node
            # - nav2_truncate_path_local_action_bt_node
            - nav2_recovery_node_bt_node
            # - nav2_path_expiring_timer_condition
            - nav2_single_trigger_bt_node
            - nav2_goal_updated_controller_bt_node
            # - nav2_controller_cancel_bt_node
            # - nav2_path_longer_on_approach_bt_node
            # - nav2_wait_cancel_bt_node
            # - nav2_spin_cancel_bt_node
            # - nav2_back_up_cancel_bt_node
            # - nav2_assisted_teleop_cancel_bt_node
            # - nav2_drive_on_heading_cancel_bt_node
            # - nav2_is_battery_charging_condition_bt_node
          # error_code_names:
          #   - compute_path_error_code
          #   - follow_path_error_code
      controller_server:
        ros__parameters:
          controller_frequency: 20.0
          min_x_velocity_threshold: 0.001
          min_y_velocity_threshold: 0.5
          min_theta_velocity_threshold: 0.001
          failure_tolerance: 0.3
          progress_checker_plugins: ["progress_checker"]
          goal_checker_plugins: ["general_goal_checker"] # "precise_goal_checker"
          controller_plugins: ["FollowPath"]
          # Progress checker parameters
          progress_checker:
            plugin: "nav2_controller::SimpleProgressChecker"
            required_movement_radius: 0.5
            movement_time_allowance: 10.0
          # Goal checker parameters
          #precise_goal_checker:
          #  plugin: "nav2_controller::SimpleGoalChecker"
          #  xy_goal_tolerance: 0.25
          #  yaw_goal_tolerance: 0.25
          #  stateful: True
          general_goal_checker:
            stateful: True
          # DWB parameters
          FollowPath:
            plugin: "dwb_core::DWBLocalPlanner"
            debug_trajectory_details: True
            min_vel_x: 0.0
            min_vel_y: 0.0
            max_vel_x: 0.26
            max_vel_y: 0.0
            max_vel_theta: 1.0
            min_speed_xy: 0.0
            max_speed_xy: 0.26
            min_speed_theta: 0.0
            # Add high threshold velocity for turtlebot 3 issue.
            # https://github.com/ROBOTIS-GIT/turtlebot3_simulations/issues/75
            acc_lim_x: 2.5
            acc_lim_y: 0.0
            acc_lim_theta: 3.2
            decel_lim_x: -2.5
            decel_lim_y: 0.0
            decel_lim_theta: -3.2
            vx_samples: 20
            vy_samples: 5
            vtheta_samples: 20
            sim_time: 1.7
            linear_granularity: 0.05
            angular_granularity: 0.025
            transform_tolerance: 0.2
            trans_stopped_velocity: 0.25
            short_circuit_trajectory_evaluation: True
            stateful: True
            critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
            BaseObstacle.scale: 0.02
            PathAlign.scale: 32.0
            PathAlign.forward_point_distance: 0.1
            GoalAlign.scale: 24.0
            GoalAlign.forward_point_distance: 0.1
            PathDist.scale: 32.0
            GoalDist.scale: 24.0
            RotateToGoal.scale: 32.0
            RotateToGoal.slowing_factor: 5.0
            RotateToGoal.lookahead_time: -1.0
      # GPS WPF CHANGE: Remove static layer
      local_costmap:
        local_costmap:
          ros__parameters:
            # update_frequency: 5.0
            update_frequency: 10.0
            # publish_frequency: 2.0
            publish_frequency: 5.0
            global_frame: odom
            rolling_window: true
            width: 3
            height: 3
            resolution: 0.05
            # robot_radius: 0.22
            robot_radius: 0.6
            plugins: ["voxel_layer", "inflation_layer"]
            # plugins: ["inflation_layer"]
            inflation_layer:
              cost_scaling_factor: 3.0
              inflation_radius: 0.55
            voxel_layer:
              plugin: "nav2_costmap_2d::VoxelLayer"
              enabled: True
              publish_voxel_map: True
              origin_z: 0.0
              z_resolution: 0.05
              z_voxels: 16
              max_obstacle_height: 2.0
              mark_threshold: 0
              observation_sources: scan
              scan:
                topic: /scan
                clearing: True
                marking: True
                data_type: "LaserScan"
                raytrace_max_range: 3.0
                raytrace_min_range: 0.0
                obstacle_max_range: 2.5
                obstacle_min_range: 0.0
      # GPS WPF CHANGE: Set rolling global costmap with 50x50 size. See note below
      global_costmap:
        global_costmap:
          ros__parameters:
            # update_frequency: 1.0
            update_frequency: 20.0
            # publish_frequency: 1.0
            publish_frequency: 10.0
            global_frame: map
            robot_radius: 0.6
            resolution: 0.1
            # When using GPS navigation you will potentially traverse huge environments which are not practical to
            # fit on a big static costmap. Thus it is recommended to use a rolling global costmap large enough to
            # contain each pair of successive waypoints. See: https://github.com/ros-planning/navigation2/issues/2174
            rolling_window: True
            # width: 50
            width: 10
            # height: 50
            height: 10
            track_unknown_space: true
            # no static map
            plugins: ["obstacle_layer", "inflation_layer"]
            obstacle_layer:
              enabled: True
              scan:
                topic: /scan
                clearing: True
                marking: True
                # outdoors there will probably be more inf points
                inf_is_valid: true
            inflation_layer:
      # The yaml_filename does not need to be specified since it going to be set by defaults in launch.
      # If you'd rather set it in the yaml, remove the default "map" value in the tb3_simulation_launch.py
      # file & provide full path to map below. If CLI map configuration or launch default is provided, that will be used.
      # map_server:
      #   ros__parameters:
      #     yaml_filename: ""
      map_server:
        ros__parameters:
          # 这里是我的地图文件路径,路径没有问题,地图加载也没有,只是这里不方便暴露出来
          yaml_filename: "turtlebot3_world.yaml"
          topic_name: "/map"
          frame_id: "map"
      map_saver:
        ros__parameters:
          save_map_timeout: 5.0
          free_thresh_default: 0.25
          occupied_thresh_default: 0.65
      planner_server:
        ros__parameters:
          expected_planner_frequency: 20.0
          planner_plugins: ["GridBased"]
          GridBased:
            plugin: "nav2_navfn_planner/NavfnPlanner"
            tolerance: 0.5
            use_astar: false
            allow_unknown: true
      smoother_server:
        ros__parameters:
          smoother_plugins: ["simple_smoother"]
          simple_smoother:
            plugin: "nav2_smoother::SimpleSmoother"
            tolerance: 1.0e-10
            max_its: 1000
            do_refinement: True
      behavior_server:
        ros__parameters:
          local_costmap_topic: local_costmap/costmap_raw
          global_costmap_topic: global_costmap/costmap_raw
          local_footprint_topic: local_costmap/published_footprint
          global_footprint_topic: global_costmap/published_footprint
          cycle_frequency: 10.0
          behavior_plugins: ["spin", "backup", "drive_on_heading", "assisted_teleop", "wait"]
          spin:
            plugin: "nav2_behaviors/Spin"
          backup:
            plugin: "nav2_behaviors/BackUp"
          drive_on_heading:
            plugin: "nav2_behaviors/DriveOnHeading"
          wait:
            plugin: "nav2_behaviors/Wait"
          assisted_teleop:
            plugin: "nav2_behaviors/AssistedTeleop"
          local_frame: odom
          global_frame: map
          transform_tolerance: 0.1
          simulate_ahead_time: 2.0
          max_rotational_vel: 1.0
          min_rotational_vel: 0.4
          rotational_acc_lim: 3.2
      waypoint_follower:
        ros__parameters:
          loop_rate: 20
          stop_on_failure: false
          waypoint_task_executor_plugin: "wait_at_waypoint"
          wait_at_waypoint:
            plugin: "nav2_waypoint_follower::WaitAtWaypoint"
            enabled: True
            waypoint_pause_duration: 200
      velocity_smoother:
        ros__parameters:
          smoothing_frequency: 20.0
          scale_velocities: False
          feedback: "OPEN_LOOP"
          max_velocity: [0.26, 0.0, 1.0]
          min_velocity: [-0.26, 0.0, -1.0]
          max_accel: [2.5, 0.0, 3.2]
          max_decel: [-2.5, 0.0, -3.2]
          odom_topic: "odom"
          odom_duration: 0.1
          deadband_velocity: [0.0, 0.0, 0.0]
          velocity_timeout: 1.0
      启动后没有报错,但是我不清楚如何给它机器人的初始位姿和目标点的位姿,如果使用rviz2里的插件在map上给的话会有报错:
      [planner_server-7] [WARN] [1698376103.809749922] [planner_server]: The goal sent to the planner is off the global costmap. Planning will always fail to this goal.
      [planner_server-7] [WARN] [1698376103.810110705] [planner_server]: GridBased: failed to create plan with tolerance 0.50.
      [planner_server-7] [WARN] [1698376103.810187956] [planner_server]: Planning algorithm GridBased failed to generate a valid path to (6.39, -3.78)
      [planner_server-7] [WARN] [1698376103.810229686] [planner_server_rclcpp_node]: [compute_path_to_pose] [ActionServer] Aborting handle.
      我一开始以为是我的global_costmap大小太小没有把目标点也包含在内,但是之后我将global_costmap改大之后还是报同样的错误。
      会不会是我那个自己写的定位节点除了发布map->odomtf转换之外还需要别的?
      B 1 条回复 最后回复 回复 引用 0
      • B
        benaidandan @374870361
        @374870361 老哥,你解决了吗
